942
jawicks
Listing configID
I create a new device under a given project via an API post to "/pnp-project/{projectId}/device" and I also need to specifiy the JSON format config-template which goes with that device for PnP.
The API documentation states that I should specifiy "configId (string, optional)" when creating the device but I cannot see where to query APIC to optain a valid "configId" which matches the JSON-config-template file I have pre-defined under "Network Plug and Play" --> "Configurations".
What do I need to query to list all the JSON-config-template files and their corresponding configID's ??
Thanks.
1 ACCEPTED SOLUTION
Joe Clarke
Hall of Fame Cisco Employee
I'll admit this isn't very intuitive.  But you can use the fileservice to get the file ID.  Try:
GET https://apic-em/api/v1/file/namespace/config
3 REPLIES 3
Joe Clarke
Brilliant, I think that looks like the right one (I'll just need to test that "id" works for my example), many thanks for the replies.
yawming
There is a configId form /pnp-device
GET /pnp-device
configId (string, optional): Configuration file ID,
Create
Recognize Your Peers
Content for Community-Ad
