CTI Port as Silent Monitoring Initiator
KasMay
i am trying to use CTIPort as Monitor Initiator rather than IP phones. I believe CTIPort can be used. I get error as below. Please advise.
2018/05/30 10:08:06.457 EDT,INFO,Call event: 108, State: ACTIVE, Cause: CAUSE_DEST_NOT_OBTAINABLE, Addr: 5140001130[ state: FAILED] , callid: 44769/1, conf call? false
2018/05/30 10:08:06.457 EDT,INFO,Calling Terminal: RSMCTIPort
2018/05/30 10:08:07.419 EDT,INFO,Call event: 103, State: ACTIVE, Cause: CAUSE_NORMAL, Addr: 5140001100[ state: CONNECTED] 2xxxxxxxxx [ state: CONNECTED] , callid: 44768/1, conf call? false
2018/05/30 10:08:07.420 EDT,INFO,Calling Terminal: RSMCTIPort
2018/05/30 10:08:07.420 EDT,INFO,Call Object: (P1-jtapiuser) GCID=(1,44769)->ACTIVE
2018/05/30 10:08:07.420 EDT,INFO,Call Active: 33
2018/05/30 10:08:07.420 EDT,INFO,Call event: 103, State: ACTIVE, Cause: CAUSE_NORMAL, Addr: 5140001130[ state: FAILED] , callid: 44769/1, conf call? false
com.cisco.jtapi.InvalidPartyExceptionImpl: Invalid monitor destination.
    at com.cisco.jtapi.CallImpl.startMonitor(CTQF)
Note: I am able to establish call connection between CTIPort and IPPhones
Thank You
5 Replies 5
KasMay
Adding JTAPI Logs:
370: May 31 17:55:11.929 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.queueEvents: queuing asynchronously
371: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:[5140001130:ALL-P-GLOBAL-DEVICES:1]Request: addCallObserver(test.CTIPort@7bacb9c3)
372: May 31 17:55:11.929 EDT %JTAPI-JTAPIIMPL-7-UNK:RSMCTIPort deviceInService(): This terminal: name=RSMCTIPort, isOpen=true. This device: Type=72, RegistrationType=2, isRegistered=true, isRegisteredExtendByThisApp=false, Protocol=1, isOpen=true
373: May 31 17:55:11.929 EDT %JTAPI-CTIIMPL-7-UNK:(P1-10.38.244.135) EventThread handling event com.cisco.cti.protocol.LineInServiceEvent[27]
374: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[ObserverThread(test.CTIPort@7bacb9c3)][RSMCTIPort]Request: getObservers()
375: May 31 17:55:11.929 EDT %JTAPI-JTAPIIMPL-7-UNK:Address [RSMCTIPort:5140001130:ALL-P-GLOBAL-DEVICES:(1,14320)]  in service
376: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[ObserverThread(test.CTIPort@7bacb9c3)][RSMCTIPort]Request: getCallObservers()
377: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser) [5140001130:ALL-P-GLOBAL-DEVICES] CiscoAddrInServiceEv [#47] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
378: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:[5140001130:ALL-P-GLOBAL-DEVICES:1]Request: getObservers
379: May 31 17:55:11.929 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.queueEvents: queuing asynchronously
380: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[ObserverThread(test.CTIPort@7bacb9c3)][5140001130:ALL-P-GLOBAL-DEVICES:1]Request: getCallObservers()
381: May 31 17:55:11.929 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[ObserverThread(test.CTIPort@7bacb9c3)][5140001130:ALL-P-GLOBAL-DEVICES:1]Request: getCallObservers()
382: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents() completed
383: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:ObserverThread(test.CTIPort@7bacb9c3): delivering JAES[1]
384: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents()
385: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]delivering to addressChangedEvent
386: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents() completed
387: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:ObserverThread(test.CTIPort@7bacb9c3): delivering JAES[1]
388: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents()
389: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]delivering to addressChangedEvent
390: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:Request:getAutoAcceptStatus: Terminal=RSMCTIPort
391: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:Request:getAutoAcceptStatus: Address=RSMCTIPort:5140001130:ALL-P-GLOBAL-DEVICES:(1,14320)
392: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:[5140001130:ALL-P-GLOBAL-DEVICES:1]Request: setAutoAcceptStatus 1Terminal=RSMCTIPort
393: May 31 17:55:11.939 EDT %JTAPI-JTAPIIMPL-7-UNK:Request:setAutoAcceptStatus: Address=RSMCTIPort:5140001130:ALL-P-GLOBAL-DEVICES:(1,14320)
394: May 31 17:55:11.979 EDT %JTAPI-CTIIMPL-7-UNK:(P1-10.38.244.135) EventThread handling event com.cisco.cti.protocol.LineAutoAcceptStatusEvent[28]
395: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:Address [RSMCTIPort:5140001130:ALL-P-GLOBAL-DEVICES:(1,14320)] AutoAcceptStatusChanged: Status =1
396: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents() completed
397: May 31 17:55:11.979 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser) [5140001130:ALL-P-GLOBAL-DEVICES] CiscoAddrAutoAcceptStatusChangedEv [#48] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
398: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.queueEvents: queuing asynchronously
399: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:ObserverThread(test.CTIPort@7bacb9c3): delivering JAES[1]
400: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents()
401: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]delivering to addressChangedEvent
402: May 31 17:55:11.979 EDT %JTAPI-JTAPIIMPL-7-UNK:[test.CTIPort@7bacb9c3]ObserverProxy.deliverEvents() completed
403: May 31 17:55:12.429 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[main][(P1-jtapiuser) GCID=(1,44850)->IDLE]Request: startMonitor ([SEP5140001100/[5140001100:ALL-P-GLOBAL-DEVICES:1/(P1-jtapiuser) GCID=(1,44849)->ACTIVE]->ESTABLISHED]->TALKING)
404: May 31 17:55:12.429 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser)[main][(P1-jtapiuser) GCID=(1,44850)->IDLE]Request: startMonitor (RSMCTIPort, 5140001130 , 18670808, 5140001100, SEP5140001100, 1 3
405: May 31 17:55:12.479 EDT %JTAPI-CTIIMPL-7-UNK:(P1-10.38.244.135) EventThread handling event com.cisco.cti.protocol.NewCallEvent[29]
406: May 31 17:55:12.479 EDT %JTAPI-JTAPIIMPL-7-UNK:(P1-jtapiuser) getCallManager() Found existing CallManager
407: May 31 17:55:12.479 EDT %JTAPI-JTAPIIMPL-7-UNK:CallInfo for = (P1-jtapiuser) GCID=(1,44850)->IDLE CurIng :5140001130:ALL-P-GLOBAL-DEVICES:1 Cured :null LRP :null ing :5140001130:ALL-P-GLOBAL-DEVICES:1 ed :null ModEd :null Moding :5140001130:ALL-P-GLOBAL-DEVICES:1
408: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:[(P1-jtapiuser) GCID=(1,44850)->IDLE]InvalidPartyExceptionImpl caught: Invalid monitor destination.
409: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:[[5140001130:ALL-P-GLOBAL-DEVICES:1/(P1-jtapiuser) GCID=(1,44850)->INVALID]->IDLE]creating internal connection for 5140001130:ALL-P-GLOBAL-DEVICES:1
410: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser) 44850/1 ConnCreatedEv 5140001130:ALL-P-GLOBAL-DEVICES:1 [#49] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
411: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:{ CcnCall=Call:[GCID=(44850/1),CID=18670809] Connection=[5140001130:ALL-P-GLOBAL-DEVICES:1/(P1-jtapiuser) GCID=(1,44850)->INVALID]->IDLE: creating new Connection for CCNCall }
412: May 31 17:55:12.479 EDT %JTAPI-JTAPIIMPL-7-UNK:{(P1-jtapiuser) GCID=(1,44850)->INVALID} Initializing to DIALTONE for 5140001130:ALL-P-GLOBAL-DEVICES:1
413: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser) 44850/1 ConnConnectedEv 5140001130:ALL-P-GLOBAL-DEVICES:1 [#50] Cause:100 CallCtlCause:0 CiscoCause:0 FeatReason:12
414: May 31 17:55:12.479 EDT %JTAPI-JTAPI-7-UNK:(P1-jtapiuser) 44850/1 CallCtlConnInitiatedEv 5140001130:ALL-P-GLOBAL-DEVICES:1 [#51] Cause:100 CallCtlCause:100 CiscoCause:0 FeatReason:12
415: May 31 17:55:12.479 EDT %JTAPI-JTAPIIMPL-7-UNK:Adding CCNCall Call:[GCID=(44850/1),CID=18670809] to TermConn:[RSMCTIPort/[5140001130:ALL-P-GLOBAL-DEVICES:1/(P1-jtapiuser) GCID=(1,44850)->INVALID]->INITIATED]->IDLE
Are you able to dial monitored phone from CTI Port?
Umesh
Hi Umesh,
Yes. I am able to make calls from CTI port to another CIPC / SIP phone.
Mayil
Please check your CTI Port CSS. Agent number should be valid and reachable from CTI Port DN.
Umesh
Here the call log between Agent and CTI Port in a normal call scenario. 5140001130 - is CTI Port DN and 5140001100 is Agent device.
CSS is set to MONITOREDDEVICES for all agent devices and CTI Port as well.
2018/05/29 18:30:07.408 EDT,INFO, Got CTI Port terminal:: RSMCTIPort
2018/05/29 18:30:07.499 EDT,INFO, TerminalChangedEvent Invoked
2018/05/29 18:30:07.499 EDT,INFO,Connection to terminal: RSMCTIPort is TERMINAL OUT OF SERVICE
2018/05/29 18:30:07.859 EDT,INFO, TerminalChangedEvent Invoked
2018/05/29 18:30:07.859 EDT,INFO,Connection to terminal: RSMCTIPort is TERMINAL IN SERVICE
2018/05/29 18:30:07.859 EDT,INFO,terminal RSMCTIPort has 1 terminal observers and 1 callobservers
2018/05/29 18:30:07.859 EDT,INFO,address 5140001130 has 1 address observers and 1 callobservers
2018/05/29 18:30:07.869 EDT,INFO,AddressChangeEvent Invoked..
2018/05/29 18:30:07.869 EDT,INFO,CiscoAddrEv activated
2018/05/29 18:30:07.869 EDT,INFO,CiscoAddress out of service: 5140001130
2018/05/29 18:30:07.910 EDT,INFO,AutoAccept set for address 5140001130
2018/05/29 18:30:07.910 EDT,INFO,CiscoAddress in service: 5140001130
2018/05/29 18:30:07.910 EDT,INFO,AddressChangeEvent Invoked..
2018/05/29 18:30:07.910 EDT,INFO,CiscoAddrEv activated
2018/05/29 18:30:07.910 EDT,INFO,AutoAccept status changed on address 5140001130
2018/05/29 18:30:29.856 EDT,INFO,CallChangedEvent Invoked
2018/05/29 18:30:29.856 EDT,INFO,CALL ACTIVE on Address: 5140001130
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001130 is CREATED
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001130 is INPROGRESS
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001130 is CallCtlConnOfferedEv
2018/05/29 18:30:29.856 EDT,INFO,5140001130is OFFERED!!!
2018/05/29 18:30:29.856 EDT,INFO,Exception accepting 5140001130 Did not meet pre-conditions.
2018/05/29 18:30:29.856 EDT,INFO,Error in pre-conditions check if autoPickup is false in CM service parameters configurations
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001100 is CREATED
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001100 is CONNECTED
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001100 is CallCtlConnEstablishedEv
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001130 is ALERTING
2018/05/29 18:30:29.856 EDT,INFO,Connection to address: 5140001130 is CallCtlConnAlertingEv
2018/05/29 18:30:29.856 EDT,INFO,CallCtlTermConnEv: RSMCTIPort is  Ringing
2018/05/29 18:30:39.929 EDT,INFO,CallChangedEvent Invoked
2018/05/29 18:30:39.929 EDT,INFO,Connection to address: 5140001130 is CONNECTED
2018/05/29 18:30:39.929 EDT,INFO,Connection to address: 5140001130 is CallCtlConnEstablishedEv
2018/05/29 18:30:39.929 EDT,INFO,CallCtlTermConnEv: RSMCTIPort is  Talking
2018/05/29 18:30:39.929 EDT,INFO, TerminalChangedEvent Invoked
2018/05/29 18:30:39.929 EDT,INFO,Connection to terminal: RSMCTIPort is RECEIVING RTP STARTED
2018/05/29 18:30:39.929 EDT,INFO, CTI Port RTP packet size 20
2018/05/29 18:30:39.929 EDT,INFO, CTI Port  MediaConnectionMode  : TRANSMIT_AND_RECEIVE
2018/05/29 18:30:39.939 EDT,INFO,RTPInput Local IP: 10.99.0.124 RTPInput Local Port: 12345 Cisco GlobalCallID: 44758
Mayil
