LUA script to remove "lr" in record-route header
ericlinji
Dear all,
Did anyone know how to remote "lr" in Record-route header to solve the bug CSCux82917?
CSCux82917, it describes:
CUCM cored - SIP Incoming message without Contact Header
CCM service crashing because Message does not contain the contact header on the SIP message, as per RFC 3261:
The Contact header field provides a SIP or SIPS URI that can be used to contact that specific instance of the UA for subsequent requests.
The Contact header field MUST be present and contain exactly one SIP or SIPS URI in any request that can result in the establishment of a dialog.
Workaround:
Disable loose routing from the Server who sends the response Or Use a LUA script to remove 'lr' from the record-route header
We need this LUA script to remove "lr" urgently.  Please help.
Thank you.
Henry
Mark Stover
Hi Henry,
This forum doesn't supply LUA scripts for Unified CM, just provides support and information for developers of those scripts.
I would start with the Developer Guide, which has excellent examples of how getHeader() & modifyHeader() are used, which is what you would have to use here.
https://developer.cisco.com/fileMedia/download/7e805b95-8bd1-46ea-a759-89797326f58b
In general, your script will have to:
1. getHeader for record-route
2. extract the URI
3. manipulate the URI to remove any ";lr" from it
4. modifyHeader to replace the record-route
You will also have to take into account if there is more than one record-route header, so you can manipulate all of them.
HTH,
Mark
