05-02-2017 11:55 PM - edited 03-01-2019 04:37 AM
Hi everyone,
After successfully provisioning a new switch from APIC-EM, I see in the switch logs that there is a lot of error messages "error opening tftp://..", and wonder if this is common, and if so, is there any way to remove it? Is it related to the PnP profile?
I guess these errors are no big deal, but it would been nice to avoid them.
May 3 2017 08:30:30.363 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
%Error opening tftp://255.255.255.255/switch-confg (Timed out)
May 3 2017 08:31:05.498 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch-confg) failed
%Error opening tftp://255.255.255.255/switch.cfg (Timed out)
May 3 2017 08:31:29.588 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch.cfg) failed
%Error opening tftp://255.255.255.255/network-confg (Timed out)
May 3 2017 08:40:54.499 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
May 3 2017 08:41:18.578 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
%Error opening tftp://255.255.255.255/switchconfg (Timed out)
May 3 2017 08:41:53.727 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch-confg) failed
May 3 2017 08:42:17.828 CEST: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/switch.cfg) failed
Solved! Go to Solution.
05-03-2017 12:31 AM
it is harmless, but annoying. The reason it is there is due to the autoboot process. If there is no configuration file, the device will try to TFTP one from the local network.
You can disable it with the
"no service config
command. You can put this in your pnp configuration file.
Adam
05-03-2017 12:31 AM
"no service config
Adam
05-03-2017 03:05 AM
Works like a charm, thanks alot!
05-03-2017 04:22 PM
glad we were able to resolve it quickly.
Adam
11-16-2019 04:39 PM
Thanks that was annoying...!
04-18-2022 05:20 AM
Hello
i have the same issue but a have not the hand to enter command
08-04-2022 09:26 AM
I have same problem in catalyst 2960 24 poe
but have not hand to write command
11-03-2023 02:15 AM
Thanks for. It was helpful for me on Switch C1000-24P-4G-L.
09-05-2023 08:48 PM
Switch Ports Model SW Version SW Image
* 1 28 C1000FE-24T-4G-L 15.2(7)E4 C1000-UNIVERSALK9-M
Configuration register is 0xF
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
