CallCtlConnEstablishedEv - Definition?
Gerry O'Rourke
Can anyone tell me or point me to a doc which states what the CallCtlConnEstablishedEv is defined as?
We get this event at ringback/alerting, i.e. before a call is connected.
I could not find any defination on exactly when this event shoudl be triggered by CUCM.
Verint call recording are using this to trigger for a valid call recording, (when the receieve a second CallCtlConnEstablishedEv).
However this leds to false "device not recording" alerts when call is routed to a Hunt Pilot, as you get a second CallCtlConnEstablishedEv
even though a call has not been established (when the call routes to the second phone in the line group)
Gerry
davidn#
Hi Gerry,
You can find the Java Doc for CallCtlConnEstablishedEv interface on many sites on the Net. For example:
Java Telephony API (JTAPI) Specification Version 1.4 (Final Release): Interface CallCtlConnEstablishedEv
The latest Cisco JTAPI Developer Guide includes many call scenarios where this event is trigger by CUCM. You can download it from our CDN documentation pages:
https://developer.cisco.com/site/collaboration/call-control/jtapi/documentation/index.gsp
FYI, one of your colleague has recently opened a ticket on this issue (SR 629548055) and our team is helping him with it.
Hope that helps.
David
David,
Many thanks that is very helpful.
I am still not 100% sure from reading the docs, if the event is to signify that the signalling (the Call Control) between the two parties is established (which is what I believe it means) or if the call itself is active (a call becomes active after calling party goes 'off hook'.
Gerry
