Debbuging PnP process
JPvisltgb
Level 4
Level 4
Hi All,
I can't find any information about how to debug failed PnP proccess, where is log files stored and so on .
I'm trying to deploy config on ISR router and getting:
Received response from pnp agent for message correlatorId: CiscoPnP-1.0-16-320-7FA078EAB2A8-14 but with error code : ZTD_CMD_ERROR Response String: ERROR:PnP Service Error 1410:Invalid config found
service log:
I understand that  there is mistake in config file, but maybe there is a way to find out where exactly this mistake is  ?
I found workaround.
I've used Denali-16.3.4(ED) image on router and my config failed to install, but today I tried to change it to 3.16.5S and config deployed successfully.
13 Replies 13
aradford
I usually just cut/paste the config into the console to test.
Do you have a  "service log" command in the configuration?
Adam
No, I don't have this command. The problem is that I created config on router and then  I just uploaded it to Apic-em and now trying to deploy it via Pnp
ok.  To access log files:
ssh to the console of the APIC-EM
# find the IP address of the pnp service
$ grape instance status | grep pnp
pnp-service                          5.17.31.211  running      59621988-fdc9-4788-957c-7bdbb7de0922  169.254.0.184  9:32:39
$ ssh 169.254.0.184
# the number for you will be different.
$ cd /var/log/grapevine/services/pnp-service/5.17.31.211/
# pnp-service.log has all of the logging.
$ ls
pnp-service.log
I found it. However there is no useful information, just same message that I posted in my question.
I got info from router:
show pnp task
------------------ show pnp tasks ---------------------
Certificate-Install Task - Last Run ID:2, ST:7201, Result:Success, LT:94182, ET:3338 ms
        Src:[http://pnpserver.domain.com:80/ca/pem], Dst:[pnplabel]
Device-Auth Task - Never Run
Device-Info Task - Never Run
Image-Install Task - Never Run
SMU Task - Never Run
Config-Upgrade Task - Last Run ID:5, ST:5202, Result:Failed, LT:545313, ET:6806 ms
        Src:[https://pnpserver.domain.com:443/api/v1/file/onetimedownload/7efee699-39bf-47bb-af21-9202921cbe], Dst:[running]
        Error Code:1410, Msg:[Invalid config found]
CLI-Config Task - Last Run ID:3, ST:5201, Result:Success, LT:156998, ET:84 ms
        Src:[cli-config request], Dst:[running-config]
Licensing Task - Never Run
File-Transfer Task - Never Run
Redirection Task - Never Run
CLI-Exec Task - Last Run ID:1, ST:5401, Result:Success, LT:80463, ET:3 ms
        Src:[cli-exec request], Dst:[running-exec]
Script Task - Never Run
As i understand this error tells that it trying to get config from apic-em but failed. It is not my config problem.
Am I correct ?
What version of APIC-EM is this?  We now check for "special characters" but may not catch all of them.
Do you accidentally have special characters in your config file?
Were you using a windows device to edit the config file?
APIC-EM Version 1.5.0.1368.
PnP 1.5.0.211
Config has special chars in commands:
enable secret 5 hashed secret
username admin secret 5 hashed secret
those are ok.. You probably should delete that information.
you can edit your post and remove it.
By special characters, I mean things like windows smart quotes or '\r' type sequences.
What did you use to edit the configuration file?
I found workaround.
interesting.. let me chat to engineering about that.
What device were you running this on?
cisco ISR4321/K9
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     FoundationSuiteK9     Permanent      FoundationSuiteK9
securityk9
appxk9
For example with this command
mpls ldp tcp pak-priority it fails on Denali software.
Thanks.
Just to clarify are you saying the configuration file has differences between 16.3.4 and 3.16.5S?
e.g. mpls ldp pak-priority is in your config file and the does not work on 16.3.4.
Or that the PnP process does not work correctly in 16.3.4?
Adam
No, I was using same config with these two versions.
When I was trying to find problem  I started to remove some configuration lines.
Manually pasting this line mpls ldp pak-priority is showing Notice message so I decided to remove it first.
But this line pasted on 3.16.5S showing the same message, but pnp process is not stopping on it.
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
