Community Helping Community
875
Beginner
Re: Total newbie looking for assistance with TCL - SIP and Hookflash to FXO
I am going through the logs - I see:
p  9 03:52:05.741: (CALLDISCONNECT(2), ev_leg_timer(1)--(act_Cleanup)-->(any_state(0))
Sep  9 03:52:05.741: (IVRACTIVE(3), ev_transfer_request(230)--(act_IVRActive)-->(SENDHFLASH(4))
Sep  9 03:52:05.741: (CALLDISCONNECT(2), ev_media_done(200)--(act_Cleanup)-->(any_state(0))
Sep  9 03:52:05.741: (SENDDIGITS(5), ev_media_done(200)--(act_DigitSend)-->(CALLEND(6))
Sep  9 03:52:05.741: (SENDHFLASH(4), ev_disconnect_done(23)--(act_HookFlash)-->(SENDDIGITS(5))
Sep  9 03:52:05.741: (any_state(0), ev_disconnected(22)--(act_Cleanup)-->(any_state(0))
Sep  9 03:52:05.741: (CALLEND(6), ev_media_done(200)--(act_Cleanup)-->(CALLDISCONNECT(2))
Sep  9 03:52:05.741: (CALLDISCONNECT(2), ev_disconnect_done(23)--(act_Cleanup)-->(any_state(0))
Sep  9 03:52:05.741: (CALLDISCONNECT(2), ev_disconnected(22)--(act_Cleanup)-->(any_state(0))
Sep  9 03:52:05.741: (CONNECTIVR(7), ev_setup_done(257)--(act_IVRConnected)-->(IVRACTIVE(3))
Sep  9 03:52:05.741: (CALL_INIT(1), ev_setup_indication(37)--(act_Setup)-->(CONNECTIVR(7))
Sep  9 03:52:05.741: FSM start state CALL_INIT(1)
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/Tcl_Link: Script hookflash succesfully linked.
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/AFW_ExecEnv_SetScript: Num of packTable entries: 26
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/AFW_ExecEnv_RestoreDataBackup: Script DataArea empty, do backup
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/AFW_ExecEnv_RestoreDataBackup: Script TokenTable empty, do backup
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/AFW_ExecEnv_Initiate: Execenv = 0x3E7F4100
Sep  9 03:52:05.741: //-1//AFW_:EE3E7F4100000:/AFW_ExecEnv_SetCallCorID:
Sep  9 03:52:05.741:  CallCorID is  Ig}WW,p
so I think I'm close - as I'm seeing the ev_transfer_request and the sendhflash
if this is working i'll need to somehow modify this so it's not tied to this specific IVR number of 253 (I sent it to 101) - it would be good to have this invoked and have the voice port connect to the appropriate number via the connection plar opx XXX command and not have it hardwired.  then - if this is working it could be used for all numbers.   anyways - was exciting to see the SENDHFLASH message....
cheers.
Hi Jim,
Is call answered at sip phone as I don't see call setupdone event in the logs. I don't see any sip refer message also.
Raghavendra
Highlighted
Beginner
Hi. The call original ages from the fxo to the 8851 sip phone registered on another CME at 10.10.20.90. Once I had the call established i pressed transfer on the 8851 (far end CME) - and then those event messages on the fxo router were created.
I thought that the script triggered those messages based on the transfer button being pressed causing a sip refer - but I guess not.  I'll look at it again.
There is a sip trunk between the router with the fxo and the CME with the 8851 registered.   I figured this was the best way to simulate the environment as they have sip clients registered off of a proxy server and that talks to their 2921 router.  They also have similar sip protocol based dual peers.
Should I be looking for some messages on the cme side as well - se if it sends sip refer to fxo router where the tcl script is loaded on the pots dial peer?  No reason to load the script on the dial beer from the fxo router out to the CME is there?
Jim
Hi Jim,
I don't see any SIP refer message or ev_transfer request in the logs which you attached. when you transfer from CME sip phone you need to look for refer message in FXO router.
You can also try jimflash.tcl which can receive DTMF digits.you need a small change in script to send hookflash to incoming leg when it recieve * and then the rest of digits.
proc act_ProcessDTMF { } {
# get the dtmf and duration
     set dtmf_value [infotag get evt_digit]
     set dtmf_duration [infotag get evt_digit_duration]
     if {$dtmf_value == "*"} {
          leg sendhookflash leg_incoming
     } else {
# ok, not a * so playout the dtmf event with the same duration
          leg senddigit leg_incoming $dtmf_value -t $dtmf_duration
Raghavendra
Beginner
hi
I made the changes to jimflash.tcl - applied it to the dial-peer.  when the call came in (after a reboot of router) when I hit * I put the far end on hold...  awesome.   this is my home line and I'm not sure I have capability to transfer so will try at site.  I heard dial tone on the ip phone, and on the phone call that was called in - I heard that I was on hold.
The mechanism for transfer should just be dialing digits and hanging up as technically the dial tone heard was from the FXS on the other side of the FXO (in this case my home telephone line provider).   Will test at site.
thanks.
Jim
Beginner
Tested at site - and on the inbound call from the FXO the call is immediately placed on hold.  The caller hears ringback and then MOH from the ACD that is transfering out of the PBX to the FXO on the router.  So i think the app is flashing the PBX, but why?  it's not lettign the call get through and having the user initiate the flash.  I see invalid command "B" in the logs.   Any reason why it would be triggered?
There is some error in the script ( jimflash_mod.tcl ) might be some typo. could you please share the script.
Raghavendra
In your previous putty logs, I see hookflash is sent to incoming leg, but there is some error in jimflash_mod.tcl. Please make sure both scripts are same.
Sep 11 12:37:09.770: //15//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALLACTIVE[3],ev_digit_end[20])---[act_ProcessDTMF]------
Sep 11 12:37:09.770: //15//TCL :/tcl_InfotagObjCmd:  infotag get evt_digit
Sep 11 12:37:09.770: //15//TCL :/tcl_InfotagGetObjCmd: infotag get evt_digit
Sep 11 12:37:09.770: //15//AFW_:/vtr_ev_digit: argc 2
Sep 11 12:37:09.770: //15//AFW_:/vtr_ev_digit: digit=*
Sep 11 12:37:09.770: //15//TCL :/tcl_InfotagObjCmd:  infotag get evt_digit_duration
Sep 11 12:37:09.770: //15//TCL :/tcl_InfotagGetObjCmd: infotag get evt_digit_duration
Sep 11 12:37:09.770: //15//AFW_:/vtr_ev_digdur: argc 2
Sep 11 12:37:09.770: //15//AFW_:/vtr_ev_digdur: duration=330
Sep 11 12:37:09.770: //15//TCL :/tcl_LegObjCmd:  leg sendhookflash leg_incoming
Sep 11 12:37:09.770: //15//TCL :/tcl_LegSendHookflashObjCmd: sendhookflash leg_incoming
Sep 11 12:37:09.770: //15//AFW_:/vtd_lg_incoming: argc 2
Sep 11 12:37:09.770: //15//AFW_:/vtd_lg_incoming: Legs [15 ]
Raghavendra
Beginner
Thanks - I am at site tomorrow and will grab some logs.  I think the far end system does not support dtmf-relay rtp-nte.  will let you know what I find - thanks.
jim
Beginner
Hi Rahavendra,
I was at site this AM and tested - I was able to generate a hookflash from the TCL script when using  an 8851 registered to the CME via SIP out the local FXO.  I applied the TCL to the FXO port and it worked.  When I tried using the SIP soft client they have I was not able to make it work.  I can see the * but the tone duration is 150 ms whereas I think on the the 8851 it is 380 ms.  Or maybe it's a difference of the DTMF encoding - the 8851 uses RTP-NTE, and i'm not sure what their softclient does.  Either way - I was able to grab dial tone via the flashhook initiated by the *.  Are you able to see what the differences could be?
thanks,
Jim
I think it is config issue,looks like soft client sending digits as SIP Info. try to configure as dtmf as below.
dtmf-relay sip-notify
Raghavendra
Beginner
ok - we will try that.  Thanks.    DTMF detection will work for rtp-nte (we've seen that) and hopefully it's supported for sip-info - i'm not in front of my router now, but sip-notify enables dtmf for SIP info?
Jim
sip-notify for dtmf same as rtp-nte. If rtp-nte works you can use that.
Raghavendra
Beginner
The solution - pbx - is from Frequentis - specialized equipment.  The do SIP-Info - is this the same as SIP-NOTIFY?  They were not successful with that test.  I'm wondering if I look at specific SIP messaging to try and trigger the hookflash if they can't generate the proper DTMF.  Any suggestions?
If they can't generate DTMF digits, the other option is to get ev_transfer_request for SIP refer transfer.
You should see below log when TCL script get ev_transfer_request after SIP refer message.
050275: *Sep 11 07:02:40.601: //88//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IVRACTIVE[3],ev_transfer_request[222])---[act_IVRActive]------
050276: *Sep 11 07:02:40.601: //88//TCL :/tcl_InfotagObjCmd:  infotag get evt_transfer_info transferDest
050277: *Sep 11 07:02:40.601: //88//TCL :/tcl_InfotagGetObjCmd: infotag get evt_transfer_info transferDest
050278: *Sep 11 07:02:40.601: //88//AFW_:/vtr_ev_transfer_info: argc 3 argindex 2
050279: *Sep 11 07:02:40.601: //88//AFW_:/vtr_ev_transfer_info:  transferTo
Raghavendra
Content for Community-Ad
FusionCharts will render here
