el 11-10-2020 10:47 AM
Hello everyone, thanks for the support, I present the following problem with a Nexus 7 K that in the monitoring tool provides me with the following message
sh inter vlan xxx
Vlan723 is up, line protocol is up, autostate enabled
Hardware is EtherSVI, address is xxxx
Description: Respaldo_Xxxxxxxx 10.1xx.xx.xx/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 15/255, rxload 18/255
Keepalive not supported
ARP type: ARPA
60 seconds input rate 71687293 bits/sec, 5953 packets/sec
60 seconds output rate 62409431 bits/sec, 7161 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 69.37 Mbps, 5.78 Kpps; output rate 68.18 Mbps, 7.62 Kpps
L3 Switched:
input: 176980952756 pkts, 40967382088994 bytes - output: 2107480955338 pkts, 3107348276861462 bytes
L3 in Switched:
ucast: 176980799107 pkts, 40967370735682 bytes - mcast: 153649 pkts, 11353312 bytes
L3 out Switched:
ucast: 2107480955338 pkts, 3107348276861462 bytes - mcast: 0 pkts, 0 bytes
el 11-10-2020 11:22 AM
Estimado buenas tardes,
Perdón pero no puedo ver el mensaje de error, si puedes adjuntarlo o pegarlo nuevamente te agradecería.
Saludos,
el 11-10-2020 12:14 PM
Hola buenas tardes, mucas gracias por responder la imagen de la falla no la puedo cargar pero indicio la falla presentada en la herramienta de monitoreo es la siguiente:
High output utilization on interface Vlan7xx
el 11-10-2020 12:28 PM
Oh ok, perdona por no haberlo entendido antes,
En ese caso te voy a recomendar leer la respuesta de Richard Burts en este post: https://community.cisco.com/t5/switching/what-is-the-max-bandwidth-of-a-l3-vlan-interface/td-p/2856178 te la copio igual acá:
The Solarwinds report was written for monitoring physical interfaces and it works well for physical interfaces. If the report says that the interface transmitted 32% or 64% or some other % then you knew with some accuracy how close you were to maximum utilization of the interface. But when it is monitoring a virtual interface like vlan 8 it does not really mean the same thing.
Let me try to explain it in this way - if Solarwinds says that vlan 8 is using 64% of 1 Gig, then it is saying that 64% of 1 Gig was the aggregate utilization going out all of the physical interfaces in vlan 8. If there are, perhaps, 8 physical interfaces in vlan 8 then realistically each physical interface is at about 8% utilization and the 64% reported on the virtual interface is really not alarming. You might try using the bandwidth command in interface config mode for vlan 8 and set some value higher than 1 Gig and see if that helps with the reporting.
Creo que esto explica exactamente el comportamiento que estas teniendo, quizá si cambias manualmente el BW en la interfaz vlan (aumentándolo) tu herramienta podría calcular basado en un valor mas real.
***Por favor no olvides calificar y/o marcar como solución las respuestas útiles, tu calificación promueve nuestra participación.***
Saludos,
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
