Community Helping Community
171
Highlighted
Beginner
Upgrade from 1.1.1.34 to 1.1.2.15 failed
Trying to upgrade to the most current version of APIC-EM.  I started with the upgrade from 1.1.1.34 to 1.1.2.15 and it failed.  Didn't make it very far.  I saw that the upgrade had failed and while doing some google-fu researching the error my web session timed out.  I was no longer able to log in.  The error kept saying try again later.  I then connected via ssh rebooted the VM 'shutdown -r now'.  Now all the apic services are harvested.  From the Dev Console i can see the Grow client operation failing as well:
Capacity plugin error: {u'status': u'success', u'version': u'0.4.0.1510.dev404-g953407a', u'response': {u'task': {u'status': u'error', u'error_code': u'RESOURCE_NOT_FOUND_ERROR', u'taskId': u'7c9b194e-b781-11e6-a558-005056965be2', u'error': u"'Template client_template-304-02-18-2016_15-18-46' does not exist"}}}
Before I tactically nuke the VM and start over with the latest version I thought I'd see if this is a simple fix.
Everyone's tags (1)
1 REPLY 1
Beginner
Re: Upgrade from 1.1.1.34 to 1.1.2.15 failed
reset_grapevine
re-initiated upgrade once all services were up - success.
Content for Community-Ad
FusionCharts will render here
