Using jumpssh to ssh into a remote network devices over a windows jumpbox (Windows server 2012 R2 standard)
pn2020
Does anyone know if python jumpssh library works when the jumpbox is a windows? If you have a working implementation of jumpssh over a windows server jumpbox, I would love to hear your feedbacks and sharing. Do I have to install openssh on the windows jumpbox to make it work?  If you have suggestions for other solutions, I would love to hear.
From its documentation, it seems it would only work with a linux jumpbox.
https://pypi.org/project/jumpssh/
Thanks.
Hi @pn2020
I had a little play with jump_ssh .. thought might come handy at some point .. btw .. thanks for sharing :)
I used Windows 10 as jumpbox .. installed OpenSSH server - https://docs.microsoft.com/en-us/windows-server/administration/openssh/openssh_install_firstuse
Simple to code I used to run show ver on remote host.
#!/usr/bin/env python
from jumpssh import SSHSession
from getpass import getpass
jumpbox = '172.16.100.13'
rhost = 'sbx-iosxr-mgmt.cisco.com'
juser = input("Jumpbox username: ")
jpass = getpass("Jumpbox password: ")
try:
    jump_session = SSHSession(jumpbox, username=juser, password=jpass).open()
    if jump_session.is_active() == True:
        print()
        print("Connected to jumpbox ... {}".format(jumpbox))
        try:
            remote_session = jump_session.get_remote_session(rhost,
	                                                 username='admin',
	                                                 port=8181,
	                                                 password='C1sco12345',
	                                                 look_for_keys=False,
	                                                 allow_agent=False,)
            if remote_session.is_active():
                print()
                print("Connected to remote host ... {}\n".format(rhost))
                result = remote_session.run_cmd('sh ver')
                print(result.output)
        except Exception as ex:
            print()
            print("Unable to connect to the remote host ... {}".format(rhost))
            print(ex)
            print()
        jump_session.close()
        print()
        print("Jumpbox connection closed.")
        print()
    print()
    print("Unable to connect to the jumpbox ... {}".format(jumpbox))
    print(ex)
    print()
8 Replies 8
Manoj Papisetty
Which part of it is broken? SSH to the jump host itself or after that?
Are you able to SSH to the Windows jump host manually? (Like a putty or from terminal?)
Unfortunately, I can't.  I got @ssh_exchange_identification: read: Connection reset by peer, after being hung for a while.
Looking like, I have to talk to the server system admin to see if openssh can be installed on the windows jumpbox.
Actually, ssh from a local cmd widows to the windows jumpbox works.  But doesn't look like ssh is installed on the windows jumpbox, ie, ssh cli command isn't recognized.
Thanks everyone for your feedbacks.  I will look more into this.
Hi @pn2020
try:
        print()
        try:
	                                                 username='admin',
	                                                 port=8181,
	                                                 allow_agent=False,)
                print()
            print()
            print(ex)
            print()
        print()
        print()
    print()
    print(ex)
    print()
Wow, that's awesome, thanks omz for sharing!  I will play more with jumpssh.
jokey@telstra
@omz, thanks for sharing ! Solved my problem which uses RHEL linux distro as the jumphost.
I should add, in my case I needed to modify the jump.session sub-method port number from 8181 to 22.
