Questions about UDS API
tro000001
I'm working as a consultant on a project where we use the UDS API.
I'm working with C# .NET and visual studio.
I have downloaded the xml schemas found here:
https://developer.cisco.com/site/collaboration/management/user-data-services/develop-and-test/schemas/
The problem is that the response we get from the server does not seem to match the schema.
Here is an example xml response when calling user get...
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<user version="9.1.1" uri="https://xxx:8443/cucm-uds/user/xxx">
  <userName>xxx</userName>
  <firstName>xxx</firstName>
  <lastName>xxx</lastName>
  <middleName/>
  <nickName/>
  <phoneNumber>xxx</phoneNumber>
  <homeNumber>xxx</homeNumber>
  <mobileNumber>xxx</mobileNumber>
  <mobileConnect>true</mobileConnect>
  <userLocale>xxx</userLocale>
  <email>xxx</email>
  <msUri>xxx</msUri>
  <department>xxx</department>
  <manager>xxx</manager>
  <title>xxx</title>
  <pager>xxx</pager>
  <useLdapAuth>true</useLdapAuth>
  <directoryUri exist="true">xxx</directoryUri>
  <callerFilters uri="https://xxx:8443/cucm-uds/user/xxx/callerFilters"/>
  <contactAssociations uri="https://10.159.1.40:8443/cucm-uds/user/xxx/contactAssociations"/>
  <contacts uri="https://xxx:8443/cucm-uds/user/xxx/contacts"/>
  <credentials uri="https://xxx:8443/cucm-uds/user/xxx/credentials"/>
  <devices uri="https://xxx:8443/cucm-uds/user/xxx/devices"/>
  <notifications uri="https://xxx:8443/cucm-uds/user/xxx/notifications"/>
  <numbers uri="https://xxx:8443/cucm-uds/user/xxx/numbers"/>
  <phoneLanguage uri="https://xxx:8443/cucm-uds/user/xxx/phoneLanguage"/>
  <profiles uri="https://xxx:8443/cucm-uds/user/xxx/profiles"/>
  <remoteDestinations uri="https://xxx:8443/cucm-uds/user/xxx/remoteDestinations"/>
</user>
It does not seem to match: "user.get.xsd"
Is it a version conflict ? is there a way to get the corresponding schema version to the current installation on the server ?
Best Regards.
Torben Rohde
15 Replies 15
Thank all for your responses. I used to use a partial UDS for searching since version 9.0.x, but manually create java files. Now I just want to create java files from UDS schema so that I can get most features that UDS support; however, I cannot use schema version 11.0 for Jabber server 9.0.x (look likes it's not backwards compatible). I will update my old manual java files to use for old Jabber version though.
Again, thank you for all valuable information.
-Phuong
