返信
TCL IVR after 6 to 8 rings IVR started
Humza Khan
we have to reduce the ring time like as I dial PSTN number, IVR should run immediately.
I tried to change the ivr pilot number one time it works great but after that ivr didn't start. Then reverted back. Configs & logs attached.
I am assuming this number aa-pilot 1 is matching with many dialpeers, which causing delay in playing.
Advise required.
1件の返信1
yawming
I don't think script itself control the alerting times.
You mentioned PSTN, if you dialed the same number(connect to a phone not Tcl IVR), how many rings calling/called heard when phone is picked up ? are the numberer different ?
