04-12-2017 06:21 AM - edited 03-01-2019 04:37 AM
We had the hub sites deployed but wanted to change some stuff but you can't after you create them
So we rebuilt it now we can't get the PKI to work anymore.
Does anyone have a solution for this?
04-12-2017 04:34 PM
You say you rebuilt them as opposed to redeploying them?
04-12-2017 05:06 PM
Yes, we wiped out the configs rebuilt it and tried to redeploy them.
04-12-2017 05:09 PM
did you redeploy the spokes as well?
04-12-2017 05:25 PM
We don't have any spokes yet
04-12-2017 05:28 PM
that is strange. Did you delete the hub from APIC before the reprovisioning?
Worst case, if you wanted to start again, you could just "reset_grapevine" and say "Y" to the destroy disk question. That would reset your controller completely and you could redeploy fresh. You should not need to do this?
Are you sure it is not a licensing issue? Do you have the correct licences on the HUB devices when you rebuilt them?
