TCL with CVP
Hi guys I have running on a gw the services tcls for CVP application... but I want the call to match first a TCL that check working hours... and then if its on a working hour send the call to a voip dial-peer which that has associated on CVP application, and if its not a working hour send the call to other CVP application...
In the first TCL I put:
set dest "*5001"
                  leg proceeding leg_incoming
                  leg setup $dest callInfo leg_incoming
                  fsm setstate PLACECALL
and I had a *5001 voip dial peer that call the CVP app....
It´s work all except that when I hang off the call.. the tcl for CVP  close the call perfectly but the first TCL keep 30 seconds before hanging off..
Do you think is better making a handoff from the first TCL to the second rather than connecting the call to the dial-peer that has the second TCL attached ??
1 ACCEPTED SOLUTION
Re: TCL with CVP
I think this has something to do with your CVP script. Not saying anything wrong with that script just that if we want to handoff to other script they are a pair have to have proper hand shaking.
See if we can do this approach. Require a dialpeer for CVP app
handoff appl leg_incoming default "DESTINATION=$pilot_of_CVP"
call close
5 REPLIES 5
Re: TCL with CVP
What I want is just  a TCL to check if the call arrives in a working hour or not,,, and then just execute the TCL for CVP....
I also tried without success
handoff appl leg_incoming aa_pre
After that command the whole call control is passed to the second app (understand that from guide)..
After doing that command what happend on the first TCL it will continue executing more commands  or the session for that Tcl will be closed automatically ??
Highlighted
Re: TCL with CVP
issue "call close" after handoff
handoff appl leg_incoming $aa_pre -s "some string to pass if needed"
call close
Re: TCL with CVP
Still no luck I cant heard any audio from CVP
debug voip app  script
Jul 21 22:00:24.202: //-1/402184338E19/CCAPI/cc_api_call_setup_ind_common:
   Sub Calling(TON=Unknown, NPI=Unknown, Data=r(, Length=61)
   Sub Called(TON=Network, NPI=Unknown, Data=7=\t, Length=3)
Jul 21 22:00:24.202: //983//TCL :/tcl_PutsObjCmd:
Dia de la semana: 1
Hora: 22
Fuera de horas
Jul 21 22:00:24.206: //983//TCL :/tcl_PutsObjCmd:
TCL CVP: ******* Procedure ReturnFromHandoff - returning from VXML Server ******** CallID = 40218433105911E48E19EA2059709E41
TCL CVP: ******* destination = , rona = 60, app = , primary = , backup = , port = , prevapp = , survive = , var1 = , var2 = , var3 = , var4 = , var5 =  ******** CallID = 40218433105911E48E19EA2059709E41
TCL CVP: ******* Initiating transfer from ANI = 1135737052 to DNIS =  ******* CallID = 40218433105911E48E19EA2059709E41
TCL CVP: ******* Procedure TransferDone - status of leg setup is ls_004 ******** CallID = 40218433105911E48E19EA2059709E41
TCL CVP: ******* Call setup failed: CVP reason: ls_004  - disconnecting caller ******* CallID = 40218433105911E48E19EA2059709E41
debug voip app error
Jul 21 22:04:06.846: //-1/C4D64A0A8E1F/CCAPI/cc_api_call_setup_ind_common:
Jul 21 22:04:06.846: //-1//AFW_:/AFW_Module_ParseHandle: ERROR: Expecting separator char after Module name
Jul 21 22:04:06.850: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
Jul 21 22:04:06.850: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
Jul 21 22:04:06.850: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
Jul 21 22:04:06.850: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
Jul 21 22:04:06.850: //984//Dest:/DestQ_AddEntry: Not a valid E.164/URL destination -
Jul 21 22:04:06.850: //984//Dest:/AFW_Destination_AddDest: Destination number/URI is invalid
In the debugs I see like if destination is not valid ???  If I tried to make a leg setup $dest callInfo  (insted of handoff app) and $dest is the pilot of CVP  I heard the audio .. the same if I directly apply the CVP script to the incomming dial peer
Re: TCL with CVP
call close
Re: TCL with CVP
I was trying handoff appl leg_incoming aa_app "DESTINATION=$dest"
forgot to change aa_pp for default app
Now that you remember me to do that works like a charm....
Content for Community-Ad
August's Community Spotlight Awards
