03-06-2018 09:56 AM
I'm trying to match bib cisco invite to its corresponding cti event. For instance for a particular call, the cisco bib guid is: 0429206016-0000065536-0000000135-1665425418. However in the begin call event, the user.media.id value is "92100AD201E820C19E15000825A05F30". Are those two values related? If so how do i convert between the two?
03-06-2018 02:09 PM
I believe the tie-in is via the global call ID for the call. This should be found in the 'x-refci' field of the SIP FROM: header, and and via JTAPI CiscoCallID.GetGlobalCallID()
03-07-2018 10:27 AM
So essentially i can't get this info from the PG?
03-08-2018 09:28 AM
When you say CTI events, I'm assuming that you are using the GED188 CTI protocol. To get the global call Id of the call from the begin call event, it is the ConnectionCallID field. See the BEGIN_CALL_EVENT table from the documentation.
Thanx,
Denise
03-08-2018 09:31 AM
Denise that is precisely what i mean however what i have noticed is thte the connection call id field does not match anything in the cisco bib siprec invite.
03-08-2018 09:37 AM
I don't know much about the Cisco Bib siprec invite, but per David's suggestion, you should be able to get the Call Id of the bib siprect invite.
That call id should match the ConnectionCallID from the begin call event.
03-08-2018 10:00 AM
I just did a test in my lab. The connection call id was: 16789617. The x-refci was: 22155891
03-08-2018 10:36 AM
Hm...looking at the CTI spec, the only other one I can think of is
03-08-2018 10:40 AM
I have a feeling that the only way to get this info would be through the jtapi interface.
03-08-2018 11:13 AM
The call ID is not limited to JTAPI/TAPI - it's global CUCM thing. You can do recording (i.e. always on) without having any CTI app or involvement at all.
I don't know enough about PG APIs to know which particular variable (if any) contains the right call ID. I might recommend opening a ticket with DevNet Developer Support - they will be able to engage with the right engineering folks to get a more definitive answer: https://developer.cisco.com/site/devnet/support/
AFAIK CTI-integrated recording situations were envisioned with TAPI/JTAPI in mind (I've not run into anyone trying to do it via PG APIs), though if you can map the global call ID as described, I don't see why it wouldn't be possible.
03-08-2018 11:17 AM
Thank you all for the very helpful answers. What i have decided is to use the extension provided by sip rec and tie that (loosely) to the cti by always keeping track of the current call id that the extension is on. I have found this to be working quite well. I wanted a tighter way to tie the audio to the cti events but for now the extension will do.
