EasyQos Beta - Does it really works?
Khurram Noor
Folks,
I was testing deployment of easyqos beta of APIC-EM 1.2.0.1594. When i tested it on a 3750x and 2960x, it doesn't completely deploys the QoS. I found some of the class-maps and ACLs empty, plus i couldnt see all 1323 apps being matches in ACLs (many of them are missing, when i applied the policy) I wanted to apply Qos in production but these results have stopped me from proceeding. Has anyone noticed something similar?
-KN
Hi Tim,
That's great explanation in the slide. I wasn't aware of the reasoning.
-KN
8 Replies 8
aradford
Hi Khurram,
did you deploy the default CVD policy?  You would expect that default applications would not be matched.
Tim Szigeti's excellent CiscoLive presentation (BRKRST-2046 SDN QoS Deep Dive) goes into the details of how this works.  Bear in mind the rendering will be different on different platforms due to TCAM resources etc.
Here is a screen shot of one of the main slides.
Thanks Adam (and thanks too for bringing this to my attention).
Yes - this is correct. EasyQoS will always implement an instantiation of the expressed business-intent to the maximum of a given platform's capabilities.
What this means is: you might configure a policy for 1323 applications (our NBAR2 library). However, not all of our platforms support NBAR. As such, rather than doing nothing on, say a Catalyst 3750 access-switch (which does not support NBAR), APIC-EM will parse the NBAR library and sift out all the apps that CAN be classified using L4 ACLs  (incidentally there are only about 200 apps that can be identified via static ACLs), and then constructs and programs these ACLs into the platform, until we hit the TCAM (memory) limits of the box.
In addition to this access-edge policy, which represents the "best that the C3750 can do", EasyQoS will also push out another policy-enforcement-point at the LAN edge of any ASR or ISR router that supports the full NBAR library. At this edge then, apps that were NOT classified at the campus access-edge will ALSO be classified and marked.
(Side Note: As you may know, NBAR has recently been released on the Catalyst 3650 and 3850 platforms; as such, we will be adding this support to EasyQoS in the next few months as well).
As for the ACLs that were not populated by default (i.e. the Voice and Video ACLs), these will be populated by APIC-EM as it discovers Cisco devices via CDP (e.g. IP Phones, Cisco TelePresence Systems, Cisco IP Video Surveillance Cameras and/or Cisco Digital Media Players) AND/OR when APIC-EM receives dynamic QoS requests via the Northbound API from EasyQoS to applications like CallManager and/or MS-Lync, etc.)
More explicit and gory detail (like the slide above) can be found at:
PPT: https://cisco.box.com/v/SDN-QoS
VoD: https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=90876&backBtn=true
So - short summary: yes, EasyQoS *really* works. We've tested the crap out of it ;-)
HTH. Cheers!
-tim
Hi szigeti,
Thanks for your reply, i was helpful to understand more in depth about easy qos. I am attaching the QoS which made me confused here, what i am trying to understand is that what ACL it is refering to ...to match voice and video traffic on a per interface bases policy. I dont see any #DYN_VOICE__acl having any permit statements to match traffic.... how would it identify the voice /video traffic and assign it in the priority queue...this was taken from a 3750x switch.
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos map dscp-mutation REWRITE-DSCP 12 14 16 to 8
mls qos map dscp-mutation REWRITE-DSCP 20 22 24 to 16
mls qos map dscp-mutation REWRITE-DSCP 28 30 32 to 26
mls qos map dscp-mutation REWRITE-DSCP 36 38 40 to 34
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 56
mls qos srr-queue input dscp-map queue 2 threshold 3 32 40 46
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 40 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 26 28 30 34
mls qos srr-queue output dscp-map queue 2 threshold 1 36 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 3 threshold 3 9 11 13 15 17 19 21 23
mls qos srr-queue output dscp-map queue 3 threshold 3 25 27 29 31 33 35 37 39
mls qos srr-queue output dscp-map queue 3 threshold 3 41 42 43 44 45 47 49 50
mls qos srr-queue output dscp-map queue 3 threshold 3 51 52 53 54 55 57 58 59
mls qos srr-queue output dscp-map queue 3 threshold 3 60 61 62 63
mls qos srr-queue output dscp-map queue 4 threshold 1 8 14
mls qos srr-queue output dscp-map queue 4 threshold 2 12
mls qos srr-queue output dscp-map queue 4 threshold 3 10
mls qos queue-set output 1 threshold 1 100 100 100 100
mls qos queue-set output 1 threshold 2 80 90 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 80 100 400
mls qos queue-set output 1 buffers 15 30 35 20
mls qos
class-map match-any prm-DYN-Gig1/0/39#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/39#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/28#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/28#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/38#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/38#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/29#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/29#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/19#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/19#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/18#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/18#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/18#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/18#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/19#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/19#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/38#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/38#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/29#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/29#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/39#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/39#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/28#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/28#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/46#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/46#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/20#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/20#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/31#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/31#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/13#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/13#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/41#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/41#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/27#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/27#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/14#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/14#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/36#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/36#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/37#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/37#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/15#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/15#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/26#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/26#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/30#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/30#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/47#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/47#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/12#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/12#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/40#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/40#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/21#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/21#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/25#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/25#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/11#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/11#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/34#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/34#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/16#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/16#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/22#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/22#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/44#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/44#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/33#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/33#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/43#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/43#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/42#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/42#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/23#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/23#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/10#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/10#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/45#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/45#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/24#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/24#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/35#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/35#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/32#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/32#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/17#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/17#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/42#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/42#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/23#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/23#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/10#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/10#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/45#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/45#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/24#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/24#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/35#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/35#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/32#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/32#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/17#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/17#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/25#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/25#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/11#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/11#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/34#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/34#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/16#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/16#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/22#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/22#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/44#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/44#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/33#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/33#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/43#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/43#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/37#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/37#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/15#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/15#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/26#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/26#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/30#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/30#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/47#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/47#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/12#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/12#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/40#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/40#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/21#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/21#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/46#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/46#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/20#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/20#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/31#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/31#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/13#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/13#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/41#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/41#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/27#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/27#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/14#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/14#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/36#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/36#DYN_VIDEO__acl
class-map match-any prm-APIC_QOS_IN#TRANS_DATA
  match access-group name prm-APIC_QOS_IN#TRANS_DATA__acl
class-map match-any prm-DYN-Ten1/1/2#DYN_VOICE
  match access-group name prm-DYN-Ten1/1/2#DYN_VOICE__acl
class-map match-any prm-DYN-Ten1/1/1#DYN_VOICE
  match access-group name prm-DYN-Ten1/1/1#DYN_VOICE__acl
class-map match-any prm-DYN-Ten1/1/1#DYN_VIDEO
  match access-group name prm-DYN-Ten1/1/1#DYN_VIDEO__acl
class-map match-any prm-DYN-Ten1/1/2#DYN_VIDEO
  match access-group name prm-DYN-Ten1/1/2#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/8#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/8#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/9#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/9#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/9#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/9#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/8#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/8#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/1/4#DYN_VOICE
  match access-group name prm-DYN-Gig1/1/4#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/2#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/2#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/1/3#DYN_VIDEO
  match access-group name prm-DYN-Gig1/1/3#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/5#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/5#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/3#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/3#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/1/2#DYN_VIDEO
  match access-group name prm-DYN-Gig1/1/2#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/4#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/4#DYN_VOICE__acl
class-map match-any prm-APIC_QOS_IN#TUNNELED
  match access-group name prm-APIC_QOS_IN#TUNNELED__acl
class-map match-any prm-DYN-Gig1/1/1#DYN_VIDEO
  match access-group name prm-DYN-Gig1/1/1#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/7#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/7#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/6#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/6#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/1#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/1#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/6#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/6#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/1#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/1#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/1/1#DYN_VOICE
  match access-group name prm-DYN-Gig1/1/1#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/7#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/7#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/3#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/3#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/1/2#DYN_VOICE
  match access-group name prm-DYN-Gig1/1/2#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/4#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/4#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/1/4#DYN_VIDEO
  match access-group name prm-DYN-Gig1/1/4#DYN_VIDEO__acl
class-map match-any prm-DYN-Gig1/0/2#DYN_VOICE
  match access-group name prm-DYN-Gig1/0/2#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/1/3#DYN_VOICE
  match access-group name prm-DYN-Gig1/1/3#DYN_VOICE__acl
class-map match-any prm-DYN-Gig1/0/5#DYN_VIDEO
  match access-group name prm-DYN-Gig1/0/5#DYN_VIDEO__acl
class-map match-any prm-APIC_QOS_IN#REALTIME
class-map match-any prm-DYN-Gig1/0/37#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/15#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/26#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/40#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/41#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/27#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/14#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/36#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/42#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/24#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/35#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/17#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/25#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/34#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/16#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/43#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/11#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/22#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/44#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/33#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/23#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/10#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/45#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/32#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/46#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/20#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/31#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/13#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/30#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/47#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/12#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/21#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/19#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/18#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/39#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/28#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/38#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/29#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/4#DYN_REALTIME
class-map match-any prm-DYN-Gig1/1/4#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/5#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/6#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/7#DYN_REALTIME
class-map match-any prm-DYN-Gig1/1/1#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/1#DYN_REALTIME
class-map match-any prm-DYN-Gig1/0/2#DYN_REALTIME
class-map match-any prm-DYN-Gig1/1/3#DYN_REALTIME
class-map match-any prm-APIC_QOS_IN#VOICE
class-map match-any prm-DYN-Gig1/0/3#DYN_REALTIME
class-map match-any prm-DYN-Gig1/1/2#DYN_REALTIME
class-map match-any prm-APIC_QOS_IN#MM_CONF
  match access-group name prm-APIC_QOS_IN#MM_CONF__acl
class-map match-any prm-DYN-Gig1/0/8#DYN_REALTIME
class-map match-any prm-APIC_QOS_IN#SCAVENGER
  match access-group name prm-APIC_QOS_IN#SCAVENGER__acl
class-map match-any prm-DYN-Gig1/0/9#DYN_REALTIME
class-map match-any prm-APIC_QOS_IN#SIGNALING
  match access-group name prm-APIC_QOS_IN#SIGNALING__acl
class-map match-any prm-APIC_QOS_IN#BROADCAST
  match access-group name prm-APIC_QOS_IN#BROADCAST__acl
class-map match-any prm-APIC_QOS_IN#BULK_DATA
  match access-group name prm-APIC_QOS_IN#BULK_DATA__acl
class-map match-any prm-DYN-Ten1/1/2#DYN_REALTIME
class-map match-any prm-DYN-Ten1/1/1#DYN_REALTIME
class-map match-any prm-APIC_QOS_IN#MM_STREAM
  match access-group name prm-APIC_QOS_IN#MM_STREAM__acl
class-map match-any prm-APIC_QOS_IN#OAM
  match access-group name prm-APIC_QOS_IN#OAM__acl
policy-map prm-DYN-Gig1/0/41
class prm-DYN-Gig1/0/41#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/41#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/41#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/40
class prm-DYN-Gig1/0/40#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/40#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/40#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/43
class prm-DYN-Gig1/0/43#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/43#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/43#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/42
class prm-DYN-Gig1/0/42#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/42#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/42#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/45
class prm-DYN-Gig1/0/45#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/45#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/45#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/44
class prm-DYN-Gig1/0/44#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/44#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/44#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/47
class prm-DYN-Gig1/0/47#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/47#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/47#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/46
class prm-DYN-Gig1/0/46#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/46#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/46#DYN_VIDEO
   set dscp af41
policy-map prm-APIC_QOS_IN
class prm-APIC_QOS_IN#VOICE
   set dscp ef
class prm-APIC_QOS_IN#BROADCAST
   set dscp cs5
class prm-APIC_QOS_IN#REALTIME
   set dscp cs4
class prm-APIC_QOS_IN#MM_CONF
   set dscp af41
class prm-APIC_QOS_IN#MM_STREAM
   set dscp af31
class prm-APIC_QOS_IN#SIGNALING
   set dscp cs3
class prm-APIC_QOS_IN#OAM
   set dscp cs2
class prm-APIC_QOS_IN#TRANS_DATA
   set dscp af21
class prm-APIC_QOS_IN#BULK_DATA
   set dscp af11
class prm-APIC_QOS_IN#SCAVENGER
   set dscp cs1
class prm-APIC_QOS_IN#TUNNELED
class class-default
   set dscp default
policy-map prm-DYN-Gig1/0/29
class prm-DYN-Gig1/0/29#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/29#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/29#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/28
class prm-DYN-Gig1/0/28#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/28#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/28#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/27
class prm-DYN-Gig1/0/27#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/27#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/27#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/26
class prm-DYN-Gig1/0/26#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/26#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/26#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/25
class prm-DYN-Gig1/0/25#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/25#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/25#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/24
class prm-DYN-Gig1/0/24#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/24#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/24#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/23
class prm-DYN-Gig1/0/23#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/23#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/23#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/22
class prm-DYN-Gig1/0/22#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/22#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/22#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/21
class prm-DYN-Gig1/0/21#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/21#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/21#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/20
class prm-DYN-Gig1/0/20#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/20#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/20#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/7
class prm-DYN-Gig1/0/7#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/7#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/7#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/6
class prm-DYN-Gig1/0/6#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/6#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/6#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/5
class prm-DYN-Gig1/0/5#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/5#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/5#DYN_VIDEO
   set dscp af41
class prm-DYN-Gig1/0/4#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/4#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/4#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/3
class prm-DYN-Gig1/0/3#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/3#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/3#DYN_VIDEO
   set dscp af41
class prm-DYN-Gig1/0/2#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/2#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/2#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/1
class prm-DYN-Gig1/0/1#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/1#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/1#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/9
class prm-DYN-Gig1/0/9#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/9#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/9#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/8
class prm-DYN-Gig1/0/8#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/8#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/8#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/1/4
class prm-DYN-Gig1/1/4#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/1/4#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/1/4#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/1/2
class prm-DYN-Gig1/1/2#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/1/2#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/1/2#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/1/3
class prm-DYN-Gig1/1/3#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/1/3#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/1/3#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/1/1
class prm-DYN-Gig1/1/1#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/1/1#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/1/1#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/12
class prm-DYN-Gig1/0/12#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/12#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/12#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/13
class prm-DYN-Gig1/0/13#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/13#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/13#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/10
class prm-DYN-Gig1/0/10#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/10#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/10#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/11
class prm-DYN-Gig1/0/11#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/11#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/11#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/16
class prm-DYN-Gig1/0/16#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/16#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/16#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/17
class prm-DYN-Gig1/0/17#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/17#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/17#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/14
class prm-DYN-Gig1/0/14#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/14#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/14#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/15
class prm-DYN-Gig1/0/15#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/15#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/15#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/18
class prm-DYN-Gig1/0/18#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/18#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/18#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/19
class prm-DYN-Gig1/0/19#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/19#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/19#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Ten1/1/1
class prm-DYN-Ten1/1/1#DYN_VOICE
   set dscp ef
class prm-DYN-Ten1/1/1#DYN_REALTIME
   set dscp cs4
class prm-DYN-Ten1/1/1#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Ten1/1/2
class prm-DYN-Ten1/1/2#DYN_VOICE
   set dscp ef
class prm-DYN-Ten1/1/2#DYN_REALTIME
   set dscp cs4
class prm-DYN-Ten1/1/2#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/38
class prm-DYN-Gig1/0/38#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/38#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/38#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/39
class prm-DYN-Gig1/0/39#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/39#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/39#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/34
class prm-DYN-Gig1/0/34#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/34#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/34#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/35
class prm-DYN-Gig1/0/35#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/35#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/35#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/36
class prm-DYN-Gig1/0/36#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/36#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/36#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/37
class prm-DYN-Gig1/0/37#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/37#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/37#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/30
class prm-DYN-Gig1/0/30#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/30#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/30#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/31
class prm-DYN-Gig1/0/31#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/31#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/31#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/32
class prm-DYN-Gig1/0/32#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/32#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/32#DYN_VIDEO
   set dscp af41
policy-map prm-DYN-Gig1/0/33
class prm-DYN-Gig1/0/33#DYN_VOICE
   set dscp ef
class prm-DYN-Gig1/0/33#DYN_REALTIME
   set dscp cs4
class prm-DYN-Gig1/0/33#DYN_VIDEO
   set dscp af41
ip access-list extended prm-APIC_QOS_IN#BROADCAST__acl
remark dmp
permit tcp any any eq 7777
ip access-list extended prm-APIC_QOS_IN#BULK_DATA__acl
remark pop3
permit tcp any any eq pop3
remark nsiiops
permit tcp any any eq 261
permit udp any any eq 261
remark smtp
permit tcp any any eq smtp
permit tcp any any eq 587
permit udp any any eq 25
remark microsoftds
permit tcp any any eq 445
permit udp any any eq 445
remark lotus-notes
permit tcp any any eq 1352
permit udp any any eq 1352
remark gridftp
permit tcp any any eq 2811
remark synergy
permit tcp any any eq 24800
remark secure-smtp
permit tcp any any eq 465
permit udp any any eq 465
remark rsync
permit tcp any any eq 873
permit udp any any eq 873
remark corba-iiop-ssl
permit tcp any any eq 684
permit udp any any eq 684
remark msexch-routing
permit tcp any any eq 691
permit udp any any eq 691
remark secure-imap
permit tcp any any eq 993
permit udp any any eq 993
remark mcafee-update
permit tcp any any eq 8801
remark gsiftp
permit udp any any eq 2811
remark ftp
permit tcp any any eq ftp
permit tcp any any eq 21000
remark imap
permit tcp any any eq 143
permit tcp any any eq 220
permit udp any any eq 143
permit udp any any eq 220
remark capwap-data
permit udp any any eq 5246
permit udp any any eq 5247
remark iscsi
permit tcp any any eq 860
permit udp any any eq 860
permit udp any any eq 3260
remark sftp
permit tcp any any eq 115
permit udp any any eq 115
remark ms-sms
permit tcp any any eq 2701
permit tcp any any eq 2702
permit tcp any any eq 2703
permit tcp any any eq 2704
remark secure-pop3
permit tcp any any eq 995
permit udp any any eq 995
remark nfs
permit tcp any any eq sunrpc
permit tcp any any eq 371
permit tcp any any eq 2049
permit udp any any eq sunrpc
permit udp any any eq 371
permit udp any any eq 2049
remark ftp-data
permit tcp any any eq ftp-data
ip access-list extended prm-APIC_QOS_IN#MM_CONF__acl
remark apple-remote-desktop
permit tcp any any eq 3283
permit udp any any eq 3283
remark timbuktu
permit tcp any any eq 407
permit udp any any eq 407
remark webex-app-sharing
permit udp any any eq 9000
remark xwindows
permit tcp any any eq 6000
permit tcp any any eq 6001
permit tcp any any eq 6002
permit tcp any any eq 6003
remark citrix
permit tcp any any eq 1494
permit tcp any any eq 2598
remark gotodevice
permit tcp any any eq 2217
permit udp any any eq 2217
remark pcoip
permit tcp any any eq 4172
remark skype
permit tcp any any eq 33033
remark radmin-port
permit tcp any any eq 4899
permit udp any any eq 4899
remark citrix-static
permit tcp any any eq 1604
permit tcp any any eq 2512
permit tcp any any eq 2513
permit udp any any eq 1604
permit udp any any eq 2512
permit udp any any eq 2513
remark ms-wbt
permit tcp any any eq 3389
remark pcanywhere
permit tcp any any eq 5631
permit tcp any any eq 65301
permit udp any any eq 5632
ip access-list extended prm-APIC_QOS_IN#MM_STREAM__acl
remark vmware-vmotion
permit tcp any any eq 8000
remark shockwave
permit tcp any any eq 1626
permit udp any any eq 1626
remark vnc
permit tcp any any eq 5800
permit tcp any any eq 5900
permit tcp any any eq 5901
permit udp any any eq 5800
permit udp any any eq 5900
permit udp any any eq 5901
ip access-list extended prm-APIC_QOS_IN#OAM__acl
remark syslog
permit udp any any eq syslog
remark active-directory
permit tcp any any eq 389
permit udp any any eq 389
remark at-nbp
permit tcp any any eq 202
permit udp any any eq 202
remark kerberos
permit udp any any eq 88
remark secure-ldap
permit tcp any any eq 636
permit udp any any eq 636
remark cisco-fna
permit tcp any any eq 130
permit udp any any eq 130
remark login
permit tcp any any eq login
remark dhcpv6-server
permit tcp any any eq 547
permit udp any any eq 547
remark cisco-sys
permit tcp any any eq 132
permit udp any any eq 132
remark dhcp-failover2
permit tcp any any eq 847
permit udp any any eq 847
remark finger
permit tcp any any eq finger
permit udp any any eq 79
remark ssh
remark exec
permit tcp any any eq exec
remark telnet
permit tcp any any eq telnet
remark ntp
permit udp any any eq ntp
remark rsvp-encap-1
permit tcp any any eq 1698
permit udp any any eq 1698
remark shell
permit tcp any any eq cmd
remark dhcp
permit udp any any eq bootps
permit udp any any eq bootpc
remark tacacs
permit tcp any any eq tacacs
permit udp any any eq tacacs
permit udp any any eq 65
remark echo
permit tcp any any eq echo
permit udp any any eq echo
remark msft-gc-ssl
permit tcp any any eq 3269
permit udp any any eq 3269
remark dhcpv6-client
permit tcp any any eq 546
permit udp any any eq 546
remark rsvp-encap-2
permit tcp any any eq 1699
permit udp any any eq 1699
remark snmp
permit tcp any any eq 161
permit tcp any any eq 1161
permit tcp any any eq 1162
permit udp any any eq snmp
permit udp any any eq snmptrap
remark tftp
permit udp any any eq tftp
remark cisco-tna
permit tcp any any eq 131
permit udp any any eq 131
remark radius
permit udp any any eq 1812
permit udp any any eq 1813
permit tcp any any eq 647
permit udp any any eq 647
remark aruba-papi
permit udp any any eq 8211
ip access-list extended prm-APIC_QOS_IN#SCAVENGER__acl
remark bittorrent
permit tcp any any eq 3544
permit tcp any any eq 6881
permit tcp any any eq 6882
permit tcp any any eq 6883
permit tcp any any eq 6884
permit tcp any any eq 6885
permit tcp any any eq 6886
permit tcp any any eq 6887
permit tcp any any eq 6888
permit tcp any any eq 6889
permit udp any any eq 3544
permit udp any any eq 3545
remark yahoo-messenger
permit tcp any any eq 5050
permit tcp any any eq 5101
remark nntp
permit tcp any any eq nntp
remark netshow
permit tcp any any eq 1755
remark edonkey
permit tcp any any eq 4662
remark edonkey-static
permit tcp any any eq 4661
permit tcp any any eq 4663
permit tcp any any eq 4664
permit tcp any any eq 4665
permit tcp any any eq 4672
permit tcp any any eq 4673
permit tcp any any eq 4711
permit tcp any any eq 5662
permit tcp any any eq 5773
permit tcp any any eq 5783
permit udp any any eq 4661
permit udp any any eq 4662
permit udp any any eq 4663
permit udp any any eq 4664
permit udp any any eq 4665
permit udp any any eq 4672
permit udp any any eq 4673
permit udp any any eq 4711
permit udp any any eq 5662
permit udp any any eq 5773
permit udp any any eq 5783
ip access-list extended prm-APIC_QOS_IN#SIGNALING__acl
remark snpp
permit tcp any any eq 444
permit udp any any eq 444
remark dnp
permit tcp any any eq 19999
permit tcp any any eq 20000
permit udp any any eq 19999
permit udp any any eq 20000
remark prm-nm
permit tcp any any eq 409
permit udp any any eq 409
remark rsvp_tunnel
permit tcp any any eq 363
permit udp any any eq 363
remark spsc
permit tcp any any eq 478
permit udp any any eq 478
remark ups
permit tcp any any eq 401
permit udp any any eq 401
remark tpip
permit tcp any any eq 594
permit udp any any eq 594
remark svrloc
permit tcp any any eq 427
permit udp any any eq 427
remark netvmg-traceroute
permit udp any any eq 33435
remark skinny
permit tcp any any eq 2001
permit tcp any any eq 2002
remark sflow
permit tcp any any eq 6343
permit udp any any eq 6343
remark prm-sm
permit tcp any any eq 408
permit udp any any eq 408
remark sgcp
permit tcp any any eq 440
permit udp any any eq 440
remark rtsp
permit tcp any any eq 554
permit tcp any any eq 8554
remark sip-tls
permit tcp any any eq 5061
permit udp any any eq 5061
remark mgcp
permit tcp any any eq 2427
permit tcp any any eq 2428
permit tcp any any eq 2727
permit udp any any eq 2427
permit udp any any eq 2727
remark rpc2portmap
permit tcp any any eq 369
permit udp any any eq 369
remark sip
permit tcp any any eq 3478
permit udp any any eq 3478
remark ss7ns
permit tcp any any eq 477
permit udp any any eq 477
remark rtsps
permit tcp any any eq 322
permit udp any any eq 322
remark h323
permit tcp any any eq 1300
permit tcp any any eq 1718
permit tcp any any eq 1719
permit tcp any any eq 1720
permit tcp any any eq 11720
permit udp any any eq 1300
permit udp any any eq 1718
permit udp any any eq 1719
permit udp any any eq 1720
permit udp any any eq 11720
remark datex-asn
permit tcp any any eq 355
permit udp any any eq 355
remark cisco-jabber-control
permit tcp any any eq 5060
permit udp any any eq 5060
ip access-list extended prm-APIC_QOS_IN#TRANS_DATA__acl
remark ssl
permit tcp any any eq 5222
permit udp any any eq 5222
remark sqlsrv
permit tcp any any eq 156
permit udp any any eq 156
remark sqlserv
permit tcp any any eq 118
permit udp any any eq 118
remark ddm-rdb
permit tcp any any eq 446
permit udp any any eq 446
remark sqlserver
permit tcp any any eq 1433
permit udp any any eq 1433
remark ms-sql-m
permit tcp any any eq 1434
permit udp any any eq 1434
remark ms-iis
remark epmap
remark distcc
permit tcp any any eq 3632
permit udp any any eq 3632
remark orbix-cfg-ssl
permit tcp any any eq 3078
permit udp any any eq 3078
remark orbix-loc-ssl
permit tcp any any eq 3077
permit udp any any eq 3077
remark corba-iiop
permit tcp any any eq 683
permit udp any any eq 683
remark ddm-ssl
permit tcp any any eq 448
permit udp any any eq 448
remark dbase
permit tcp any any eq 217
permit udp any any eq 217
remark coauthor
permit tcp any any eq 1529
permit udp any any eq 1529
remark iiop
permit tcp any any eq 535
permit udp any any eq 535
remark sap
permit tcp any any eq 3200
permit tcp any any eq 3300
permit tcp any any eq 3600
remark erpc
permit tcp any any eq 121
permit udp any any eq 121
remark esro-gen
permit udp any any eq 259
remark banyan-rpc
permit tcp any any eq 567
permit udp any any eq 567
remark ddm-dfm
permit tcp any any eq 447
permit udp any any eq 447
remark oracle-sqlnet
permit tcp any any eq 66
remark gds_db
permit tcp any any eq 3050
permit udp any any eq 3050
remark ibm-db2
permit tcp any any eq 523
permit udp any any eq 523
ip access-list extended prm-APIC_QOS_IN#TUNNELED__acl
remark capwap-data
ip access-list extended prm-DYN-Gig1/0/1#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/1#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/10#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/10#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/11#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/11#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/12#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/12#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/13#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/13#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/14#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/14#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/15#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/15#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/16#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/16#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/17#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/17#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/18#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/18#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/19#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/19#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/2#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/2#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/20#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/20#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/21#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/21#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/22#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/22#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/23#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/23#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/24#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/24#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/25#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/25#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/26#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/26#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/27#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/27#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/28#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/28#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/29#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/29#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/3#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/3#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/30#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/30#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/31#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/31#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/32#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/32#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/33#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/33#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/34#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/34#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/35#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/35#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/36#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/36#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/37#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/37#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/38#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/38#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/39#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/39#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/4#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/4#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/40#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/40#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/41#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/41#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/42#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/42#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/43#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/43#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/44#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/44#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/45#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/45#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/46#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/46#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/47#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/47#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/5#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/5#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/6#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/6#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/7#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/7#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/8#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/8#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/0/9#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/0/9#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/1/1#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/1/1#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/1/2#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/1/2#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/1/3#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/1/3#DYN_VOICE__acl
ip access-list extended prm-DYN-Gig1/1/4#DYN_VIDEO__acl
ip access-list extended prm-DYN-Gig1/1/4#DYN_VOICE__acl
ip access-list extended prm-DYN-Ten1/1/1#DYN_VIDEO__acl
ip access-list extended prm-DYN-Ten1/1/1#DYN_VOICE__acl
ip access-list extended prm-DYN-Ten1/1/2#DYN_VIDEO__acl
ip access-list extended prm-DYN-Ten1/1/2#DYN_VOICE__acl
interface GigabitEthernet1/0/1
srr-queue bandwidth share 1 30 35 5
priority-queue out
service-policy input prm-APIC_QOS_IN
Hi Khurram,
Short answer: the dynamic QoS Northbound API (from CUCM or from MS-Lync server) will supply the IP and UDP port information for the voice/video calls. Only at that time will EasyQoS dynamically program the ACEs (i.e. the "permit udp IP Port statements). The reason for the policy-shells (i.e. the empty ACLs, class-maps and policy-maps) in your config is to optimize performance and to ensure that QoS is applied in a non-disruptive manner.
For additional details see:
Slides 138 through 144 and
Appendix D: Dynamic QoS (Slides 272 through 285).
HTH.
-tim
Hi Tim,
-KN
Will add one additional comment....
Dynamic Shells are only added if you turn on Dynamic QoS. It is an optional feature, which is still in beta, and Static QoS , which has just been released as GA in 1.3, does not require these dynamic shells to work properly.
Ramit
Hi aradford,
I did not deploy the default CVD QoS. But i made some adjustment which makes sense to the business. I have gone through the presentation and it looks pretty nice.
-KN
Thanks KN.
we are about to release  1.3 which has a number of EQ enhancements.
should be out in next day or so.
Adam
