Python netmiko interactive session on Cisco IOS
fc00::/7
This is simple Python code to get `show hostname` output in Cisco IOS.
script.py
from netmiko import ConnectHandler
cisco_881 = {
'device_type': 'cisco_ios',
'host': 'host',
'username': 'u',
'password': 'p'
net_connect = ConnectHandler(**cisco_881)
output = net_connect.send_command('show hostname')
print(output)
Output
[user@Linux ~]$ python script.py
Hostname is Cisco_01
[user@Linux ~]$
Instead of defining the Cisco command in the code, would it be possible to get interactive mode so that I can type anything on the Cisco IOS Shell?
Desired Ouput
Cisco_01 #
Cisco_01 # show hostname
Cisco_01 # exit
Connection to Cisco_01 closed.
[user@Linux ~]$
Sergiu.Daniluk
Try this:
device = {
'device_type': 'cisco_nxos',
'host': 'ip',
'username': 'u',
'password': 'p'
net_connect = ConnectHandler(**device)
while True:
command = input("Router# ")
if command == "exit":
net_connect.disconnect()
print("Disconnected!")
break
output = net_connect.send_command(command)
print(output)
 Result:
Router# show hostname
N9K-1
Router# show version
Cisco Nexus Operating System (NX-OS) Software
Router# exit
Disconnected!
Sergiu
6 Replies 6
Sergiu.Daniluk
Try this:
device = {
'host': 'ip',
'username': 'u',
'password': 'p'
while True:
break
print(output)
 Result:
N9K-1
Router# exit
Disconnected!
Sergiu
It's simpler that I thought .. many thanks man. I can't believe simple while loop can do this.
I don't think that is a genuine way......
it is disconnecting session rather than actually sending exit command.
omz
Although there are better ways to write this code .. you can try this ..
#!/usr/bin/env python
cisco_881 = {
'host': '172.16.100.17',
'username': 'cisco',
'password': 'cisco123'
output = net_connect.send_command('',expect_string=r'#',strip_command=False, strip_prompt=False)
output += net_connect.send_command('\n',expect_string=r'#',strip_command=False, strip_prompt=False)
output += net_connect.send_command('show run | i hostname',expect_string=r'#',strip_command=False, strip_prompt=False)
print(output)
Your desired output .. does it have to match? Instead of exit command you can use net_connect.disconnect() to close the session.
omz@mac ios % python script.py
Switch#
Switch#show run | i hostname
hostname Switch
Switch#
omz@mac ios %
Thanks but this is not what I looking for.
In this code, Cisco command needs to be defined.
What I wanted to achieve is to run arbitrary command in Cisco devices as shown in msdaniluk's code.
ahh  .. I didn't read the requirement properly .. my bad 🙂
glad you got the answer
