CURRI not respect interdigit
maurotb
I am testing curri and external call control, if i put external call control in translation pattern or route pattern with 0.! , if i digit from my phone 034 immediatly cm make a request to my test application, but i need to digit 03456etc number.
for any other digit after 034, cm make other request to application with additional digit.
Why not wait for interdigit timeout?
In xml message do I know if the interdigit timeout has passed and therefore the number entered is complete?
davidn#
Hi Mauro,
Not sure I understood your question completely but if you need to match the route pattern of 034 or 034... numbers (e.g 03456), then try the route pattern 034!? to see if that works. What about interdigit timeout?
Hope that helps.
David
