PCM through CUCM
denes.istvan
I'm using CUCM 9.1.
The scenario: I'm making a call from my application to a Cisco IP Communicator and only testing the audio coming from my microphone and listening on the IP Communicator.
The problem is, that when I'm using PCM 16bit 8000Hz format I only hear loud noise, however if I use MuLaw encoding it all sound ok. In the TapiDevGuide it says that Cisco supports both formats as long as they are 16bit 8000Hz.
Is this true?
Geevarghese Cheria
Hi Denes,
I think you can only play record wave files on CUCM  "CTI Ports". 16-bit PCM at 8000Hz format is supported by the TAPI Wave Driver.  Route points and station lines do not support "wave/in" and "wave/out".
Thanks and Regards,
Geevarghese
Geevarghese Cheria
Hi Denes,
Thanks and Regards,
Geevarghese
