06-15-2017 01:15 AM - edited 03-01-2019 04:38 AM
Hi, I am receiving this error several times while trying to install APIC-EM.
Do you know how to resolve this?
06-23-2017 10:44 AM
What it is telling you is that the port 14141, used for management is refusing connections.
This seems like a strange error to be the culprit behind being unable to install...
Please login to APIC-EM as the grapevine user at the command line.
Execute 'tar czvf logs4cisco.tgz /var/log/installer/`
Then please attach the results.
06-23-2017 11:24 AM
Is this a single host deployment or multiple? If multiple, is this server 2 or 3? if it is not the first server, is there a firewall in between?
06-30-2017 10:15 AM
Did you solve the issue?
06-30-2017 02:51 PM
No. Finally I have installed on another machine with necessary resources, and it works! Thank you for your answer!!
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
