sip to sip gateway
neelgagan
Hi Friends,
I have just preparing for cvoice and I have made two sip gateways on gns3 connected with loopback and VM-Net. Xlite phone registered on both gateway seperately.
When i make calls each other it shows media not implemented. The configuration is as follow-
voice service voip
allow-connections sip to sip
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0!
voice register global
mode cme!
voice register dn  1
number 2000!
voice register pool  1
id mac 0050.5639.361C
number 1 dn 1
dtmf-relay sip-notify
username test1 password test1
interface Loopback0
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0
ip address 14.14.14.1 255.255.255.0
interface Serial1/0
ip address 10.10.10.2 255.255.255.0
serial restart-delay 0
dial-peer voice 1 voip
destination-pattern 1...
media flow-around
session protocol sipv2
session target ipv4:10.1.1.1
incoming called-number 1000
sip-ua
authentication username cisco password 7 104D000A0618
registrar ipv4:192.168.20.1 expires 3600
sip-server ipv4:14.14.14.1
Raghavendra G V
are you using TCL IVR script here if not then you can contact Cisco TAC.
Raghavendra
