Jabber Login/Logout Tapi
christian.la
i am running some Tapi tests regarding user login or logout using jabber.
Configuration:
cisco tsp 12.5.1
lineNegotiateAPIVersion: : cisco tsp returns tapi version 0x00020001
lineNegotiateExtVersion: cisco tsp returns 0x0000000F.
Registry: EMOptions is 1.
Test scenario:
lineopen returns OK
lineDevSpecific also returns OK at using these parameters
params.m_msgType = Cisco::SLDST_SET_STATUS_MESSAGES;
params.m_statusMsgsFlag = DEVSPECIFIC_OTHER_DEVICE_STATE_NOTIFY;
BUT: cisco tsp doesn't fire any event when user logout or login at Jabber.
Is there anyway to get notification when user login or logout at Jabber?
Many thanks
Christian
dstaudt
I believe you will want to use the standard lineSetStatusMessages (including at least LINEDEVSTATE_INSERVICE and LINEDEVSTATE_OUTOFSERVICE) instead of lineDevSpecific::SLDST_SET_STATUS_MESSAGES (which is needed for non-standard line status messages that are Cisco-only).
This seems to test out for me using TAPI Browser Screenshot-20211007150945-225x78.png
