unicon.core.errors.UniconAuthenticationError: Too many password retries
nehamangla5310
Hi, I am trying my hands on pyats. So I have set up a basic script wherein I've a testbed file having device details in it. so when I am trying to connect to the device, it is giving me following error:
Password:
Password:
Password:
root@10.121.12.36's password: Traceback (most recent call last):
  File "src/unicon/statemachine/statemachine.py", line 701, in unicon.statemachine.statemachine.StateMachine.go_to
  File "src/unicon/statemachine/statetransition.py", line 479, in unicon.statemachine.statetransition.AnyStateTransition.do_transitions
  File "src/unicon/eal/dialogs.py", line 419, in unicon.eal.dialogs.Dialog.process
  File "src/unicon/eal/dialog_processor.py", line 285, in unicon.eal.dialog_processor.SimpleDialogProcessor.process
  File "src/unicon/eal/dialog_processor.py", line 224, in unicon.eal.dialog_processor.SimpleDialogProcessor.expect_eval_statements
  File "/usr/local/lib/python3.6/dist-packages/unicon/plugins/generic/statements.py", line 144, in password_handler
    raise UniconAuthenticationError('Too many password retries')
The above exception was the direct cause of the following exception:
  File "src/unicon/bases/connection.py", line 532, in unicon.bases.connection.Connection.connect
  File "src/unicon/bases/routers/connection_provider.py", line 146, in unicon.bases.routers.connection_provider.BaseSingleRpConnectionProvider.connect
  File "src/unicon/bases/routers/connection_provider.py", line 169, in unicon.bases.routers.connection_provider.BaseSingleRpConnectionProvider.establish_connection
  File "src/unicon/statemachine/statemachine.py", line 704, in unicon.statemachine.statemachine.StateMachine.go_to
unicon.core.errors.StateMachineError: Failed while bringing device to "any" state
  File "<console>", line 1, in <module>
  File "src/pyats/connections/manager.py", line 305, in pyats.connections.manager.ConnectionManager.connect
  File "src/unicon/bases/connection.py", line 538, in unicon.bases.connection.Connection.connect
unicon.core.errors.ConnectionError: failed to connect to nexus_device
device details are correct, as I am able to login via netmiko library.
Please help!!
15 Replies 15
omz
What device you are running this against?
As you can see its failing with too many password retires. I suggest you double-check the credentials in the testbed file.
You can validate the testbed file with - pyats validate testbed <testbed_file.yml>
Can you share the testbed file (remove sensitive info) and how you are executing the pyats command?
I tested my testbed file. It results following:
Testbed Name:
    our-testbed-file
Testbed Devices:
`-- nexus_device [switch/cisco_nxos]
Warning Messages
 - Device 'nexus_device' missing 'platform' definition
 - Device 'nexus_device' has no interface definitions
YAML Lint Messages
Below is the yaml file. I have a nexus device.
# a simpe testbed yaml containing a single device
devices:                # all device definition goes under devices block
  nexus_device:           # start a device definition with its HOSTNAME
    type: switch
    os: cisco_nxos
    credentials:
      default:
        username: ****
        password: ****
    connections:        # give the block on how to connect to its mgmt interface
      mgmt:
        protocol: ssh
        ip: ****
For execution, I am following this link:
https://developer.cisco.com/docs/pyats/#!connection-to-devices/device-connections
you can ignore warning messages in pyats validation.
is there any error message or debug output you can share?
does the device prompt shows hostname as - nexus_device - as in your testbed file?
try like this -
  nexus_device:
    os: nxos
    type: nxos
    credentials:
      default:
        username: "admin"
        password: "xxx"
        enable: "xxx"
    connections:
      defaults:
        class: unicon.Unicon
      ssh:
        protocol: ssh
        ip: "xxx"
There is no error message, only warnings.
I am not sure what you mean by "shows hostname"question but when I run following command set, it returns output:
pyats shell --testbed-file our-testbed-file.yaml
from pyats.topology import loader
testbed = loader.load('our-testbed-file.yaml')
testbed.devices
it returns following output:
TopologyDict({'nexus_device': <Device nexus_device at 0x7f874e328ba8>})
if you login to the nexus box from putty or cli .. after successful you get the device prompt that shows the hostname of the device.
R1#
or
nexus_device#
try to match the hostname configured on the device to the hostname in the testbed file.
is expected after you type testbed.devices
what happens when you do -
>>> device = testbed.devices['nexus_device']
>>> device.connect()
 Do you get password error after this? Can you login to the device with the same creds via Putty or shell?
Yes I get password error just after "device.connect()". I am successfully able to login via putty
I tried your testbed file on devnet sandbox.
after the device.connect() it logs in but the connection hangs..
if I add enable password in the testbed file .. the connection works fine
have you added the enable password on the testbed file? can you plz try?
try these creds for sandbox in your testbed file -
credentials:
    default:
      username: admin
      password: Admin_1234!
      enable: Admin_1234!
ip: sbx-nxos-mgmt.cisco.com
port: "8181"
Can you share testbed file that you've used? Enable didn't work for me
this is a working testbed file .. i have tested with sandbox.
testbed:
  credentials:
    default:
      username: admin
      enable: Admin_1234!
devices:
  sbx-n9kv-ao:   ## match this with hostname on device
    alias: nexus_device   ## you can use alias here if want to call it nexus_device
    type: nxos
    os: nxos
    connections:
      mgmt:
        protocol: ssh
        port: "8181"
omz
Are you using console/SSH connection in the testbed? Netmiko will be using SSH.
  csr1000v-1:           # start a device definition with its HOSTNAME
    alias: node1
    type: router
    os: iosxe           # this tells the engine what type of OS its connected to
    credentials:
      default:                         # login credentials
        username: admin
        password: Cisco123
      mgmt:
        protocol: ssh
        ip: 172.16.1.1
Neither this work for me. I think problem is something else.
Do you password error with sandbox as well?
I am not using Sandbox but a lab device and when I am logging via putty, it works fine
test with sandbox and check pyats version
