TCL IVR does play busy tone to PSTN callers
KY_
Enthusiast
Enthusiast
Hello Everyone
I have a problem about TCL IVR in my case  gw does not play busy tone pstn callers. Do you have any ideas what causes the trouble? I have seen smilar case as follows. Call legs is return ls_007  I think some more parameters needs to be added.
Call FLow....
ITSP....E1....ISRG2(2901).....H323 Gw....CUCM... Ip Phone...
https://community.cisco.com/t5/collaboration-documents/tcl-script-does-not-allow-busy-tone-to-pstn-callers/ta-p/3626333
  1. check leg setup status if return ls_007 then play busy tone
    2. replace leg setup by "handoff appl leg_incoming default "DESTINATION=$dnis" . Handoff back to IOS let IOS handle busy tone. But watch if displayinfo is passed.
calling number: 05342992223
called number:   02324638011  then I  dial : 8097
You can see my tcl script and gw trace attached file.
1 ACCEPTED SOLUTION
Looks like some extra character added for below line, while your are converting text file to tcl file.
o;?#TCL IVR Script, accepts calls and plays welcome AA, if busy or no answer, IVR responds
You need to make below changes in your original TCL script and try.
proc act_InvalidExt { } {
    global langselect
    global pilotno
    puts "\n(act_InvalidExt) Entering Procedure\n"
    set status [infotag get evt_status]
        puts "\nDEBUG STATUS: $status\n"
    if { $status == "ls_007" } {
      playtone leg_incoming tn_busy
      timer start leg_timer 5 leg_incoming
      fsm setstate CLEANUP
      return
    playtone leg_incoming tn_none
    if { $status != "ls_000"} {
                puts "\n(act_InvalidExt) Status is not 000. (Status=$status)\n"
                if { $langselect == "Turkish" } {
                        puts "\n(act_InvalidExt) Playing Turkish prompt\n"
                        media play leg_incoming flash:Transfer_To_Operator.au
                if { $langselect == "English" } {
                        puts "\n(act_InvalidExt) Playing English prompt\n"
                leg setup $pilotno callInfo leg_incoming
                puts "\n(act_InvalidExt) Cannot connect so Xfer to OP ($pilotno)\n"
set fsm(SELECTOPT,ev_collectdigits_done)        "act_Collected  TRANSFERTOEXT"
set fsm(SELECTOPTENG,ev_collectdigits_done)     "act_eng_Collected  TRANSFERTOEXT"
Raghavendra
14 REPLIES 14
yawming
set fsm(TRANSFERTOEXT,ev_setup_done) "act_InvalidExt same_state"
In proc act_InvalidExt I don't see you handle ls_007
for example:
proc act_CallSetupDone { } {
global busyPrompt
global legConnected
if { $status == "ls_000" } {
puts "\n Connection success"
handoff appl leg_all default
act_Cleanup
} else {
if { $legConnected == "false" } {
leg proceeding leg_incoming
leg connect leg_incoming
set legConnected true
puts "\n Call failed. Play prompt and collect digit"
if { ($status == "ls_007") } {
set busyPrompt _dest_busy.au
act_Select
Hi Yawming
In my case do need upload  busy.au file  on the flash ? ist it possible to generate busytone  without this file ?
Can you create it on my tcl script ?
Hi ,
You can use below command to play busy tone when you receive ls_007.
Raghavendra
H, Ravindra
Where should be use this command ? on dp delevel or TCL script ?
Can you please do it for me on my TCL file ?
I don't see you haven't set state "TRANSFERTOEXT" anywhere, when you are planning to call procedure act_InvalidExt.
you need to call this in procedure when TCL script get ev_setup_done event with status code ls_007
What you are planning to do after playing busy tone , close the call ?
Raghavendra
Yes,
When the pstn callers hear busy tone then call should be close... Can you create it for me ? I'm not familar TCL
You can test with the attached script, added below code in the script.
      return
Raghavendra
Thank you Raghavendra, I will make test and update you.
KY_
Enthusiast
Enthusiast
Hello I Tried this tcl but its not activated  when the tcl is changed  it does not find by gw.
I found the logs provide but its already cofnigured on dp 65
dial-peer voice 65 pots
service ivr
incoming called-number 0654645645
direct-inward-dial
forward-digits all
This is working TCL.
application
service IVR tcl.tcl
Non working TCL
application
service IVR test_ivr.tcl
Nov 29 09:29:50.420: %CALL_CONTROL-6-APP_NOT_FOUND: Application ivr in dial-peer 65 not found. Handing callid 410703 to the alternate app .
KY_
Enthusiast
Enthusiast
Collected working and non workin calls.
working tcl: test_ivr.tcl
non working: TCL.tcl
    global langselect
    global pilotno
      return
Raghavendra
My original tcl as follows , where should be added additonal l rows ? Im confuse that point.
global langselect
global pilotno
proc donothing { } {
puts "\n(donothing) Cannot end up here\n"
init
set delay 5
# State Machine
set fsm(any_state,ev_disconnected) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_setup_indication) "act_Setup same_state"
set fsm(SELECTOPT,ev_collectdigits_done) "act_Collected same_state"
set fsm(PLACECALL,ev_leg_timer) "act_Cleanup same_state"
set fsm(SELECTOPTENG,ev_collectdigits_done) "act_eng_Collected same_state"
set fsm(CLEANUP,ev_leg_timer) "act_Cleanup same_state"
set fsm(TRANSFERTOOP,ev_media_done) "optransfer same_state"
set fsm(TRANSFERTOEXT,ev_collectdigits_done) "exttransfer same_state"
fsm define fsm CALL_INIT
please make highlighted changes mentioned in the above post into your original script.
Raghavendra
 Hi Raghavendra
 TCL is working perfectly. Thank you :)
