06-19-2014 08:45 AM
Seeing strange behavior when using the JtapiTestTool. I am trying to perform a basic call. However, there is no terminal present to answer the call. This happens when I run the tool on both Mac and linux. Also, I get popups that mention "this function must use treeLock" and I see a ton of stack traces in the console. Attached is a pic of the tool with a CTI port in ALERTing with no terminal to answer it.
Using Java version 1.7
JtapiTestTool 9.0.1
Matt
解決済! 解決策の投稿を見る。
06-19-2014 11:56 AM
Matt,
CTIPorts are used for the call which need a 'Media Terminal Observer'. Right click on the CTIPorts, select 'Add Observer' => Media Terminal Observer on both the devices and retry. Let us know the result.
06-19-2014 11:44 AM
Hi Mohan,
Thanks for the quick response. The new jar works much better. I can now see a terminal and answer the call. However, the call doesn't stay up long. About 12 seconds later, the call drops. Not sure what is going on here. Attached are 2 pics: one of the stack traces from the console, and the other showing the events that occurred during the call.
Matt
06-19-2014 11:56 AM
Matt,
06-19-2014 12:13 PM
Ah yes, media terminal observers. Ok, I added them and it now works. I have a call up. Thanks again, and I'll mark this as 'answered'.
Matt
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
