Guestshell open file on flash with Python
nathy1984
Hello
How can I open a file on flash from Guestshell with Python?
Thanks.
5 Replies 5
ngkin2010
Level 7
Level 7
As I remember, the absolute path of flash drive is '/flash' in guestshell. Make sure you got at least 'read' file permission, and you could open the file by Python.
fd = open('/flash/filename','r')
It should be '/bootflash' instead of '/flash' as mentioned by @omz
omz
file = open('/bootflash/test.txt','r')
print file.read()
file.close()
OR
with open('/bootflash/test.txt','r') as file: print file.read()
Thank you for the reply.
That works. Flash or Bootflash depends on the device type.
Please dont forget to rate helpful posts and accept solutions so the post is helpful for other users.
Thank you
