How to get Call Duration from JTAPI
dts.swadhin
Hello All,
Is it possible to get CISCO call duration from JTAPI?
Any link or info will be appreciated.
Swadhin.
Geevarghese Cheria
Hi Swadhin,
As far as Call Duration is concerned, there is no API to retrieve this information but you can compute the call duration programatically based on the events that JTAPI sends out (basically RTP (media) start event and established event would tell you when the call is answered and  when you get disconnected/Invalid event would tell you when is call
torn down and you can subtract the timestamps of these events to get call duration).
Alternatively these can be picked from CDRs.
Reference - Get a list of active calls
Thanks and Regards,
Geevarghese
Hello Geevarghese,
Thanks for your valuable reply. Helped me a lot to make my decision.
Thanks & Regards,
Swadhin.
