VLAN Management via SNMP on CBS350-16T-2G
o0oinsomniao0o
could you please provide some snmpset commands to add, modify and delete vlan table entries on CBS350-16T-2G switches?
I can create VLAN
SNMPv2-SMI::mib-2.17.7.1.4.3.1.5.3 = INTEGER: 4  (create and go)
SNMPv2-SMI::mib-2.17.7.1.4.3.1.1.3 = STRING: "vlan3" (vlan name)
to add port 3 to vlan3 I used this OID's but it doesn't work
SNMPv2-SMI::mib-2.17.7.1.4.3.1.2.3 = Hex-STRING: “0x20”  (This is bit map representation of ports on device in HEX format, and have to fill something even for 0)
SNMPv2-SMI::mib-2.17.7.1.4.3.1.3.3 = Hex-STRING: “0x00”  (This field has the same definition as static field)
SNMPv2-SMI::mib-2.17.7.1.4.3.1.4.3 = Hex-STRING: “0x20”  (This field has the same definition as static field)
balaji.bandi
don't work for CBS350
They are same SMB switches, if not working, contact Cisco SMB TAC see if that supported what you looking to do.
BB
