10-01-2021 12:53 PM - edited 10-01-2021 02:08 PM
I am creating a script using nornir_scrapli (netconf_edit_config) to replace some NTP config for a CSR1000v running 17.03.03, however I am getting the following error when running the script:
* CSR-17-3-3 ** changed : True ************************************************* vvvv load_vars_ios ** changed : False vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv ERROR Subtask: netconf_edit_config (failed) ---- load_yaml ** changed : False ---------------------------------------------- INFO { 'ios': { 'ntp': { 'servers': { 'ntp_server_1': '1.1.1.1', 'ntp_server_2': '3.3.3.3', 'ntp_server_3': '5.5.5.5'}}}, 'ios_xr': { 'ntp': { 'servers': { 'ntp_server_1': '2.2.2.2', 'ntp_server_2': '4.4.4.4', 'ntp_server_3': '6.6.6.6'}}}} ---- Building NTP Configuration ** changed : False ----------------------------- INFO <config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0""> <native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native"> <ntp operation="replace"> <authentication-key xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-ntp"> <number>4</number> <md5-cfg>05080F1C22431F5B4A</md5-cfg> <md5>05080F1C22431F5B4A</md5> <encryption-type>7</encryption-type> </authentication-key> <server xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-ntp"> <server-list> <ip-address>1.1.1.1</ip-address> </server-list> <server-list> <ip-address>3.3.3.3</ip-address> </server-list> <server-list> <ip-address>5.5.5.5</ip-address> <prefer/> </server-list> </server> <trusted-key xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-ntp"> <number>4</number> </trusted-key> </ntp> </native> </config> ---- netconf_edit_config ** changed : True ------------------------------------- ERROR <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"> <rpc-error> <error-type>rpc</error-type> <error-tag>unknown-element</error-tag> <error-severity>error</error-severity> <error-info> <bad-element>native</bad-element> </error-info> </rpc-error> </rpc-reply> ^^^^ END load_vars_ios ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
What's weird is that the XML formatted config shown above is exactly the same as another script where I use ncclient instead of nornir_scrapli and it works without issues.
Does anyone have any ideas why I'm getting "<bad-element>native</bad-element>" when using nornir_scrapli but not with ncclient?
10-01-2021 02:42 PM
Just a quick update, I had both "netconf ssh" and "netconf-yang" configured on this device. After removing "netconf-ssh" everything started working as expected.
