vManage Event and Alarm logs extract
hrmt92
Beginner
Beginner
Is there a way to extract the Event and Alarm logs from vManage for a long period like last 6 months? When i extract from the vManage, I get logs for a very short time since the row limit for the extract is 10000 and it is filled within very short time.
balaji.bandi
VIP Guru VIP Guru
VIP Guru
as per i know that is limitation "Total Rows: 10000"  you can do based on the  " severity or component or detail" if you looking to cover more.
or select the Time range Customer to get more acurate results.
May be we can consider send events to external syslog server.
BB
Recognize Your Peers
