08-19-2020 04:13 AM - edited 08-19-2020 09:28 AM
https://developer.cisco.com/site/jtapi/documents/cti-tapi-jtapi-supported-device-matrix/
Cisco Spark Remote Device | NA | NA | CTI Supported. Not supported from CiscoJTAPI and CiscoTSP |
I can see it's a CTI supported device but not supported by Cisco JTAPI or TSP.
Can you please tell which server side CTI API supports Cisco Room Kits?
Is there a way or CUCM database table where I can check login & logout time of particular user on particular Cisco Room Kit device?
Apart from xCommand (https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce90/room-kit-api-reference-guide-ce90.pdf)
Umesh
Does Cisco Extension Mobility API supports Cisco Room Kits?
08-19-2020 11:31 AM
08-19-2020 08:33 PM
Thanks for reply David.
We are registering Room Kits with CUCM as per customer requirement. WebEx is not in this scenario. So we need to use CUCM API for tracking login/logout of use on these devices.
xCommand can be a way we are also exploring that if that will be a better approach or not.
Umesh
