Walkthrough Wednesdays
471
Highlighted
End Call on device registered to Spark fails to clear call legs on coSpace
Use case: CMS  dails out to participant configured on Spark.
Device have SIP URI configured.
Call gets placed successfully.
Now from device(DX650) click on end call button.
Call leg this device is still active on CMS.
Was expecting the call leg to be removed from CMS.
Looking for support if CMS requires any configuration to enable feature?
Request :
# Create initial call on coSpace
Body: coSpace Id
Response:
Date:Tue
Server:Apache
X-Frame-Options:DENY
Strict-Transport-Security:max-age=31536000; includeSubDomains
Location:/api/v1/calls/8d7cdccf-771d-48c5-bec4-45b1d472b65d
Vary:Accept-Encoding
Transfer-Encoding:chunked
# Dial out a participant
Body: remoteParty​ = device@spark.com
Response :
Date:Tue,
Server:Apache
Location:/api/v1/participants/d000eb67-9f76-4a36-b6c7-859c341a186f
End call on device
To check use Get API : response still shows call leg , the call status on CMS Admin also shows the call leg. No error recorded.
CMS Logs attached
0 REPLIES 0
