Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Cannot find working link to Cisco TAPI BlogIn the "Getting Started with Cisco TAPI" https://developer.cisco.com/site/tapi/discover/getting-started/, the link for Cisco TAPI Blog is broken: https://communities.cisco.com/community/developer/tapi/blogAl...
What needs to be done to have multiple calls on a CTI Port? I can do makeCall multiple times after another just fine, but if there's one active outbound call, calling makeCall, while returning success, returns the same globalCallId and in fact no new...
Hi,https://developer.cisco.com/site/jtapi/documents/cti-tapi-jtapi-supported-device-matrix/ Cisco Spark Remote DeviceNANACTI Supported. Not supported from CiscoJTAPI and CiscoTSP I can see it's a CTI supported device but not supported by Cisco JTAPI ...
In the routing section of the JTAPI dev guide, it states: "You can configure each CTI RoutePoint with only one line in the Cisco Unified Communications Manager. A single CTI RoutePoint supports a maximumof 34 lines.To support more than 34 lines," So,...
  Hi,I want to develop an automation suite to tests big loads of calls with CTI. what would be the options, is there a CTI server simulator available? I believe there is an option to reserve an IVT but then I don't think it will be ideal to run daily...
Hello, in my Application i would like to add my voice gateway to show the calls which are running now and the calls which was active in the past. So to give the user an overview about the usage for the Gateway. And i dont want to get this information...
I am using lineGetNewCalls() to get handles to the calls which is established before invoking my application.https://docs.microsoft.com/en-us/windows/win32/api/tapi/nf-tapi-linegetnewcalls The issue is that It always returns zero in the dwCallsNumEnt...
h.abdelraouf by • Community Member
  • 1875 Views
  • 3 replies
Hi All, I have a question regarding JTAPI usage and the following are my scenarios: Scenario 1:1. Silent and Whisper functionalities are added on a gadget on Finesse desktop2. Two (2) workstations are used each for Supervisor and Agent (total of 4) ....
liam123 by • Level 2
  • 2534 Views
  • 3 replies
