Error Health Check Timer Expired
mjbeckett
We are in the process of setting up APIC-EM and are testing the PnP feature. Currently I have a c2960+24tc-l running 15.2(2)E setup on the test bench plugged into a DHCP port. After boot is reaches APIC-EM and is listed as an "unclaimed" device". When I try to claim it and push a new IOS image to it the following error occurs:
Hi Marcus,
Can you also verify the time it takes to download the image to the 2960x.  Are you doing this over the WAN or a LAN connection.
i think you need to be running 15.2(2)E3 as that is the first version that is supported.  can you try with that image?
Adam
11 Replies 11
aradford
Hi Marcus,
do you have "aaa command authorisation" in your configuration?
Adam
At this current test i'm not pushing a config just the IOS image
ok.  Is it 12.2(2)E3 that you are running?  12.2(2)E3 is the min supported version in the release notes.
which version are you upgrading to?
The switch is currently running 15.2(2)E and we are deploying 15.2(2)E3
It could happen due to slow connection as well, if image download to device takes a longer time
It's on the LAN connection with no firewalls between them. It errors before it downloads the image and there are no progress notifications. No part of the image shows up on the 2960. If I manually tftp the image from our tftp server it takes about 1-2 minutes.
Hi Marcus,
Adam
I manually installed 15.2(2)E3 and then had APIC-EM push 15.2(2)E5. This succeeded. So this must be a version issue. Might have to try the image push via prime then.
the minimum version of code is 15.2.2(e3) according to the release notes.
That will be the first officially supported version of code.
Hi Adam,
Do you know if the IOS version 15.2(5)E is supported? I can't find anything in the release notes.
it will be.  15.2(2)E3 is min version.  15.2(5) will not mention PnP as it will have been added in earlier releases.  Need to get 15.2(5) added.
