Initiate call to extension using AXL API
Hi there,
can some one let me know the soap command in AXL API to initiate call? my requirement is to initiate a call in a given time and terminate after few seconds.
thank you
Good luck
KB
dstaudt
The AXL API itself cannot perform any call control operations, however there is another small SOAP API called Webdialer that might be helpful: https://developer.cisco.com/site/webdialer/
Webdialer is good for simply doing make-call operations, and can also terminate the call (though only after a short time).  If you need more extensive and capable call control, you may want to look at TAPI or JTAPI, which provide pretty much complete call monitoring and command functionality:
https://developer.cisco.com/site/jtapi/
https://developer.cisco.com/site/tapi/
dstaudt
Hi ,
thanks for the replay. is there any sample soap code which shows how to generate call?
thank you
Good luck
KB
