Unable to print telnet test result to Python
normzie
Hi All,
Hope someone can help us with this. We're not successful in printing a telnet test result. Netmiko is being used with Python. Tried several methods but it's the same error. Below is the code and the output that should appear. Other commands execute fine and results are printed except for telnet. It seems that the problem is on terminating the telnet. All the methods I tried doesn't seem to work to terminate telnet. Appreciate your help on this. Thanks!
sr_telnet_output = device.send_command('telnet 40.113.200.201 443 /source-interface vlan 1400', delay_factor=1)
# Already tried using various combinations of ASCII codes with different methods like write_channel(), send_command_timing() but still the same.
# Please see scripts below
device.write_channel('\x036','\x036','\x036','\x036','\x036','\x036','\n','\n')
device.write_channel('\x036')
time.sleep(0.2)
                        time.sleep(0.2)
                        time.sleep(0.2)
                        time.sleep(0.2)
                        time.sleep(0.2)
                        time.sleep(0.2)
                        device.write_channel('\n')
                        time.sleep(0.2)
device.send_command_timing('\x036')
time.sleep(0.1)
sr_telnet_output = device.read_channel()
device.clear_buffer()'
device.disconnect()
print(sr_telnet_output)
Error message:
Traceback (most recent call last):
  File "bot.py", line 170, in <module>
  File "D:\python\bot\lib\site-packages\netmiko\base_connection.py", line 129
5, in send_command
    search_pattern
OSError: Search pattern never detected in send_command_expect: Switch-\A\#
Desired result:
Finally we're able to find a solution!
The code below helped us. I'll be closing the discussion now. Thanks for all your inputs!
from netmiko import ConnectHandler
import csv
import os
import sys
import netmiko
connection = netmiko.ConnectHandler(ip="10.1.115.146", device_type="cisco_ios", username="admin", password="cisco")
output = connection.send_command("telnet 8.8.8.8 443 /source-interface vlan 7", expect_string=r"Trying")
connection.disconnect()
print(output)
7 Replies 7
omz
Are you using the telnet driver for telnet connection?
device_type='cisco_ios_telnet'
omz
You could try - telnetlib instead of netmiko
import telnetlib
conn = telnetlib.Telnet(ip, port, TELNET_TIMEOUT)
Script was entirely coded using Netmiko. Will it work if I mix it with telnetlib? And can I run telnetlib using Cisco devices?
I'm using the below parameter. Should I add the telnet driver too?
device_type = platform
Yea - Im 90% sure the comment above is your issue - fix your device type.   I had the same type of problem with F5 not having the right device type.
I tried it and it resulted in the error message below. The error message seem to be related on how the python will connect to the device which is using Telnet and the device is not be accessible via telnet for security purposes.
Our goal is to run a telnet test on a specified IP address from the core switch from user input, then print the result.
  File "tshoot.py", line 166, in <module>
    device = ConnectHandler(device_type='cisco_ios_telnet', ip=switch_A, usernam
e=username, password=password, secret=password)
  File "D:\python\bot\lib\site-packages\netmiko\ssh_dispatcher.py", line 228,
 in ConnectHandler
    return ConnectionClass(*args, **kwargs)
  File "D:\python\bot\lib\site-packages\netmiko\base_connection.py", line 283
, in __init__
    self.establish_connection()
  File "D:\python\pewbot\lib\site-packages\netmiko\base_connection.py", line 846
, in establish_connection
    self.host, port=self.port, timeout=self.timeout
  File "D:\python\pewbot\lib\telnetlib.py", line 218, in __init__
    self.open(host, port, timeout)
  File "D:\python\pewbot\lib\telnetlib.py", line 234, in open
    self.sock = socket.create_connection((host, port), timeout)
  File "D:\python\pewbot\lib\socket.py", line 727, in create_connection
    raise err
  File "D:\python\pewbot\lib\socket.py", line 716, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [WinError 10061] No connection could be made because the
 target machine actively refused it
import csv
import os
import sys
import netmiko
print(output)
