Python Netmiko to get hostname
write_erase
I was able to get device hostname with the following netmiko code.
>>> print(net_connect.find_prompt())
Cisco#
>>> print(net_connect.send_command('show running-config | include hostname'))
hostname Cisco
Would it be possible to remove `#` and `hostname` from the output?
Desired Output
>>> print(net_connect.find_prompt()) <= need to do something here
Cisco
>>> print(net_connect.send_command('sh run | i host')) <= need to do something here
Cisco
Seb Rupik
Hi there,
Try the following:
>>> print(net_connect.find_prompt()[:-1])
>>> print(net_connect.send_command('sh run | i host').split()[1])
cheers,
Seb.
Seb Rupik
Hi there,
Try the following:
cheers,
Seb.
Instead of parsing the running-config (which means additional execution time for your script until the running-config is collected), why not getting the hostname directly using 'show hostname' command?
print(net_connect.send_command('show hostname'))
Cheers,
Sergiu
There is no "show hostname" on 3725
R1#show hostname
% Invalid input detected at '^' marker.
R1#
R1#show host?
hosts
R1#
I run 'show version | in uptime' which is way more faster than parsing running config.
