Highlighted
Beginner
[JTAPI] Disable Caller and Callee Ringer
Hi Everyone,
I was wondering if any of you have been able to implement disabling ringers for called and calling phones?
I have a client requirement which needs me to disable the ringer of the phone being called whenever a specific logic applies.
I know that this could be achieved by updating some columns in AXL but I don't want to do that because it poses problems when the device is no longer connected to the application we're developing.
So the other option is to send out a command to the phone, through XML, that would tell the phone not to ring.
Of course, the call is still ACTIVE it's just that the ringer is muted.
Is this possible?
Please advise.
Cheers!
Everyone's tags (2)
2 REPLIES 2
Highlighted
Contributor
Re: [JTAPI] Disable Caller and Callee Ringer
If you are using JTAPI just call:
     CiscoAddress.setRingerStatus(CiscoAddress.RINGER_DISABLE).
Any of these values are ok (from CiscoAddress.java):
  public static final int RINGER_DEFAULT = 0;
  public static final int RINGER_DISABLE = 1;
  public static final int RINGER_ENABLE = 2;
Check out the CiscoAddress class in the JTAPI Developers Guide for more info.
Best,
Derrick
Beginner
Hi Derrick,
I'll try this out today and let you know and confirm if correct.
Thanks for the help!
