Insufficient Bandwidth error
ShoutTelecoms
I am looking at integrating our call-record platform to work with Cisco HCS, and am having difficulty with the forked audio call. I have set up a recording profile, built-in-bridge etc in CUCM but when I receive the call, it shortly clears with a BYE containing:
Warning: 370 172.27.199.11 "Insufficient Bandwidth"
Reason: Q.850; cause=125
This is after 5 RTP packets. Am I supposed to send RTP back, or RTCP? Also, shouldn't there be a second audio stream?
Thanks.
Geevarghese Cheria
Hi David,
Please check this url for related info - Multiple RTP packets recording. moving your question under UC Manager SIP community for more visibility of support engineers.
Thanks and Regards,
Geevarghese
The error is likely due to 'region' settings for bandwidth allocation and call quality: https://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/telepresence-codec-c40/119207-ts-failures-end-ccm-00.…
My understanding is that call signaling and media setups are somewhat decoupled, which may explain why you receive a brief bit of RTP...
I'm not sure if there are any special considerations or handling with a HCS situation - hopefully between the customer admin and HCS support, they can review the recording architecture vs. their current config, and adjust region/bandwidth settings as needed to accommodate.
