05-13-2015 01:54 AM
My need is simple and couldn't get any information/solution from the support ![]()
From a web based application, I would like to get all calls events from a specific phone number.
I want to know:
- who is calling
- who picked up the phone
- how long last the call
- etc.
I didn't succeed to get a sample code from this site.
Can someone help me out?!
Thanks folks ![]()
Samba
Solved! Go to Solution.
05-17-2015 07:29 PM
Hi Samba,
You can login and will be able to download the sample codes from here - Cisco UCXAPI
Thanks and Regards,
Geevarghese
05-17-2015 07:29 PM
Hi Samba,
Thanks and Regards,
Geevarghese
05-28-2015 01:36 PM
Hi Geevarghese,
I tried to implement this solution but my company adminsitrator told me that they are not using a CME router, the example you gave me won't work ![]()
He told me to connect directly to the UCCX database and run queries every 2 seconds to get live data.
I'm not thrilled about this solution since a lot of calls will be made against the database...
In addition, I don't know where to find live incoming call from a user to the call center?
Any ideas?
Samba
