PnP not deploying complete switch configuration
Joakim Backlund
I need some advice or assistance to get PnP to deploy a complete switch stack configuration at the same times as I do a image upgrade.
I'm struggling getting the APIC-EM PnP to work as expected deploying the complete switch (WS-C3650-48PD) configuration. I've pre-provisioned switches to upgrade image to IOS-XE 16.3.3 and deploy a switch stack configuration where only the image is upgraded and the first half of the configuration is deployed. The odd thing is that PnP seems to think it is a success and says status Provisioned.
When I deploy the same configuration via CLI or do a new provision of the same switch stack but without image upgrade the complete configuration goes through without any errors so I assume the configuration is correct. I see no timeouts and we use 40 minutes timeout for image upgrade and 30 minutes for configuration deployment.
I have the same behavior on all switch stacks that the configuration deployment only deploy the interface configuration for the first two switches in the stack.
The interface configuration used is the following.
interface range GigabitEthernet2/0/1 - 48
switchport access vlan 42
switchport mode access
spanning-tree portfast
authentication control-direction in
authentication event fail action auth vlan 42
authentication event server dead action authorize vlan 42
authentication event no-response action authorize vlan 42
authentication event server alive action reinitialize
authentication host-mode multi-domain
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
mab
dot1x pae authenticator
dot1x timeout tx-period 3
dot1x timeout supp-timeout 10
dot1x max-req 3
spanning-tree bpduguard enable
switchport nonegotiate
storm-control broadcast level 0.5
storm-control multicast level 10
exit
interface range GigabitEthernet3/0/1 - 48
mab
dot1x max-req 3
exit
Joakim Backlund
If I compare the configuration in PnP and the running configuration after a successful provisioning it looks like PnP only provided a partial configuration. How do I verify what configuration is really sent to the switch?
The switch says so it is satisfied with the configuration downloaded at least. Although not complete.
------------------ show pnp tasks ---------------------
Certificate-Install Task - Never Run
Image-Install Task - Never Run
Config-Upgrade Task - Last Run ID:3, ST:5202, Result:Success, LT:219061, ET:108323 ms
        Src:[https://pnpserver.<domain.com>:443/api/v1/file/onetimedownload/eb40303c-0cfd-4d45-970e-75412c992dee], Dst:[running]
CLI-Config Task - Last Run ID:2, ST:5201, Result:Success, LT:105156, ET:223 ms
        Src:[cli-config request], Dst:[running-config]
Licensing Task - Never Run
File-Transfer Task - Never Run
Redirection Task - Never Run
CLI-Exec Task - Last Run ID:5, ST:5401, Result:Success, LT:286802, ET:11239 ms
        Src:[cli-exec request], Dst:[running-exec]
Quick sanity check.
What version of PnP app?
What version of IOS are you upgrading from?
Now running PnP 1.5.1.35, when I started the troubleshooting I was running 1.4.1.1159. There are two differences in behaviour between those two versions.
With 1.4.1.1159 a random number of interfaces on switch one and two were configured but nothing more. To be able to get the switch fully configured I had to delete the old provision job and create a new one without any image pointed out before I did a total reset on the switch via CLI.
With 1.5.1.35 all interfaces on switch 1 and 2 are fully configured but nothing more. Now it is enough to just reset the old provision job and do a complete reset on the switch via CLI.
Switches are mostly delivered with 3.6.6E which we upgrade to 16.3.3 to be able to do full AAA configuration directly without workarounds with EEM script.
I have a TAC case on this as well.
