We have CRM full access in a custom finesse gadget but recently the CRM team made a suggestion to have a single panel on CRM side. For this request on one hand we need to have Cisco Finesse features embedded in CRM which can be done using Finesse APIs and I have found the following example:
https://www.expertflow.com/ms-dynamics-crm-cti-connector/And on the other hand, we also need to use the Jabber SDK to have the user's phone Embedded into CRM.
But the questions which raise:
1-Can Jabber be used as a Uccx Agent if implemented inside the Browser? The CCX Compatibility matrix only refers to the Jabber Desktop and there is no information about it.
2-How will be the Flow of the call when using Finesse as Embedded? Do Agents also need to continue to see Finesse's server directly or is the CRM server's connection to UCCX enough?
3-If there is no need to have direct port access to finesse, can the service be offered over MRA on the Internet?
Thanks.
