Beginner
Prime 3.2 API and curl not working correctly
I recently upgraded from Prime 3.0 to 3.2 and am having issues with using curl and php curl when trying to pull information using the filtering. For example:-
>curl -k "https://<user>:<pass>@<server>/webacs/api/v3/data/AccessPointDetails?macAddress=\"<mac>\""
Curl error: Empty reply from serverurl
The same result with using php curl.
When using curl to obtain a list of devices without using a filter, it returns the results fine.
On PI 3.0 this was working fine so I'm not sure what changed in 3.2. I tested a sample Ruby script and that works fine so even more weird!
Any thoughts on what is going on?
Everyone's tags (2)
9 REPLIES 9
Re: Prime 3.2 API and curl not working correctly
My apologies, it seems there's been a regression here.  I've opened CSCvf16644 to track this issue (the link may say the bug does not exist at first, it may take a couple business days for the bug to be visible).
Workaround
You can replace the \" escaped double-quotes with percent encoded double quotes.  For example macAddress=%2200:11:22:33:44:55%22
I'll update this thread when I have information about when and in what patch this issue will be fixed.
EDIT: Bug now visible
Beginner
Thanks for the reply and for opening a bug ID on this. I never thought of that workaround!
I had written an app (mostly for mobile) to interact with Prime and once I made the changes per your workaround, it is now working again.
We've concluded our investigation into this issue; unfortunately, we'll be closing the bug (indicating that we believe the reported issue is valid but will go unfixed).
In PI, we use Apache Tomcat to handle our HTTP traffic.  In resolving CVE-2016-6816, Tomcat's behavior was changed to strictly enforce RFC 3986's allowed URL characters.  So, whenever an unencoded character is present in a URL, Tomcat will now immediately return an HTTP 400 response.  This seems to occur before filters are invoked, which means we don't have that avenue to alter Tomcat's behavior.  Furthermore, we can't identify any Tomcat configuration we'd be able to specify to workaround this particular issue.
So because this change in behavior was made to mitigate a vulnerability, and because the workaround is easy to implement, and for the reasons above, we're closing this bug.  We will be making documentation changes to clarify things, but the behavior will go on as it is in 3.2.
I understand this is probably not the answer you wanted to hear; please feel free to reach out here or via email (my address is visible to logged in users on my profile) if you'd like to discuss this further.
One more (and probably the last) update on this issue.  We've updated the 3.2 Reference Guide and Tutorial in DevNet regarding this.  We've also incorporated these documentation changes in the first maintenance release of 3.2
Beginner
This is terrific news Spencer! Perfectly understandable in regards to the encoding of special characters in the URL. it's better to force the API clients to use correct encoding.
You could try use curl with "--data-urlencode" parameter. See curl man page.
Igor,
My understanding is that --data-urlencode only changes data in a POST/PUT request payload, not the URL.  So I don't think it will help with this issue.
Hi Spencer,
Actually, you misunderstood some points regarding curl --data-urlencode option.
Take a look the follow example for an unauthenticated request (just to catch the HTTP headers):
# curl -k -G -v "https://10.129.223.18/webacs/api/v3/data/AccessPointDetails" --data-urlencode "apMacAddress=0c:85:25:34:5f:55" --data-urlencode "profileName=#MY-SERVICE WIFI"
* About to connect() to 10.129.223.18 port 443 (#0)
*   Trying 10.129.223.18...
* connected
* Connected to 10.129.223.18 (10.129.223.18) port 443 (#0)
* found 149 certificates in /etc/pki/tls/certs/ca-bundle.crt
*      server certificate verification SKIPPED
*      compression: NULL
*      cipher: AES-128-CBC
*      MAC: SHA1
> GET /webacs/api/v3/data/AccessPointDetails?apMacAddress=0c%3A85%3A25%3A34%3A5f%3A55&profileName=%23MY-SERVICE%20WIFI HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.27.0 GnuTLS/2.12.23 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: 10.129.223.18
> Accept: */*
< HTTP/1.1 302
< Cache-Control: private
< Expires: Wed, 31 Dec 1969 21:00:00 BRT
< Set-Cookie: JSESSIONID=E9BCB19C2D40282961C6C2A6A7891650; Path=/webacs; Secure; HttpOnly
< Location: https://10.129.223.18/webacs/pages/common/login.jsp
< Content-Length: 0
< Date: Thu, 14 Sep 2017 20:28:54 GMT
< Server: Prime
* Connection #0 to host 10.129.223.18 left intact
* Closing connection #0
Request attibutes:
Request URI:
Highlighted
Content for Community-Ad
August's Community Spotlight Awards
