02-08-2021 01:26 PM
Is it possible using the ansible aci modules to login once and get the token and pass the cookie on subsequent aci_rest tasks?
The goal is to avoid having to login and logoff with userid/password on aci_rest calls that have loops.
Is this possible?
02-09-2021 08:59 AM - edited 02-09-2021 09:00 AM
Hello @sarlindo1 ,
This discussion Not able to access APIC REST APIs with web token , particularly the final post at the very bottom, may be of help.
Also, here are the Ansible Docs - cisco.aci.aci_rest – Direct access to the Cisco APIC REST API
02-09-2021 07:51 PM
Hi Alex,
That the discussion "Not able to access APIC REST APIs with web token" was sort of helpful. So basically in order to use web token, I need to resort to using the raw "uri" ansible module, so what is the point of the aci_rest module?
Also, as stated my goal is to avoid having to login and logoff with userid/password on aci_rest calls that have loops. Would using private keys in the aci_rest module achieve that goal?
02-09-2021 10:09 PM
Hi @sarlindo1
Yes, what you are looking for is the signature based authentication. This way you do not use the user/pass credentials for login and you will not be restricted by the default ACI rate limiters for user logins.
Stay safe,
Sergiu
