09-22-2016 01:22 PM - edited 03-01-2019 04:31 AM
My testing for PnP with APIC-EM works great through a Ethernet uplink, but when using an SFP Multimode Fiber Uplink I'm not seeing anything link up. Is this a feature not quite set up yet with the PnP Agent?
Here is my DHCP Option 43 configuration on the router it's uplinking to.
ip dhcp pool APICPnP
network 10.2.222.0 255.255.255.248
default-router 10.2.222.1
option 43 ascii "5A1N;B2;K4;I10.100.4.38;J80"
The switch has been factory defaulted:
==============Website screen output========================
configure terminal
crypto key zeroize
no crypto pki certificate pool
no pnp profile pnp-zero-touch
end
delete nvram:*.cer
delete stby-nvram:*.cer (if the device has stack members)
write erase
reload
====================End of output======================
Any information would be much appreciated.
10-09-2016 09:11 PM
what model switch are you using and which version of code?
Adam
10-10-2016 06:04 AM
Version: IOS 15.2
Model: Switch 3750-X
10-10-2016 05:15 PM
sorry to keep drilling down on this, but is it 15.2(2)E3 or later?
10-11-2016 07:44 AM
No problem at all, yes it is.
10-11-2016 09:28 PM
Hi, I am having problem as well with pnp on 3750x with 15.2.(4)E2, pnp doesnt start working...i have already posted a question for it.
-KN
10-11-2016 09:41 PM
Hi Khurram,
Did you had chance to refer page 35 (Troubleshooting) of this url - http://www.cisco.com/c/dam/assets/global/DK/seminarer/pdfs/EN_SDN_APIC_EM_PNP_APP.pdf and confirm the PnP Server on the APIC-EM is reachable and can be authenticated using the credentials provided in settings. If all is fine can you check the logs.
Thanks and Regards,
Geevarghese
10-12-2016 06:04 AM
Yes, the server is reachable. I've performed this procedure twice through Ethernet on the same switch, but when uplinking with Fiber ports with SFP's it won't work.
10-17-2016 02:25 AM
can you give me the exact fibre interface you are using. I want to get engineering to test and reproduce this.
A "show interface" of the interface in question should do.
Adam
10-19-2016 07:55 AM
Currently we do not have it active at the moment. If you need an active port connected to the PnP switch...let me know, I can get it back online when able.
This port is set up as a trunk only.
TenGigabitEthernet5/8 is down, line protocol is down (inactive)
Hardware is Ten Gigabit Ethernet Port, address is f44e.052d.51c7 (bia f44e.052d.51c7)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
10-18-2016 08:00 PM
Thanks .... it started to work after a couple of switch reloads. Also i put the pnp profile manually. but later on i tried DHCP way and it worked.
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
