06-03-2019 06:25 AM
Hi guys,
I have been trying to migrate a TCL IVR script from 2900 to ISR router for days, but the router show a lot of erros.
On debug process the most part of the functions are not compatible with the new platform.
The script is very simple with options and make calls.
What do you suggest ?
解決済! 解決策の投稿を見る。
06-05-2019 09:56 PM
06-03-2019 11:04 AM
Can you please share debug log ?
06-03-2019 11:18 AM 06-03-2019 11:36 AM 更新
debug file has been attached.
thanks.
06-03-2019 11:24 AM
Sorry I sent the wrong file. One second..
06-03-2019 12:16 PM
Can you please share information showing "On debug process the most part of the functions are not compatible with the new platform." ? I don't see any alerting from the log attached.
usually these debug can catch most of issues.
06-03-2019 01:27 PM
In that internal debug the script run but it is not following the flow created... Only the null.wav prompt I m able to listen.
06-03-2019 02:19 PM
You still haven't explained what does it mean "On debug process the most part of the functions are not compatible with the new platform." ?
Is it only having the issue playing audio file ?
What protocol is used ? What codec is used ? Codec format of those wav files ? Have you check the codec negotiation is OK ?
If call flow is ok I will dig in more on codec.
06-03-2019 02:35 PM
Another thing I will also try is that load all media files when application started like in
set WelcomePrompt [string trim [infotag get cfg_avpair welwome-prompt]]
06-04-2019 04:25 AM
06-04-2019 04:57 AM
06-04-2019 05:19 AM
06-04-2019 05:32 AM
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
