Calling Another TCL script from with in TCL script
AshG
Level 4
Level 4
Is it possible to call another TCL application from with in tcl app?
or otherwise is it possible to assign two TCL Application to single dial peer to execute in series. i.e once first application is finished then second executes.
Ashish
Hi Raghavendra,
Yes that's what we are thinking now.
Our app started its life on its own and later we discovered the need of survivability , that's why we were looking in to options but now it seems that we will have to merge our app with survivability.
Ashish
11 Replies 11
Raghavendra G V
Hi Ashish,
You can use sendmsg command to communicate with other tcl app. For more information please refer TCL IVR programming guide.
Sends a message to another application instance.
Syntax
sendmsg {<app-name> | <handle>} -p <parameter_array>
Arguments
• <app-name>—Creates a new instance using this application name.
• <handle>—The handle of an existing application instance.
• -p <parameter_array>—A Tcl array containing the list of parameters to pass.
Raghavendra
Thanks Raghavendra,
Will try that.
Below is the exact scenario.
Our Custom.tcl will run and update the destination number based on http output.
Then custom.tcl handover the call to survivability.tcl  and comes out of call path.
Possible?
Ashish
If you want handoff to another app then you can use handoff command.
Syntax
handoff {appl | callappl} {legID | info-tag} [{legID2 | info-tag2} ...] {app-name | <handle>} [-s
<argstring>]
Raghavendra
Thanks Raghavendra,
yeah, seems better. will try Handoff.
Hi Raghavendra
Just wondering, Can we use handoff in conjunction with leg Setup ?
Currently we use Leg Setup to update the DN, however as soon as leg setup is executed call left the script.
Below is the command we are using.
Set dest "08001234567"
leg setup $dest callinfo leg_incoming
No You can't use both same time.
Raghavendra
Any other way to update the destination number without using leg setup ?
you can try as below but this will handoff to default app.
handoff appl leg_incoming default "DESTINATION=$dest"
call close
Raghavendra
Hi Raghavendra,
Default application will not solve our issue. We need a way to bring survivability.tcl in call path after we have finished our custom.tcl.
Any suggestions?
Ashish
why don't use http code in survivability script instead of doing handoff? why you want another script any specific reasons ?
Raghavendra
Hi Raghavendra,
Ashish
