Cisco 800 Series ISR
AshG
Level 4
Level 4
Can Cisco 800 Series router used as a Voice gateway and use TCL Scripts to answer calls
Hi Ashish,
I checked internally and got the below response.
"I don’t think we tested/supported  voice TCL apps on 800 series platforms. But it is possible for customer to configure and use it. I don’t know what limitations they will encounter."
Raghavendra
Raghavendra G V
I haven't tested TCL script in this router, let me check on this and get back to you..
did you tired got any issues ?
Raghavendra
Hi Raghavendra,
Thanks for your reply.
No , I not haven't tried as yet as we do not have them but we are planning to source them.
They will be used as simple SIP End Device , where tcl script will answer the call and play message.
Hi Ashish,
Raghavendra
