ucxsi not receiving ringing notification
tj1
I'm having problem where the application is not receiving ringing notification event. It is receiving OUT_OF_SERVICE and BACK_IN_SERVICE.
ID   DN Num     Tag Mac          MRef CreateTime           #Msg
32625 66363      0   001AA1E55F70 0    Apr 22 2015 06:09:11 7
#MSG corresponds with the OUT_OF_SERVICE and BACK_IN_SERVICE message being received.
Looks like you are passing empty call, please try to get CMECall from CMECallConnectionRingingEvent  and pass to answer method.
Raghavendra
14 Replies 14
Raghavendra G V
Please share the SDK debugs, hope you have implemented the CMECSTAListener.
Raghavendra
Hi Raghavendra,
debug below. Yes, I have implemented the CMECSTAListener.
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 1 to index 119
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1727E524 with refCount = 1
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13BF0BC8 with refCount = 1
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1727E524
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, connid=119, transport=TCP
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 59575 connId 119
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.28.218.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.28.250.93:5070;branch=z9hG4bK9bkDTjwKc7Ez15sTfoNEXQ~~5
Max-Forwards: 70
To: <sip:davecallconnector@172.28.218.1>
From: <sip:davecallconnector@172.28.218.1>;tag=dsd1b2e01f
Call-ID: 14296485727041@172.28.218.1
CSeq: 4 REGISTER
Content-Length: 0
Contact: <sip:null@172.28.250.93:5070;transport=tcp>;expires=120
X-cisco-session-server: davecallconnector
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFindRegisterCcb: *****CCB NOT found in UAS Request table. ccb=0x0
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D6F0F0) with key=[5652] to table
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/verbose/4608/sipSPISipIncomingMsg: copy the natted transport info to ccb natted dest: 172.28.250.93:59575,natted src: 172.28.218.1:5060, natted transport: 2
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/info/1024/sipSPISipIncomingMsg:  sip via host 172.28.250.93
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/info/9216/sipSPISipIncomingMsg:  sip nat auto detect 0
Apr 21 20:37:40.764: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 172.28.254.130 for SIP
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 172.28.254.130
Apr 21 20:37:40.764: //-1/16E06104AA98/SIP/State/sipSPIChangeState: 0x15D6F0F0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5060vrfid 0
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:37:40.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x13BF0BC8) counter, current msg->refCount = 2
Apr 21 20:37:40.764: //-1/16E06104AA98/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D6F0F0)->last_request = 0x13BF0BC8, refCount = 2
Apr 21 20:37:40.764: //-1/16E06104AA98/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x15D6F0F0 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f balance 0
Apr 21 20:37:40.764: //32697/16E06104AA98/SIP/Event/sact_idle_new_message_register:
ccsip_api_register_ind return value : SIP_SUCCESS
Apr 21 20:37:40.764: //32697/16E06104AA98/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 7FB9 to table
Apr 21 20:37:40.764: //32697/16E06104AA98/SIP/State/sipSPIChangeState: 0x15D6F0F0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
Apr 21 20:37:40.764: //32697/16E06104AA98/SIP/Info/notify/262144/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: registration expires timer max is 3600 and min is 60
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/ccsip_process_registration_passthrough: RCB Pointer : [0x174F4B58]
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/critical/262144/ccsip_process_registration_passthrough: Re-Register not for passthrough, Try CME
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/info/262144/ccsip_spi_register_incoming_registration: Register for CME case
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: CCSIP_REGISTER:: re-REGISTER request
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/262144/ccsip_spi_update_cc_callid: ccCallId for RCB is 32690
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILineGetVersionStr:
Failed to get supported header value
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern davecallconnector for 120 seconds
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Error/ccsipCheckVoiceRegSupportedFeatures:
Unable to access supported header values
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 41
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 13 event
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1727E524 with refCount = 1
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/info/4096/sipSPISendResponse: Associated container=0x102EF370 to REGISTER Response 200
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Transport/sipSPITransportSendMessage: msg=0x1727E524, addr=172.28.250.93, port=59575, sentBy_port=5070, local_addr=, is_req=0, transport=2, switch=0, callBack=0x97DA6F8
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x1727E524, addr=172.28.250.93, port=59575, local_addr=, connId=119 vrfid=0 for TCP
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x15D6F0F0 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 7FB9
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5652] removed.
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x13BF0BC8) counter, current msg->refCount = 1
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, unregistering context=0x15D6F0F0
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Transport/sipSPITransportContextCleanup: Could not purge context gcb=0x15D6F0F0 from the connection; gcb might be locked
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13BF0BC8
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Apr 21 20:37:40.768: //32697/16E06104AA98/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x15D6F0F0
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[5652]
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb has cleanedup, Done with send operations for this context
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 119, fd: 1
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:davecallconnector@172.28.218.1>;tag=83E69AEC-1BDA
Date: Tue, 21 Apr 2015 20:37:40 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 4 REGISTER
X-cisco-referenceID: FB47A3FE
Contact: <sip:davecallconnector@172.28.250.93:5070;transport=tcp>;expires=60
Expires:  60
Content-Length: 0
Apr 21 20:37:40.768: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1727E524
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for davecallconnector
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_cc_call_id_table:
Entry not found for search key
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_reg_delete_from_call_id_table: ****Delete from sipCallID Table
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/ccsipGetCCBFromRCB: Retrived CCB pointer [0x0]
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_register_free_rcb:
Error in unregistering davecallconnector@172.28.250.93
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIFreePthruDataFromRPCBorRCB: RCB =[0x102BD7B4].. RPCB =[0x0]
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/9216/sipSPIPassThruHdrContainerFreeHelper: Data -->[0x0]
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper:
Null ContentQ - Exit
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_rpcb_search_cc_call_id_table:
No entry found in ccCallID Table
Apr 21 20:37:44.844: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_free_rcb: Freeing rcb [0x102BD7B4]
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5650] removed.
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/info/4096/sipSPIStopCommonTimer: Stopping Generic Timer 2
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: free ccb->call_info.origRedirectNumber
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x15D4F188 key=CEF395E-E79D11E4-AA97AB81-28935809@172.28.218.1
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x4006816C
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x25C4564, addr=172.28.218.2, port=5060, local_addr=, unregistering context=0x15D4F188
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x15D4F188 from the connection=0x25C4E38 context list
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Apr 21 20:38:00.068: //32696/0CED64E6AA93/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x15D4F188
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/act_subscription_terminated: Resetting server EDB flag
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/info/4096/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/act_subscription_terminated: Resetting Client EDB flag
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneEDB: DeQ'd EDB(0x2A63E64)
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFreeOneEDB: EnQing EDB(0x2A63E64) for reuse
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/sipSPITerminateEvent: Freeing SCB(0x42A3111C), 0 active events present
Apr 21 20:38:00.068: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5651] removed.
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/sipSPIRemoveSCBFromClientTable: Removing SCB(0x42A3111C) with Key(CEF395E-E79D11E4-AA97AB81-28935809@172.28.218.183E659C4-1A8D) from Client Table
Apr 21 20:38:00.068: //0/000000000000/SIP/Info/verbose/4096/sipSPIFreeOneSCB: EnQing SCB(0x42A3111C) for reuse
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 1 to index 119
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, connid=119, transport=TCP
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 59575 connId 119
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.28.250.93:5070;branch=z9hG4bK9bkDTjwKc7Ez15sTfoNEXQ~~6
Max-Forwards: 70
CSeq: 5 REGISTER
Content-Length: 0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFindRegisterCcb: *****CCB NOT found in UAS Request table. ccb=0x0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D4F188) with key=[5653] to table
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/verbose/4608/sipSPISipIncomingMsg: copy the natted transport info to ccb natted dest: 172.28.250.93:59575,natted src: 172.28.218.1:5060, natted transport: 2
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/info/1024/sipSPISipIncomingMsg:  sip via host 172.28.250.93
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/info/9216/sipSPISipIncomingMsg:  sip nat auto detect 0
Apr 21 20:38:10.832: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 172.28.254.130 for SIP
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 172.28.254.130
Apr 21 20:38:10.832: //-1/28CC62ACAA99/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5060vrfid 0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x47020AE0) counter, current msg->refCount = 2
Apr 21 20:38:10.832: //-1/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D4F188)->last_request = 0x47020AE0, refCount = 2
Apr 21 20:38:10.832: //-1/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f balance 0
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Event/sact_idle_new_message_register:
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 7FBA to table
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/notify/262144/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: registration expires timer max is 3600 and min is 60
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/ccsip_process_registration_passthrough: RCB Pointer : [0x174F4B58]
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/critical/262144/ccsip_process_registration_passthrough: Re-Register not for passthrough, Try CME
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/info/262144/ccsip_spi_register_incoming_registration: Register for CME case
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: CCSIP_REGISTER:: re-REGISTER request
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/262144/ccsip_spi_update_cc_callid: ccCallId for RCB is 32690
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILineGetVersionStr:
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern davecallconnector for 120 seconds
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Error/ccsipCheckVoiceRegSupportedFeatures:
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 41
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 13 event
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/info/4096/sipSPISendResponse: Associated container=0x102F0B80 to REGISTER Response 200
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Transport/sipSPITransportSendMessage: msg=0x13F54F14, addr=172.28.250.93, port=59575, sentBy_port=5070, local_addr=, is_req=0, transport=2, switch=0, callBack=0x97DA6F8
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x13F54F14, addr=172.28.250.93, port=59575, local_addr=, connId=119 vrfid=0 for TCP
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 7FBA
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5653] removed.
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x47020AE0) counter, current msg->refCount = 1
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, unregistering context=0x15D4F188
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Transport/sipSPITransportContextCleanup: Could not purge context gcb=0x15D4F188 from the connection; gcb might be locked
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Apr 21 20:38:10.832: //32698/28CC62ACAA99/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x15D4F188
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[5653]
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb has cleanedup, Done with send operations for this context
Apr 21 20:38:10.832: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 119, fd: 1
Sent:
SIP/2.0 200 OK
To: <sip:davecallconnector@172.28.218.1>;tag=83E71060-D80
Date: Tue, 21 Apr 2015 20:38:10 GMT
CSeq: 5 REGISTER
Expires:  60
Content-Length: 0
dcmhrc02#show cti session
32691 66363      0   001AA1E55F70 0    Apr 22 2015 06:36:15 1
dcmhrc02#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
dcmhrc02(config)#ephone
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 1 to index 119
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, connid=119, transport=TCP
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 59575 connId 119
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.28.250.93:5070;branch=z9hG4bK9bkDTjwKc7Ez15sTfoNEXQ~~7
Max-Forwards: 70
CSeq: 6 REGISTER
Content-Length: 0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFindRegisterCcb: *****CCB NOT found in UAS Request table. ccb=0x0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D4F188) with key=[5654] to table
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/verbose/4608/sipSPISipIncomingMsg: copy the natted transport info to ccb natted dest: 172.28.250.93:59575,natted src: 172.28.218.1:5060, natted transport: 2
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/info/1024/sipSPISipIncomingMsg:  sip via host 172.28.250.93
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/info/9216/sipSPISipIncomingMsg:  sip nat auto detect 0
Apr 21 20:38:40.896: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 172.28.254.130 for SIP
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 172.28.254.130
Apr 21 20:38:40.896: //-1/3AB7C792AA9A/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5060vrfid 0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x47020AE0) counter, current msg->refCount = 2
Apr 21 20:38:40.896: //-1/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D4F188)->last_request = 0x47020AE0, refCount = 2
Apr 21 20:38:40.896: //-1/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f balance 0
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Event/sact_idle_new_message_register:
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 7FBB to table
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/notify/262144/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: registration expires timer max is 3600 and min is 60
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/ccsip_process_registration_passthrough: RCB Pointer : [0x174F4B58]
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/critical/262144/ccsip_process_registration_passthrough: Re-Register not for passthrough, Try CME
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/info/262144/ccsip_spi_register_incoming_registration: Register for CME case
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: CCSIP_REGISTER:: re-REGISTER request
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/262144/ccsip_spi_update_cc_callid: ccCallId for RCB is 32690
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILineGetVersionStr:
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern davecallconnector for 120 seconds
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Error/ccsipCheckVoiceRegSupportedFeatures:
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 41
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 13 event
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/info/4096/sipSPISendResponse: Associated container=0x102F0B80 to REGISTER Response 200
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Transport/sipSPITransportSendMessage: msg=0x13F54F14, addr=172.28.250.93, port=59575, sentBy_port=5070, local_addr=, is_req=0, transport=2, switch=0, callBack=0x97DA6F8
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x13F54F14, addr=172.28.250.93, port=59575, local_addr=, connId=119 vrfid=0 for TCP
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 7FBB
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5654] removed.
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x47020AE0) counter, current msg->refCount = 1
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, unregistering context=0x15D4F188
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Transport/sipSPITransportContextCleanup: Could not purge context gcb=0x15D4F188 from the connection; gcb might be locked
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Apr 21 20:38:40.896: //32699/3AB7C792AA9A/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x15D4F188
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[5654]
Apr 21 20:38:40.896: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb has cleanedup, Done with send operations for this context
Apr 21 20:38:40.900: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event ty 1
dcmhrc02(config-ephone)#pe: send msg, connid: 119, fd: 1
Apr 21 20:38:40.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:davecallconnector@172.28.218.1>;tag=83E785D0-BC0
Date: Tue, 21 Apr 2015 20:38:40 GMT
CSeq: 6 REGISTER
Expires:  60
Content-Length: 0
Apr 21 20:38:40.900: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14reset
resetting 001A.A1E5.5F70
Apr 21 20:38:44.536: //CTI/LM:cti_update_cme_line_status mac addr 001AA1E55F70 number 66363 line status 0 normal 1 line removed 0 line shared 0 cti notify 1
Apr 21 20:38:44.536: //CTI/SM:sm_find_context_ids_by_line num 66363, tag 0, mac 001AA1E55F70, prev 0, expanded 0
Apr 21 20:38:44.536: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:38:44.536: //CTI/CM:    target_node 16FD7830
Apr 21 20:38:44.536: //CTI/CM:   - dn 66363
Apr 21 20:38:44.536: %IPPHONE-6-UNREGISTER_NORMAL: ephone-1:SEP001AA1E55F70 IP:172.28.218.138 Socket:63 DeviceType:Phone has unregistered normally.
Apr 21 20:38:44.536: //CTI/LM:lmm_process_cti_event event 15
Apr 21 20:38:44.536: //CTI/LM:lmm_process_cti_event event 14
Apr 21 20:38:44.536: //CTI/SM:sm_process_lmm_event event 15
Apr 21 20:38:44.536: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:38:44.536: //CTI/SM:    to return 1544C8B0
Apr 21 20:38:44.536: //CTI/PI:pi_send_log_event event 15 context_id 32691
Apr 21 20:38:44.536: //CTI/PI:pi_build_event event 15
Apr 21 20:38:44.536: //CTI/XI:cti2csta:1076 cti_ev_type_t(15)
Apr 21 20:38:44.536: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=(001AA1E55F70)
Apr 21 20:38:44.536: //CTI/XI:cti2csta_cause: cti_cause = 1
Apr 21 20:38:44.536: //CTI/XI:cti2csta:2169 csta_EventType_t(45)
Apr 21 20:38:44.536: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(295), message(295)
<?xml version="1.0" encoding="UTF-8"?>
  <OutOfServiceEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>
    </monitorCrossRefID>
    <device>
      <deviceIdentifier>tel:66363;device=001AA1E55F70</deviceIdentifier>
    </device>
    <cause>normal</cause>
  </OutOfServiceEvent>
Apr 21 20:38:44.536: //CTI/SM:sm_process_lmm_event event 14
Apr 21 20:38:44.536: //CTI/PI:pi_send_log_event event 14 context_id 32691
Apr 21 20:38:44.536: //CTI/PI:pi_build_event event 14
Apr 21 20:38:44.536: //CTI/XI:cti2csta:1076 cti_ev_type_t(14)
Apr 21 20:38:44.536: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=()
Apr 21 20:38:44.536: //CTI/XI:cti2csta:2169 csta_EventType_t(44)
Apr 21 20:38:44.536: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(255), message(255)
  <BackInServiceEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>
    <device>
      <deviceIdentifier>tel:66363</deviceIdentifier>
    </device>
  </BackInServiceEvent>
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 34
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/verbose/4096/act_active_info_request: Transaction active. Facilities/INFO requests will be queued.
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 5 event
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102F1260 to Info
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 295
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPISendInfo: Sending INFO to the transport layer
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x13F54F14, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, unregistering context=0x15D62460
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Could not purge context gcb=0x15D62460 from the connection; gcb might be locked
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.250.93, rport:5070 with laddr:
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x15D62460 with connection=0x426367C4 context list
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x13F54F14
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x13F54F14, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/info/512/sentInfo: Sent Info Request, starting InfoTimer
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102E4790 to Info
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 255
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x47020AE0, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x15D62460 is already on connection=0x426367C4 context_list
Apr 21 20:38:44.536: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x47020AE0
Apr 21 20:38:44.536: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x47020AE0, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:38:44.540: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 120, fd: 2
Apr 21 20:38:44.540: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Sent:
INFO sip:66363_001AA1E55F70@172.28.250.93:5070;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B01385
To: CME_SDK <sip:66363_001AA1E55F70@csta-sdk>;tag=dsd548f03c
Date: Tue, 21 Apr 2015 20:36:14 GMT
Call-ID: 14296485768312@192.168.1.10
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M1
Max-Forwards: 70
Timestamp: 1429648724
CSeq: 101 INFO
Contact: <sip:66363@172.28.254.130:5060;transport=tcp>
Content-Type: application/csta+xml
Content-Disposition: signal;handling=required
Content-Length: 295
<monitorCrossRefID></monitorCrossRefID>
<device>
<deviceIdentifier>tel:66363;device=001AA1E55F70</deviceIdentifier></device>
<cause>normal</cause></OutOfServiceEvent>
Apr 21 20:38:44.540: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:38:44.540: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sip_tcp_sendmsg: Socket blocked data queued
Apr 21 20:38:44.540: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipTcpQueueSendData: Data queued length: 835
Apr 21 20:38:44.540: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:44.548: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_resend: Socket blocked requeue data
Apr 21 20:38:44.556: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_resend: Socket blocked requeue data
Apr 21 20:38:44.564: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_resend: Socket blocked requeue data
Apr 21 20:38:44.576: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_resend: Socket blocked requeue data
Apr 21 20:38:44.584: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:44.584: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B1E8B
Max-Forwards: 70
CSeq: 102 INFO
Content-Length: 255
<device>
<deviceIdentifier>tel:66363</deviceIdentifier></device></BackInServiceEvent>
Apr 21 20:38:44.584: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 2 to index 120
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x42635D70
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=5070, local_addr=, connid=120, transport=TCP
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5070 connId 120
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Info/info/1024/sipSPIMatchRespToReqTran: match z9hG4bK24B01385 to via_branch_list - remove and continue
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x15D62460
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x13F54F14) counter, current msg->refCount = 2
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INFO
Content-Length: 0
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Info/verbose/4096/sact_active_new_message_response: Transaction Complete. Lock on Facilities/INFO released.
Apr 21 20:38:44.592: //32691/E3856E28AA86/SIP/Info/verbose/32768/ccsip_api_info_done: RTP_LPBK == FALSE, checkpoint HA data
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x13F54F14) counter, current msg->refCount = 1
Apr 21 20:38:44.592: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:38:44.592: //CTI/PI:cti_frontend_proc [7FB3]: received CC Event [21]: CC_EV_CALL_INFO_ACK
Apr 21 20:38:44.592: //CTI/PI:pi_process_service_event event 21
Apr 21 20:38:44.592: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 32691
Apr 21 20:38:44.592: //CTI/SM:sm_handle_cc_service event 85
Apr 21 20:38:44.592: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:38:44.596: //CTI/SM:    to return 1544C8B0
Apr 21 20:38:44.596: //CTI/SM:    got CTI_EV_ACK, callID 32691
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 2 to index 120
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x42635D70
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=5070, local_addr=, connid=120, transport=TCP
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5070 connId 120
Apr 21 20:38:44.632: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK24B1E8B from via branch list
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x15D62460
Apr 21 20:38:44.636: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x47020AE0) counter, current msg->refCount = 2
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 INFO
Content-Length: 0
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Info/verbose/4096/sact_active_new_message_response: Transaction Complete. Lock on Facilities/INFO released.
Apr 21 20:38:44.636: //32691/E3856E28AA86/SIP/Info/verbose/32768/ccsip_api_info_done: RTP_LPBK == FALSE, checkpoint HA data
Apr 21 20:38:44.636: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x47020AE0) counter, current msg->refCount = 1
Apr 21 20:38:44.636: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:38:44.636: //CTI/PI:cti_frontend_proc [7FB3]: received CC Event [21]: CC_EV_CALL_INFO_ACK
Apr 21 20:38:44.636: //CTI/PI:pi_process_service_event event 21
Apr 21 20:38:44.636: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 32691
Apr 21 20:38:44.636: //CTI/SM:sm_handle_cc_service event 85
Apr 21 20:38:44.636: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:38:44.636: //CTI/SM:    to return 1544C8B0
Apr 21 20:38:44.636: //CTI/SM:    got CTI_EV_ACK, callID 32691
dcmhrc02(config-ephone)#^Z
dcmhrc02#sh
Apr 21 20:38:47.544: %SYS-5-CONFIG_I: Configured from console by network on vty8 (172.28.250.93)ow cti sess
32691 66363      0   001AA1E55F70 0    Apr 22 2015 06:36:15 3
dcmhrc02#
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 1 to index 119
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13F54F14 with refCount = 1
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1060BAF8 with refCount = 1
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, connid=119, transport=TCP
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 59575 connId 119
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.28.250.93:5070;branch=z9hG4bK9bkDTjwKc7Ez15sTfoNEXQ~~8
Max-Forwards: 70
CSeq: 7 REGISTER
Content-Length: 0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFindRegisterCcb: *****CCB NOT found in UAS Request table. ccb=0x0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D4F188) with key=[5655] to table
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/verbose/4608/sipSPISipIncomingMsg: copy the natted transport info to ccb natted dest: 172.28.250.93:59575,natted src: 172.28.218.1:5060, natted transport: 2
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/info/1024/sipSPISipIncomingMsg:  sip via host 172.28.250.93
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/info/9216/sipSPISipIncomingMsg:  sip nat auto detect 0
Apr 21 20:39:10.964: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 172.28.254.130 for SIP
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 172.28.254.130
Apr 21 20:39:10.964: //-1/4CA3C8A1AA9B/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5060vrfid 0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x1060BAF8) counter, current msg->refCount = 2
Apr 21 20:39:10.964: //-1/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D4F188)->last_request = 0x1060BAF8, refCount = 2
Apr 21 20:39:10.964: //-1/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f balance 0
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Event/sact_idle_new_message_register:
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 7FBC to table
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/notify/262144/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: registration expires timer max is 3600 and min is 60
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/ccsip_process_registration_passthrough: RCB Pointer : [0x174F4B58]
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/critical/262144/ccsip_process_registration_passthrough: Re-Register not for passthrough, Try CME
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/info/262144/ccsip_spi_register_incoming_registration: Register for CME case
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: CCSIP_REGISTER:: re-REGISTER request
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/262144/ccsip_spi_update_cc_callid: ccCallId for RCB is 32690
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILineGetVersionStr:
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern davecallconnector for 120 seconds
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Error/ccsipCheckVoiceRegSupportedFeatures:
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 41
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 13 event
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/info/4096/sipSPISendResponse: Associated container=0x102F24F0 to REGISTER Response 200
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Transport/sipSPITransportSendMessage: msg=0x13F54F14, addr=172.28.250.93, port=59575, sentBy_port=5070, local_addr=, is_req=0, transport=2, switch=0, callBack=0x97DA6F8
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x13F54F14, addr=172.28.250.93, port=59575, local_addr=, connId=119 vrfid=0 for TCP
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x15D4F188 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 7FBC
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[5655] removed.
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x1060BAF8) counter, current msg->refCount = 1
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, unregistering context=0x15D4F188
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Transport/sipSPITransportContextCleanup: Could not purge context gcb=0x15D4F188 from the connection; gcb might be locked
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1060BAF8
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Apr 21 20:39:10.964: //32700/4CA3C8A1AA9B/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x15D4F188
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[5655]
Apr 21 20:39:10.964: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPITransportSendMessage: gcb has cleanedup, Done with send operations for this context
Apr 21 20:39:10.968: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[5655]
Apr 21 20:39:10.968: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 119, fd: 1
Apr 21 20:39:10.968: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:davecallconnector@172.28.218.1>;tag=83E7FB44-1220
Date: Tue, 21 Apr 2015 20:39:10 GMT
CSeq: 7 REGISTER
Expires:  60
Content-Length: 0
Apr 21 20:39:10.968: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:21.732: //CTI/CM:-- trigger 1, callID 32701, dn 200990, reason 157701124, result 0
Apr 21 20:39:21.732: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:21.732: //CTI/CM:    target_node 25FD778
Apr 21 20:39:21.732: //CTI/CM:   - dn 200990
Apr 21 20:39:21.732: //CTI/CM:  CallEntry 1012890
Apr 21 20:39:21.732: //CTI/CM:  dstCallID -1
Apr 21 20:39:21.732: //CTI/CM:  line_info 25FD784, dn 200990
Apr 21 20:39:21.732: //CTI/CM:    * cmm_crs_proc_tr_call_orig
Apr 21 20:39:21.732: //CTI/CM:        callID = 32701, CG 200990, GCID =
Apr 21 20:39:21.732: //CTI/CM:cmm_is_hairpin_leg  number 200990 callID 32701
Apr 21 20:39:21.732: //CTI/CM: -- cid 32701 interface type 26
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_is_ephone_leg cid 32701 interface type 26 return TRUE530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:increase_gcid_ref_count 32701 0
Apr 21 20:39:21.732: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:21.732: //CTI/CM:      target_node 0
Apr 21 20:39:21.732: //CTI/CM:      Gcidinfo node Search FAILED
Apr 21 20:39:21.732: //CTI/CM:create_gcidinfo_node 32701
Apr 21 20:39:21.732: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:21.732: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:      count = 1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 404C11C8 callID 32701 dn_tag -1 dn_chan -1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_tag  call_inst 404C11C8 dn_tag 90 dn_chan 1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_phone  ccGetCallInfo ret succ. phone tag 99
Apr 21 20:39:21.732: //CTI/CM:        orig --> callID 32701, line_info 25FD784, call_inst 404C11C8, gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_ORIGINATED
Apr 21 20:39:22.736: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.736: //CTI/CM:-- trigger 14, callID 32702, dn 66363, reason 1079265368, result 317342152
Apr 21 20:39:22.736: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.736: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.736: //CTI/CM:   - dn 66363
Apr 21 20:39:22.736: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.736: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.736: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.736: //CTI/CM:    * cti_cmm_crs_proc_tr_call_active
Apr 21 20:39:22.736: //CTI/CM:    callID = 32702,src_callid  = 32701, CG 200990, CD = 66363, GCID =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.736: //CTI/CM:increase_gcid_ref_count 32702 0
Apr 21 20:39:22.736: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:22.736: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:22.740: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.740: //CTI/CM:      count = 2
Apr 21 20:39:22.740: //CTI/CM:    set originalCalled = 66363
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.740: //CTI/CM:-- trigger 2, callID 32702, dn 66363, reason -1433490559, result 680744969
Apr 21 20:39:22.740: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.740: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.740: //CTI/CM:   - dn 66363
Apr 21 20:39:22.740: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.740: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.740: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.740: //CTI/CM:    * cmm_crs_proc_tr_call_offr
Apr 21 20:39:22.740: //CTI/CM:        offr --> line_info 16FD783C
Apr 21 20:39:22.740: //CTI/CM:        CallEntry_src 1012890, id = 32701
Apr 21 20:39:22.740: //CTI/CM:             call_inst_src 404C11C8 gcid_parent 00000000-00000000-00000000-00000000
Apr 21 20:39:22.740: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:22.740: //CTI/CM:    target_node 25FD778
Apr 21 20:39:22.740: //CTI/CM:   - dn 200990
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 200990 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.740: //CTI/CM:cmm_find_callid_from_gcid  dn 200990
Apr 21 20:39:22.740: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:22.740: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:22.740: //CTI/CM:  to return callID 32701
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_OFFERED
Apr 21 20:39:22.740: //CTI/CM:             CID = 32702, CallEntry_dst = 100A6A0, call_inst_dst = 404C2794
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 404C2794 callID 32702 dn_tag -1 dn_chan -1
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.748: //CTI/CM:-- trigger 3, callID 32702, dn 66363, reason 1079271936, result 170250468
Apr 21 20:39:22.748: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.748: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.748: //CTI/CM:   - dn 66363
Apr 21 20:39:22.748: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.748: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.748: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.748: //CTI/CM:    * cmm_crs_proc_tr_call_ring
Apr 21 20:39:22.748: //CTI/CM:             call_inst_src 404C11C8 gcid_parent 00000000-00000000-00000000-00000000
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_call_inst_set_DN_tag  call_inst 404C2794 dn_tag 64 dn_chan 1
Apr 21 20:39:22.748: //CTI/CM:        ring --> callID 32702, line_info 16FD783C, call_inst 404C2794, gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 21 20:39:22.748: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:22.752: //CTI/CM:    target_node 25FD778
Apr 21 20:39:22.752: //CTI/CM:   - dn 200990
Apr 21 20:39:22.752: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 21 20:39:22.752: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 21 20:39:35.592: %IPPHONE-6-REG_ALARM: 22: Name=SEP001AA1E55F70 Load= SCCP41.8-4-4S Last=Reset-Reset
Apr 21 20:39:35.696: //CTI/LM:cti_update_cme_line_status mac addr 001AA1E55F70 number 66363 line status 0 normal 0 line removed 0 line shared 0 cti notify 1
Apr 21 20:39:35.696: //CTI/SM:sm_find_context_ids_by_line num 66363, tag 0, mac 001AA1E55F70, prev 0, expanded 0
Apr 21 20:39:35.696: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:35.696: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:35.696: //CTI/CM:   - dn 66363
Apr 21 20:39:35.696: //CTI/LM:lmm_process_cti_event event 15
Apr 21 20:39:35.696: //CTI/LM:lmm_process_cti_event event 14
Apr 21 20:39:35.696: //CTI/SM:sm_process_lmm_event event 15
Apr 21 20:39:35.696: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:35.696: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:35.696: //CTI/PI:pi_send_log_event event 15 context_id 32691
Apr 21 20:39:35.696: //CTI/PI:pi_build_event event 15
Apr 21 20:39:35.696: //CTI/XI:cti2csta:1076 cti_ev_type_t(15)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=(001AA1E55F70)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_cause: cti_cause = 21
Apr 21 20:39:35.696: //CTI/XI:cti2csta:2169 csta_EventType_t(45)
Apr 21 20:39:35.696: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(300), message(300)
    <monitorCrossRefID>
    <device>
    </device>
    <cause>maintenance</cause>
Apr 21 20:39:35.696: //CTI/SM:sm_process_lmm_event event 14
Apr 21 20:39:35.696: //CTI/PI:pi_send_log_event event 14 context_id 32691
Apr 21 20:39:35.696: //CTI/PI:pi_build_event event 14
Apr 21 20:39:35.696: //CTI/XI:cti2csta:1076 cti_ev_type_t(14)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=()
Apr 21 20:39:35.696: //CTI/XI:cti2csta:2169 csta_EventType_t(44)
Apr 21 20:39:35.696: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(255), message(255)
    <monitorCrossRefID>
    <device>
    </device>
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 34
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/verbose/4096/act_active_info_request: Transaction active. Facilities/INFO requests will be queued.
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1060BAF8 with refCount = 1
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 5 event
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102F3258 to Info
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 300
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Transport/sipSPISendInfo: Sending INFO to the transport layer
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x1060BAF8, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.250.93, rport:5070 with laddr:
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x15D62460 is already on connection=0x426367C4 context_list
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x1060BAF8
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x1060BAF8, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/info/512/sentInfo: Sent Info Request, starting InfoTimer
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Apr 21 20:39:35.696: //32691/E3856E28AA86/SIP/Info/info/8192/Session-Timer/sipSTSLMain:
Apr 21 20:39:35.696: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102F20D0 to Info
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 255
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Transport/sipSPISendInfo: Sending INFO to the transport layer
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x47020AE0, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.250.93, rport:5070 with laddr:
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x15D62460 is already on connection=0x426367C4 context_list
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x47020AE0
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x47020AE0, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Info/info/512/sentInfo: Sent Info Request, starting InfoTimer
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 120, fd: 2
Apr 21 20:39:35.700: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B27A4
Max-Forwards: 70
Timestamp: 1429648775
CSeq: 103 INFO
Content-Length: 300
<device>
<cause>maintenance</cause></OutOfServiceEvent>
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1060BAF8
Sent:
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B317A5
Max-Forwards: 70
CSeq: 104 INFO
Content-Length: 255
<device>
Apr 21 20:39:35.700: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:35.748: %IPPHONE-6-REGISTER: ephone-1:SEP001AA1E55F70 IP:172.28.218.138 Socket:69 DeviceType:Phone has registered.
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 2 to index 120
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1060BAF8 with refCount = 1
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x42635D70
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=5070, local_addr=, connid=120, transport=TCP
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5070 connId 120
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Info/info/1024/sipSPIMatchRespToReqTran: match z9hG4bK24B27A4 to via_branch_list - remove and continue
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x15D62460
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x1060BAF8) counter, current msg->refCount = 2
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 INFO
Content-Length: 0
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Info/verbose/4096/sact_active_new_message_response: Transaction Complete. Lock on Facilities/INFO released.
Apr 21 20:39:35.752: //32691/E3856E28AA86/SIP/Info/verbose/32768/ccsip_api_info_done: RTP_LPBK == FALSE, checkpoint HA data
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x1060BAF8) counter, current msg->refCount = 1
Apr 21 20:39:35.752: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1060BAF8
Apr 21 20:39:35.756: //CTI/PI:cti_frontend_proc [7FB3]: received CC Event [21]: CC_EV_CALL_INFO_ACK
Apr 21 20:39:35.756: //CTI/PI:pi_process_service_event event 21
Apr 21 20:39:35.756: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 32691
Apr 21 20:39:35.756: //CTI/SM:sm_handle_cc_service event 85
Apr 21 20:39:35.756: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:35.756: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:35.756: //CTI/SM:    got CTI_EV_ACK, callID 32691
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 2 to index 120
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1060BAF8 with refCount = 1
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1060BAF8
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x42635D70
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=5070, local_addr=, connid=120, transport=TCP
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5070 connId 120
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK24B317A5 from via branch list
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x15D62460
Apr 21 20:39:35.760: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x47020AE0) counter, current msg->refCount = 2
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 104 INFO
Content-Length: 0
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Info/verbose/4096/sact_active_new_message_response: Transaction Complete. Lock on Facilities/INFO released.
Apr 21 20:39:35.760: //32691/E3856E28AA86/SIP/Info/verbose/32768/ccsip_api_info_done: RTP_LPBK == FALSE, checkpoint HA data
Apr 21 20:39:35.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x47020AE0) counter, current msg->refCount = 1
Apr 21 20:39:35.764: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:35.764: //CTI/PI:cti_frontend_proc [7FB3]: received CC Event [21]: CC_EV_CALL_INFO_ACK
Apr 21 20:39:35.764: //CTI/PI:pi_process_service_event event 21
Apr 21 20:39:35.764: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 32691
Apr 21 20:39:35.764: //CTI/SM:sm_handle_cc_service event 85
Apr 21 20:39:35.764: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:35.764: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:35.764: //CTI/SM:    got CTI_EV_ACK, callID 32691
Apr 21 20:39:36.252: //CTI/LM:cti_update_cme_line_status mac addr 001AA1E55F70 number 66363 line status 1 normal 1 line removed 0 line shared 0 cti notify 1
Apr 21 20:39:36.252: //CTI/SM:sm_find_context_ids_by_line num 66363, tag 0, mac 001AA1E55F70, prev 0, expanded 0
Apr 21 20:39:36.252: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:36.252: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:36.252: //CTI/CM:   - dn 66363
Apr 21 20:39:36.252: //CTI/LM:lmm_process_cti_event event 14
Apr 21 20:39:36.252: //CTI/SM:sm_process_lmm_event event 14
Apr 21 20:39:36.252: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:36.252: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:36.252: //CTI/PI:pi_send_log_event event 14 context_id 32691
Apr 21 20:39:36.252: //CTI/PI:pi_build_event event 14
Apr 21 20:39:36.252: //CTI/XI:cti2csta:1076 cti_ev_type_t(14)
Apr 21 20:39:36.252: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=(001AA1E55F70)
Apr 21 20:39:36.252: //CTI/XI:cti2csta:2169 csta_EventType_t(44)
Apr 21 20:39:36.252: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(275), message(275)
    <monitorCrossRefID>
    <device>
    </device>
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 34
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/verbose/4096/act_active_info_request: Transaction active. Facilities/INFO requests will be queued.
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 5 event
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102F13C0 to Info
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 275
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Transport/sipSPISendInfo: Sending INFO to the transport layer
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x47020AE0, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.250.93, rport:5070 with laddr:
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x15D62460 is already on connection=0x426367C4 context_list
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x47020AE0
Apr 21 20:39:36.252: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x47020AE0, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:39:36.252: //32691/E3856E28AA86/SIP/Info/info/512/sentInfo: Sent Info Request, starting InfoTimer
Apr 21 20:39:36.256: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 120, fd: 2
Apr 21 20:39:36.256: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B41C3B
Max-Forwards: 70
Timestamp: 1429648776
CSeq: 105 INFO
Content-Length: 275
<device>
<deviceIdentifier>tel:66363;device=001AA1E55F70</deviceIdentifier></device></BackInServiceEvent>
Apr 21 20:39:36.256: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 2 to index 120
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1060BAF8 with refCount = 1
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x42635D70
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=5070, local_addr=, connid=120, transport=TCP
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 5070 connId 120
Apr 21 20:39:36.308: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Info/info/1024/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK24B41C3B from via branch list
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x15D62460
Apr 21 20:39:36.312: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x1060BAF8) counter, current msg->refCount = 2
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 105 INFO
Content-Length: 0
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Info/verbose/1024/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Info/verbose/4096/sact_active_new_message_response: Transaction Complete. Lock on Facilities/INFO released.
Apr 21 20:39:36.312: //32691/E3856E28AA86/SIP/Info/verbose/32768/ccsip_api_info_done: RTP_LPBK == FALSE, checkpoint HA data
Apr 21 20:39:36.312: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x1060BAF8) counter, current msg->refCount = 1
Apr 21 20:39:36.312: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1060BAF8
Apr 21 20:39:36.312: //CTI/PI:cti_frontend_proc [7FB3]: received CC Event [21]: CC_EV_CALL_INFO_ACK
Apr 21 20:39:36.312: //CTI/PI:pi_process_service_event event 21
Apr 21 20:39:36.312: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 32691
Apr 21 20:39:36.312: //CTI/SM:sm_handle_cc_service event 85
Apr 21 20:39:36.312: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:36.312: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:36.312: //CTI/SM:    got CTI_EV_ACK, callID 32691
Apr 21 20:39:36.468: //CTI/LM:cti_update_mwi_info_to_app mac addr 001AA1E55F70 number 66363 mwi OFF
Apr 21 20:39:36.468: //CTI/SM:sm_find_context_ids_by_line num 66363, tag 0, mac 001AA1E55F70, prev 0, expanded 0
Apr 21 20:39:36.468: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:36.472: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:36.472: //CTI/CM:   - dn 66363
Apr 21 20:39:36.472: //CTI/LM:lmm_process_cti_event event 84
Apr 21 20:39:36.472: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:36.472: //CTI/CM:-- trigger 13, callID 32702, dn 66363, reason 808858425, result 16777215
Apr 21 20:39:36.472: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:36.472: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:36.472: //CTI/CM:  dstCallID 32701
Apr 21 20:39:36.472: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:36.472: //CTI/CM:    * cmm_crs_proc_tr_call_redir
Apr 21 20:39:36.472: //CTI/CM:          inst 404C2794 state 4
Apr 21 20:39:36.472: //CTI/CM:          set inst 404C11C8, dn 200990 redir cause = 4
Apr 21 20:39:36.472: //CTI/CM:find_lineinfo_node    finding number 66666
Apr 21 20:39:36.472: //CTI/CM:    target_node 0
Apr 21 20:39:36.472: //CTI/CM:Lineinfo node Search 66666 FAILED
Apr 21 20:39:36.472: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DIVERTED
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:36.476: //CTI/CM:-- trigger 16, callID 32702, dn 66363, reason 19, result 0
Apr 21 20:39:36.476: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:36.476: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:36.476: //CTI/CM:   - dn 66363
Apr 21 20:39:36.476: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:36.476: //CTI/CM:  dstCallID 32701
Apr 21 20:39:36.476: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:36.476: //CTI/CM:    * cti_cmm_crs_proc_tr_rpt_disconn
Apr 21 20:39:36.476: //CTI/CM:    callID = 32702, CD ,CG =200990 CD = 66363, GCID =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.476: //CTI/CM:    * is_only_one_callinst_with_dn_and_gcid
Apr 21 20:39:36.476: //CTI/CM:          callid 32702, dn = 66363, gcid =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.476: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:36.476: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:36.476: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.476: //CTI/CM:    Cause = C(13), inst cause = A
Apr 21 20:39:36.476: //CTI/CM:    Cause changed from alertTimeExpired to CFNA
Apr 21 20:39:36.476: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:36.476: //CTI/CM:    target_node 25FD778
Apr 21 20:39:36.476: //CTI/CM:   - dn 200990
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 200990 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.476: //CTI/CM:cmm_find_callid_from_gcid  dn 200990
Apr 21 20:39:36.476: //CTI/CM:  to return callID 32701
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 66363 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.476: //CTI/CM:cmm_find_callid_from_gcid  dn 66363
Apr 21 20:39:36.476: //CTI/CM:  to return callID 32702
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 66363 callID 32702
Apr 21 20:39:36.476: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 64 mac no mac
Apr 21 20:39:36.480: //CTI/CM:  to return callID 32702
Apr 21 20:39:36.480: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 66363 callID 32702
Apr 21 20:39:36.480: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:36.480: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:36.480: //CTI/CM:   - dn 66363
Apr 21 20:39:36.480: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 64 mac no mac
Apr 21 20:39:36.480: //CTI/CM:decrease_gcid_ref_count 32702
Apr 21 20:39:36.480: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:36.480: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:36.480: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.480: //CTI/CM:      count = 1
Apr 21 20:39:36.480: //CTI/CM:          delete_callinst 404C2794, callID = 32702
Apr 21 20:39:36.480: //CTI/CM:            freeing instance from CllEntry 100A6A0
Apr 21 20:39:36.480: //CTI/CM:cti_is_sccp_endpoint DN 66363
Apr 21 20:39:36.480:     sccp endpoint TRUE
Apr 21 20:39:36.480: //CTI/SM:sm_process_lmm_event event 84
Apr 21 20:39:36.480: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:36.480: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:36.480: //CTI/PI:pi_send_log_event event 84 context_id 32691
Apr 21 20:39:36.480: //CTI/PI:pi_build_event event 84
Apr 21 20:39:36.480: //CTI/XI:cti2csta:1076 cti_ev_type_t(84)
Apr 21 20:39:36.480: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=(001AA1E55F70)
Apr 21 20:39:36.480: //CTI/XI:cti2csta:2169 csta_EventType_t(48)
Apr 21 20:39:36.480: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(332), message(332)
  <MessageWaitingEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>
    <targetDevice>
    </targetDevice>
    <messageWaitingOn>false</messageWaitingOn>
  </MessageWaitingEvent>
Apr 21 20:39:36.480: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 34
Apr 21 20:39:36.480: //32691/E3856E28AA86/SIP/Info/verbose/4096/act_active_info_request: Transaction active. Facilities/INFO requests will be queued.
Apr 21 20:39:36.480: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x47020AE0 with refCount = 1
Apr 21 20:39:36.480: //32691/E3856E28AA86/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 5 event
Apr 21 20:39:36.480: //32691/E3856E28AA86/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Apr 21 20:39:36.480: //32691/E3856E28AA86/SIP/Info/verbose/4096/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Info/info/4096/sipSPISendInfo: Associated container=0x102F22E0 to Info
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 332
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Transport/sipSPISendInfo: Sending INFO to the transport layer
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: msg=0x47020AE0, addr=172.28.250.93, port=5070, sentBy_port=0, local_addr=, is_req=1, transport=2, switch=0, callBack=0x97D4514
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.250.93, rport:5070 with laddr:
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x15D62460 is already on connection=0x426367C4 context_list
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x47020AE0
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x47020AE0, addr=172.28.250.93, port=5070, local_addr=, connId=120 vrfid=0 for TCP
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Info/info/512/sentInfo: Sent Info Request, starting InfoTimer
Apr 21 20:39:36.484: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 530E3CF6E79D11E4AA9CAB8128935809, SetupTime 06:39:22.744 AEST Wed Apr 22 2015, PeerAddress 66363, PeerSubAddress , DisconnectCause 13  , DisconnectText no user answer (19), ConnectTime 06:39:36.484 AEST Wed Apr 22 2015, DisconnectTime 06:39:36.484 AEST Wed Apr 22 2015, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Apr 21 20:39:36.484: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFNA,ft:04/22/2015 06:39:36.476,frs:0,fid:73500,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBD,frson:3,fdcnt:1,fwder:66363,fwdee:200990,fwdto:66666,frm:66363,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:36.484: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:04/22/2015 06:39:22.736,cgn:200990,cdn:66363,frs:0,fid:73499,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBE,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_tcp_queue_event: Event type: send msg, connid: 120, fd: 2
Apr 21 20:39:36.484: //32691/E3856E28AA86/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 172.28.254.130:5060;branch=z9hG4bK24B5952
Max-Forwards: 70
CSeq: 106 INFO
Content-Length: 332
<targetDevice>
<deviceIdentifier>tel:66363;device=001AA1E55F70</deviceIdentifier></targetDevice>
<messageWaitingOn>false</messageWaitingOn></MessageWaitingEvent>
Apr 21 20:39:36.484: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x47020AE0
Apr 21 20:39:36.488: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D4F188) with key=[5656] to table
Apr 21 20:39:36.488: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:39:36.488: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:39:36.488: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:39:36.488: //32703/000000000000/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_read_from_TDContainer: MF: Unable to read data from TD Container..
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/critical/32768/ccsip_ipip_media_forking_forked_leg_config: MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: EV_UNDEFINED
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/verbose/4096/ccsip_iwf_map_ccapi_event_to_iwf_event: IWF Event: E_SIP_IWF_EV_SET_MODE
Apr 21 20:39:36.488: //32703/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Apr 21 20:39:36.488: //32703/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/ccsip_get_int_type_frm_set_mode_ev:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md_snr:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed_snr:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_sip_md:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_sip_ed:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_h32x_in_set_mode:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_h323_in_set_mode:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/4096/is_mode_sip_sccp_in_set_mode:
Apr 21 20:39:36.488: //32703/000000000000/SIP/Info/info/8192/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Apr 21 20:39:36.488: //32703/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_sccp_early_dialog_container
Apr 21 20:39:36.488: //32703/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGEfind_gcidinfo_node
Apr 21 20:39:36.656: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:36.656: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:36.656: //CTI/CM:  to return callID 32701
Apr 21 20:39:36.656: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:36.656: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:36.656: //CTI/CM:    target_node 25FD778
Apr 21 20:39:36.656: //CTI/CM:   - dn 200990
Apr 21 20:39:36.656: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:36.656: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_MEDIAATTACHED
Apr 21 20:39:38.816: //32703/5BDA6F22AAA1/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=32703, proc_id=9
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1017CA80 with refCount = 1
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x16962628 with refCount = 1
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.28.218.2]:32770, local_address:[ - ]
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1017CA80
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:200990@172.28.218.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.28.218.2:5060;branch=z9hG4bK5nZMMMf7hWvi8wv.DyW0Bw~~622
Max-Forwards: 70
To: <sip:200990@172.28.218.1>;tag=83E85F04-1A46
Call-ID: 5BDBA80B-E79D11E4-AAA5AB81-28935809@172.28.218.1
CSeq: 2 BYE
Content-Length: 0
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 530E3CF6-E79D-11E4-AA9C-AB8128935809
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/info/4096/sipSPICheckFromToRequest: Found matching CB 15D4F188
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/info/4096/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x16962628) counter, current msg->refCount = 2
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.218.2,Port 32770, Transport 1, SentBy Port 5060vrfid 0
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/ccsip_set_release_source_for_peer: ownCallId[32703], src[4]
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/info/4096/sipSPIStopHoldTimer: Stopping hold timer
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentGTD: No GTD found in inbound container
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/critical/4096/sipSPIInitiateDisconnect: Initiate call disconnect(16) for outgoing call
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13CC17F8
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 29
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x16962628) counter, current msg->refCount = 3
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D4F188)->last_request = 0x16962628, refCount = 3
Apr 21 20:39:40.488: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x16962628) counter, current msg->refCount = 2
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 18
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/256/sipSPIResetXcoder: *****CLEANING UP XCODER RESOURCES*****
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Info/verbose/256/sipSPIResetXcoder: Xcoder resource already cleaned up
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/State/ccsip_cnfsm_debugs: IPIPMS:next_state:S_IPIP_MEDIA_SERV_STATE_IDLE
Apr 21 20:39:40.488: //32703/5BDA6F22AAA1/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:17283244
Apr 21 20:39:40.488: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:40.488: //CTI/CM:-- trigger 16, callID 32701, dn 200990, reason 16, result 1079272200
Apr 21 20:39:40.488: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:40.488: //CTI/CM:    target_node 25FD778
Apr 21 20:39:40.488: //CTI/CM:   - dn 200990
Apr 21 20:39:40.488: //CTI/CM:  CallEntry 1012890
Apr 21 20:39:40.488: //CTI/CM:  dstCallID -1
Apr 21 20:39:40.488: //CTI/CM:  line_info 25FD784, dn 200990
Apr 21 20:39:40.488: //CTI/CM:    * cti_cmm_crs_proc_tr_rpt_disconn
Apr 21 20:39:40.488: //CTI/CM:    callID = 32701, CG ,CG =200990 CD = 66666, GCID =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.488: //CTI/CM:    * is_only_one_callinst_with_dn_and_gcid
Apr 21 20:39:40.492: //CTI/CM:          callid 32701, dn = 200990, gcid =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.492: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:40.492: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:40.492: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.492: //CTI/CM:    Cause = A(10), inst cause = A
Apr 21 20:39:40.492: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:40.492: //CTI/CM:    target_node 25FD778
Apr 21 20:39:40.492: //CTI/CM:   - dn 200990
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 200990 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.492: //CTI/CM:cmm_find_callid_from_gcid  dn 200990
Apr 21 20:39:40.492: //CTI/CM:  to return callID 32701
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:40.492: //CTI/CM:find_lineinfo_node    finding number 66666
Apr 21 20:39:40.492: //CTI/CM:    target_node 1000A684
Apr 21 20:39:40.492: //CTI/CM:   - dn 66666
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 66666 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.492: //CTI/CM:cmm_find_callid_from_gcid  dn 66666
Apr 21 20:39:40.492: //CTI/CM:  to return callID 32703
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 66666 callID 32703
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag -1 mac no mac
Apr 21 20:39:40.492: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_CONN_CLEARED
Apr 21 20:39:40.492: //CTI/CM:decrease_gcid_ref_count 32701
Apr 21 20:39:40.492: //CTI/CM:      count = 1
Apr 21 20:39:40.492: //CTI/CM:          delete_callinst 404C11C8, callID = 32701
Apr 21 20:39:40.492: //CTI/CM:            freeing instance from CllEntry 1012890
Apr 21 20:39:40.492: //CTI/CM:cti_is_sccp_endpoint DN 200990
Apr 21 20:39:40.492:     sccp endpoint TRUE
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:40.496: //CTI/CM:-- trigger 16, callID 32703, dn 66666, reason 16, result 1079272200
Apr 21 20:39:40.496: //CTI/CM:find_lineinfo_node    finding number 66666
Apr 21 20:39:40.496: //CTI/CM:    target_node 1000A684
Apr 21 20:39:40.496: //CTI/CM:   - dn 66666
Apr 21 20:39:40.496: //CTI/CM:  CallEntry 100D1F0
Apr 21 20:39:40.496: //CTI/CM:  dstCallID -1
Apr 21 20:39:40.496: //CTI/CM:  line_info 1000A690, dn 66666
Apr 21 20:39:40.496: //CTI/CM:    * cti_cmm_crs_proc_tr_rpt_disconn
Apr 21 20:39:40.496: //CTI/CM:    callID = 32703, CD ,CG =200990 CD = 66666, GCID =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.496: //CTI/CM:    * is_only_one_callinst_with_dn_and_gcid
Apr 21 20:39:40.496: //CTI/CM:          callid 32703, dn = 66666, gcid =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.496: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:40.496: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:40.496: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.496: //CTI/CM:    Cause = A(10), inst cause = A
Apr 21 20:39:40.496: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:40.496: //CTI/CM:    target_node 25FD778
Apr 21 20:39:40.496: //CTI/CM:   - dn 200990
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 200990 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.496: //CTI/CM:cmm_find_callid_from_gcid  dn 200990
Apr 21 20:39:40.496: //CTI/CM:  to return callID -1
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  fail in getting CallID
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 66666 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.496: //CTI/CM:cmm_find_callid_from_gcid  dn 66666
Apr 21 20:39:40.496: //CTI/CM:  to return callID 32703
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 66666 callID 32703
Apr 21 20:39:40.496: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag -1 mac no mac
Apr 21 20:39:40.500: //CTI/CM:    target_node 1000A684
Apr 21 20:39:40.500: //CTI/CM:   - dn 66666
Apr 21 20:39:40.500: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag -1 mac no mac
Apr 21 20:39:40.500: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_CONN_CLEARED
Apr 21 20:39:40.500: //CTI/CM:decrease_gcid_ref_count 32703
Apr 21 20:39:40.500: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:40.500: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:40.500: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:40.500: //CTI/CM:delete_gcid_node
Apr 21 20:39:40.500: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:40.500: //CTI/CM:    target_node 25FD778
Apr 21 20:39:40.500: //CTI/CM:   - dn 200990
Apr 21 20:39:40.500: //CTI/CM:find_lineinfo_node    finding number 66666
Apr 21 20:39:40.500: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_CONN_DROPPED
Apr 21 20:39:40.500: //CTI/CM:          delete_callinst 404C2794, callID = 32703
Apr 21 20:39:40.500: //CTI/CM:            freeing instance from CllEntry 100D1F0
Apr 21 20:39:40.500: //CTI/CM:cti_is_sccp_endpoint DN 66666
Apr 21 20:39:40.500: //CTI/CM:cti_is_SIP_line_side_endpoint DN 66666
Apr 21 20:39:40.500: //CTI/CM:free 66666 line_info 1000A690
Apr 21 20:39:40.500: //32703/5BDA6F22AAA1/SIP/Info/verbose/8192/ccsip_call_statistics: Requesting stats for callid=32703
Apr 21 20:39:40.500: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/ccsip_ipip_media_service_get_event_data: Event id = 29
Apr 21 20:39:40.500: //32703/5BDA6F22AAA1/SIP/Info/critical/32768/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
Apr 21 20:39:40.500: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Apr 21 20:39:40.500: //32703/5BDA6F22AAA1/SIP/Info/verbose/32768/ccsip_indicate_rt_packet_stats: Processing stats for callid=32703, proc_id=1
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/133120/sipSPIBwCacReleaseDialPeerBw: bwcac dial-peer bw 80 Kbps released for tag 1 active bw 0 Kbps
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/131072/sipSPIBwCacReleaseInterfaceBw: bwcac releasing interface GigabitEthernet0/0 bw 80 Kbps
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/131072/sipSPIBwCacReleaseAccountedBw: bwcac released accounted  bw 80000 bps
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/4096/act_disconnecting_disconnect: Disconnect now.. no defer BYE..
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1017CA80 with refCount = 1
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/8192/sipSPIPresendProcessing: Presend Processing called for 3 event
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/notify/4096/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/4096/sipSPISendByeResponse: Associated container=0x102E68E8 to Bye Response
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 0
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Transport/sipSPITransportSendMessage: msg=0x1017CA80, addr=172.28.218.2, port=32770, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x97D6768
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x25C4564, addr=172.28.218.2, port=5060, local_addr=, unregistering context=0x15D4F188
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x15D4F188 from the connection=0x25C4E38 context list
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x1017CA80 to default port=5060
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.28.218.2, rport:5060 with laddr:
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x15D4F188 with connection=0x25C4E38 context list
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x1017CA80
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x1017CA80, addr=172.28.218.2, port=5060, local_addr=, connId=2 vrfid=0 for UDP
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/512/sentByeResponse: Sent 200ok to the BYE, tearing down the call
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/4096/sipSPISetCommonTimer: Started generic timer type 2 for 240000 millisecs
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/8192/sipSPIDeferCallClose: Not split dataplane, bail
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/8192/sipSPIWaitForStatsBforeCallClose: Not split dataplane, bail
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/sipSPICallCloseAfterFinalStat:
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/info/12288/sipSPIIcpifUpdate: CallState: 4 Playout: 3800 DiscTime:221304797 ConnTime 221304398
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Media/sipSPIHandleDestroyRtpSession: stream:17283244
Apr 21 20:39:40.504: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 5BDA6F22E79D11E4AAA1AB8128935809, SetupTime 06:39:36.504 AEST Wed Apr 22 2015, PeerAddress 66666, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 06:39:36.514 AEST Wed Apr 22 2015, DisconnectTime 06:39:40.504 AEST Wed Apr 22 2015, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 192, TransmitBytes 30720, ReceivePackets 198, ReceiveBytes 31680
Apr 21 20:39:40.504: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFNA,ft:04/22/2015 06:39:36.488,frs:0,fid:73503,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBF,frson:3,fdcnt:1,fwder:66363,fwdee:200990,fwdto:66666,frm:66363,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:40.504: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:04/22/2015 06:39:36.488,cgn:200990,cdn:66666,frs:0,fid:73504,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBF,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:40.504: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x16962628) counter, current msg->refCount = 1
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/State/sipSPIChangeState: 0x15D4F188 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x15D4F188
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 200990
Called Number            : 66666
Source IP Address (Sig  ): 172.28.218.1
Destn SIP Req Addr:Port  : 172.28.218.2:5060
Destn SIP Resp Addr:Port : 172.28.218.2:32770
Destination Name         : 172.28.218.2
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 8
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.28.218.1
Source IP Port    (Media): 20164
Destn  IP Address (Media): 172.28.218.2
Destn  IP Port    (Media): 21016
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 7FBF
Apr 21 20:39:40.504: //32703/5BDA6F22AAA1/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Return and SIP_TIMER_REMOVE_TRANSACTION timer will free this ccb=0x15D4F188
Apr 21 20:39:40.504: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:40.504: //CTI/MD:-- trigger 23, callID 32701, dn 200990, reason 15, result 10
Apr 21 20:39:40.504: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:40.504: //CTI/CM:    target_node 25FD778
Apr 21 20:39:40.504: //CTI/CM:   - dn 200990
Apr 21 20:39:40.504: //CTI/CM:  CallEntry 1012890
Apr 21 20:39:40.504: //CTI/CM:  dstCallID -1
Apr 21 20:39:40.504: //CTI/MD:  line_info 25FD784, dn 200990
Apr 21 20:39:40.504: //CTI/MD:    * cti_cmm_crs_proc_tr_call_mediadetached
Apr 21 20:39:40.504: //CTI/MD:-- trigger 23, callID 32701, dn 200990, reason 1112845024, result 292859168
Apr 21 20:39:40.508: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 530E3CF6E79D11E4AA9CAB8128935809, SetupTime 06:39:21.728 AEST Wed Apr 22 2015, PeerAddress 200990, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 06:39:36.528 AEST Wed Apr 22 2015, DisconnectTime 06:39:40.508 AEST Wed Apr 22 2015, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 192, ReceiveBytes 30720
Apr 21 20:39:40.508: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFNA,ft:04/22/2015 06:39:36.488,frs:0,fid:73503,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBF,frson:3,fdcnt:1,fwder:66363,fwdee:200990,fwdto:66666,frm:66363,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:40.508: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:04/22/2015 06:39:21.732,cgn:200990,cdn:,frs:0,fid:73498,fcid:530E3CF6E79D11E4AA9CAB8128935809,legID:7FBD,bguid:530E3CF6E79D11E4AA9CAB8128935809
Apr 21 20:39:40.512: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 21 Apr 2015 20:39:40 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 2 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=192,OS=30720,PR=198,OR=31680,PL=0,JI=0,LA=0,DU=3
Content-Length: 0
Apr 21 20:39:40.512: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1017CA80
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Transport/sip_find_connid_by_fd: Map fd 1 to index 119
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x1017CA80 with refCount = 1
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x13BAD038 with refCount = 1
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1017CA80
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x42635D70, addr=172.28.250.93, port=59575, local_addr=, connid=119, transport=TCP
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/4608/sipHolderGetConnInstance: Return existing connection for port 59575 connId 119
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.28.218.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.28.250.93:5070;branch=z9hG4bK9bkDTjwKc7Ez15sTfoNEXQ~~9
Max-Forwards: 70
From: <sip:davecallconnector@172.28.218.1>;tag=dsd1b2e01f
Call-ID: 14296485727041@172.28.218.1
CSeq: 8 REGISTER
Content-Length: 0
Contact: <sip:null@172.28.250.93:5070;transport=tcp>;expires=120
X-cisco-session-server: davecallconnector
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIFindRegisterCcb: *****CCB NOT found in UAS Request table. ccb=0x0
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x15D6F0F0) with key=[5658] to table
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/verbose/4608/sipSPISipIncomingMsg: copy the natted transport info to ccb natted dest: 172.28.250.93:59575,natted src: 172.28.218.1:5060, natted transport: 2
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/info/1024/sipSPISipIncomingMsg:  sip via host 172.28.250.93
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/info/9216/sipSPISipIncomingMsg:  sip nat auto detect 0
Apr 21 20:39:41.028: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Apr 21 20:39:41.028: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 172.28.254.130 for SIP
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 172.28.254.130
Apr 21 20:39:41.032: //-1/5E8FCC4EAAA6/SIP/State/sipSPIChangeState: 0x15D6F0F0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5060vrfid 0
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone AEST to SIP default timezone = GMT
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.28.250.93,Port 59575, Transport 2, SentBy Port 5070vrfid 0
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x13BAD038) counter, current msg->refCount = 2
Apr 21 20:39:41.032: //-1/5E8FCC4EAAA6/SIP/Info/verbose/4096/sipSPIAssignCcbLastRequest: Current ccb(0x15D6F0F0)->last_request = 0x13BAD038, refCount = 2
Apr 21 20:39:41.032: //-1/5E8FCC4EAAA6/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x15D6F0F0 key=14296485727041@172.28.218.1davecallconnectordsd1b2e01f balance 0
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Event/sact_idle_new_message_register:
ccsip_api_register_ind return value : SIP_SUCCESS
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 7FC0 to table
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/State/sipSPIChangeState: 0x15D6F0F0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Info/notify/262144/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Info/notify/262144/ccsip_spi_register_incoming_registration: registration expires timer max is 3600 and min is 60
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/ccsip_process_registration_passthrough: RCB Pointer : [0x174F4B58]
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Info/critical/262144/ccsip_process_registration_passthrough: Re-Register not for passthrough, Try CME
Apr 21 20:39:41.032: //32704/5E8FCC4EAAA6/SIP/Info/info/262144/ccsip_spi_register_incoming_registration: Register for CME caseSIP/2.0 200 OK
To: <sip:davecallconnector@172.28.218.1>;tag=83E870B8-E44
Date: Tue, 21 Apr 2015 20:39:41 GMT
CSeq: 8 REGISTER
X-cisco-referenceID: FB47A3FE
Contact: <sip:davecallconnector@172.28.250.93:5070;transport=tcp>;expires=60
Expires:  60
Content-Length: 0
Apr 21 20:39:41.032: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x1017CA80
dcmhrc02#
dcmhrc02#show cti session
ID   DN Num     Tag Mac          MRef CreateTime           #Msg
32691 66363      0   001AA1E55F70 0    Apr 22 2015 06:36:15 7
From logs I don't see if any call placed, you can try with our sample codes in below location.
Cisco UCXAPIhttps://developer.cisco.com/site/uc-express-services/documentation/
You can raise a Dev Net support case, for more information you can refer below link.
Cisco DevNet Supporthttps://developer.cisco.com/site/devnet/support/
Raghavendra
Hi Raghavendra,
Sorry I should have provided more information about the log
I initiated a phone call from 200990  to 66363 as listed below but it did not generate CSTA event
Apr 21 20:39:10.968: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x13F54F14
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:21.732: //CTI/CM:-- trigger 1, callID 32701, dn 200990, reason 157701124, result 0
Apr 21 20:39:21.732: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:21.732: //CTI/CM:    target_node 25FD778
Apr 21 20:39:21.732: //CTI/CM:   - dn 200990
Apr 21 20:39:21.732: //CTI/CM:  CallEntry 1012890
Apr 21 20:39:21.732: //CTI/CM:  dstCallID -1
Apr 21 20:39:21.732: //CTI/CM:  line_info 25FD784, dn 200990
Apr 21 20:39:21.732: //CTI/CM:    * cmm_crs_proc_tr_call_orig
Apr 21 20:39:21.732: //CTI/CM:        callID = 32701, CG 200990, GCID =
Apr 21 20:39:21.732: //CTI/CM:cmm_is_hairpin_leg  number 200990 callID 32701
Apr 21 20:39:21.732: //CTI/CM: -- cid 32701 interface type 26
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_is_ephone_leg cid 32701 interface type 26 return TRUE530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:increase_gcid_ref_count 32701 0
Apr 21 20:39:21.732: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:21.732: //CTI/CM:      target_node 0
Apr 21 20:39:21.732: //CTI/CM:      Gcidinfo node Search FAILED
Apr 21 20:39:21.732: //CTI/CM:create_gcidinfo_node 32701
Apr 21 20:39:21.732: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:21.732: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:      count = 1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 404C11C8 callID 32701 dn_tag -1 dn_chan -1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_tag  call_inst 404C11C8 dn_tag 90 dn_chan 1
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_call_inst_set_DN_phone  ccGetCallInfo ret succ. phone tag 99
Apr 21 20:39:21.732: //CTI/CM:        orig --> callID 32701, line_info 25FD784, call_inst 404C11C8, gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:21.732: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_ORIGINATED
Apr 21 20:39:22.736: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.736: //CTI/CM:-- trigger 14, callID 32702, dn 66363, reason 1079265368, result 317342152
Apr 21 20:39:22.736: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.736: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.736: //CTI/CM:   - dn 66363
Apr 21 20:39:22.736: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.736: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.736: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.736: //CTI/CM:    * cti_cmm_crs_proc_tr_call_active
Apr 21 20:39:22.736: //CTI/CM:    callID = 32702,src_callid  = 32701, CG 200990, CD = 66363, GCID =530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.736: //CTI/CM:increase_gcid_ref_count 32702 0
Apr 21 20:39:22.736: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:22.736: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:22.740: //CTI/CM:   - gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.740: //CTI/CM:      count = 2
Apr 21 20:39:22.740: //CTI/CM:    set originalCalled = 66363
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.740: //CTI/CM:-- trigger 2, callID 32702, dn 66363, reason -1433490559, result 680744969
Apr 21 20:39:22.740: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.740: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.740: //CTI/CM:   - dn 66363
Apr 21 20:39:22.740: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.740: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.740: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.740: //CTI/CM:    * cmm_crs_proc_tr_call_offr
Apr 21 20:39:22.740: //CTI/CM:        offr --> line_info 16FD783C
Apr 21 20:39:22.740: //CTI/CM:        CallEntry_src 1012890, id = 32701
Apr 21 20:39:22.740: //CTI/CM:             call_inst_src 404C11C8 gcid_parent 00000000-00000000-00000000-00000000
Apr 21 20:39:22.740: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:22.740: //CTI/CM:    target_node 25FD778
Apr 21 20:39:22.740: //CTI/CM:   - dn 200990
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 200990 gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.740: //CTI/CM:cmm_find_callid_from_gcid  dn 200990
Apr 21 20:39:22.740: //CTI/CM:find_gcidinfo_node
Apr 21 20:39:22.740: //CTI/CM:      target_node 1772B7C0
Apr 21 20:39:22.740: //CTI/CM:  to return callID 32701
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 200990 callID 32701
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 90 mac 1CE85DC9D715
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_OFFERED
Apr 21 20:39:22.740: //CTI/CM:             CID = 32702, CallEntry_dst = 100A6A0, call_inst_dst = 404C2794
Apr 21 20:39:22.740: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 404C2794 callID 32702 dn_tag -1 dn_chan -1
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_notify_trigger
Apr 21 20:39:22.748: //CTI/CM:-- trigger 3, callID 32702, dn 66363, reason 1079271936, result 170250468
Apr 21 20:39:22.748: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:22.748: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:22.748: //CTI/CM:   - dn 66363
Apr 21 20:39:22.748: //CTI/CM:  CallEntry 100A6A0
Apr 21 20:39:22.748: //CTI/CM:  dstCallID 32701
Apr 21 20:39:22.748: //CTI/CM:  line_info 16FD783C, dn 66363
Apr 21 20:39:22.748: //CTI/CM:    * cmm_crs_proc_tr_call_ring
Apr 21 20:39:22.748: //CTI/CM:             call_inst_src 404C11C8 gcid_parent 00000000-00000000-00000000-00000000
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_call_inst_set_DN_tag  call_inst 404C2794 dn_tag 64 dn_chan 1
Apr 21 20:39:22.748: //CTI/CM:        ring --> callID 32702, line_info 16FD783C, call_inst 404C2794, gcid 530E3CF6-E79D11E4-AA9CAB81-28935809
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 21 20:39:22.748: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 21 20:39:22.748: //CTI/CM:find_lineinfo_node    finding number 200990
Apr 21 20:39:22.752: //CTI/CM:    target_node 25FD778
Apr 21 20:39:22.752: //CTI/CM:   - dn 200990
Apr 21 20:39:22.752: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 21 20:39:22.752: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
I reset  the phone here and it generated CSTA event
Apr 21 20:39:35.592: %IPPHONE-6-REG_ALARM: 22: Name=SEP001AA1E55F70 Load= SCCP41.8-4-4S Last=Reset-Reset
Apr 21 20:39:35.696: //CTI/LM:cti_update_cme_line_status mac addr 001AA1E55F70 number 66363 line status 0 normal 0 line removed 0 line shared 0 cti notify 1
Apr 21 20:39:35.696: //CTI/SM:sm_find_context_ids_by_line num 66363, tag 0, mac 001AA1E55F70, prev 0, expanded 0
Apr 21 20:39:35.696: //CTI/CM:find_lineinfo_node    finding number 66363
Apr 21 20:39:35.696: //CTI/CM:    target_node 16FD7830
Apr 21 20:39:35.696: //CTI/CM:   - dn 66363
Apr 21 20:39:35.696: //CTI/LM:lmm_process_cti_event event 15
Apr 21 20:39:35.696: //CTI/LM:lmm_process_cti_event event 14
Apr 21 20:39:35.696: //CTI/SM:sm_process_lmm_event event 15
Apr 21 20:39:35.696: //CTI/SM:sm_find_scb_node_by_context context_id 32691
Apr 21 20:39:35.696: //CTI/SM:    to return 1544C8B0
Apr 21 20:39:35.696: //CTI/PI:pi_send_log_event event 15 context_id 32691
Apr 21 20:39:35.696: //CTI/PI:pi_build_event event 15
Apr 21 20:39:35.696: //CTI/XI:cti2csta:1076 cti_ev_type_t(15)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=(001AA1E55F70)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_cause: cti_cause = 21
Apr 21 20:39:35.696: //CTI/XI:cti2csta:2169 csta_EventType_t(45)
Apr 21 20:39:35.696: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(300), message(300)
<?xml version="1.0" encoding="UTF-8"?>
  <OutOfServiceEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>
    </monitorCrossRefID>
    <device>
    </device>
Apr 21 20:39:35.696: //CTI/SM:sm_process_lmm_event event 14
Apr 21 20:39:35.696: //CTI/PI:pi_send_log_event event 14 context_id 32691
Apr 21 20:39:35.696: //CTI/PI:pi_build_event event 14
Apr 21 20:39:35.696: //CTI/XI:cti2csta:1076 cti_ev_type_t(14)
Apr 21 20:39:35.696: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(66363) phone-context=(0,) device=()
Apr 21 20:39:35.696: //CTI/XI:cti2csta:2169 csta_EventType_t(44)
Apr 21 20:39:35.696: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(255), message(255)
  <BackInServiceEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>
    <device>
      <deviceIdentifier>tel:66363</deviceIdentifier>
    </device>
  </BackInSer
The router is running CME 10.5.
Thanks for sharing the info, are you monitoring 200990 and  66363  phones ?
Raghavendra
Hi Raghavendra,
I'm now able to remote answer internal calls but not external from ISDN/E1. CME responds with invalid callid below are the logs.
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<AnswerCall xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <callToBeAnswered>
        <callID>61F84BF6-EA4311E4-8DD6AA78-418DAEF4</callID>
        <deviceID>73465</deviceID>
    </callToBeAnswered>
</AnswerCall>
Apr 25 05:47:54.585: //CTI/XI:csta_AnswerCall_cb: Function Called
Apr 25 05:47:54.585: //CTI/XI:csta_callToBeAnswered_cb: Function Called
Apr 25 05:47:54.585: //CTI/XI:csta_callID_cb: Function Called
Apr 25 05:47:54.585: //CTI/XI:csta_deviceID_cb: Function Called
Apr 25 05:47:54.585: //CTI/XI:csta2cti:811 csta_service_type_t(1)
Apr 25 05:47:54.585: //CTI/XI:csta2cti_CallID: Input =  61F84BF6-EA4311E4-8DD6AA78-418DAEF4
Apr 25 05:47:54.585: //CTI/XI:csta2cti_CallID: match 4, 61F84BF6-EA4311E4-8DD6AA78-418DAEF4
Apr 25 05:47:54.585: //CTI/XI:csta2cti_DeviceID: csta(73465) attr(0,) number(73465) phone-context=(0,) device=()
Apr 25 05:47:54.585: //CTI/XI:csta2cti:1062 cti_ev_type_t(39)
Apr 25 05:47:54.585: //CTI/SM:sm_find_scb_node_by_context context_id 363741
Apr 25 05:47:54.585: //CTI/SM:    to return 41975234
Apr 25 05:47:54.585: //CTI/PI:pi_process_service_event Feature Server Type = 2, Monitor_only = 0
Apr 25 05:47:54.585: //CTI/SM:sm_handle_cc_service event 39
Apr 25 05:47:54.585: //CTI/CC:ccm_process_sm_event event 39
Apr 25 05:47:54.585: //CTI/CM:find_lineinfo_node    finding number 73465
Apr 25 05:47:54.585: //CTI/CM:    target_node 4435465C
Apr 25 05:47:54.585: //CTI/CM:   - dn 73465
Apr 25 05:47:54.585: //CTI/CC:ccm_find_ccb_by_gcid parent 0
Apr 25 05:47:54.585: //CTI/CC:ccm_append_ccb ccb 44415C38
Apr 25 05:47:54.589: //CTI/CC:    final ccb count 1
Apr 25 05:47:54.589: //CTI/CC:ccm_drive_fsm state_curr 1 event 39
Apr 25 05:47:54.589: //CTI/CC:        Eventual selection 15
Apr 25 05:47:54.589: //CTI/CC:Fsm_Idle_AnswerCall answering 73465
Apr 25 05:47:54.589: //CTI/CM:cmm_find_callid_from_gcid  dn 73465
Apr 25 05:47:54.589: //CTI/CM:find_gcidinfo_node
Apr 25 05:47:54.589: //CTI/CM:      target_node 0
Apr 25 05:47:54.589: //CTI/CM:      Gcidinfo node Search FAILED
Apr 25 05:47:54.589: //CTI/CM:  to return callID -1
Apr 25 05:47:54.589: //CTI/CC:ccm_delete_ccb
Apr 25 05:47:54.589: //CTI/CC:    ccb 44415C38 released
Apr 25 05:47:54.589: //CTI/CC:    final ccb count 0
Apr 25 05:47:54.589: //CTI/SM:sm_process_ccm_event event 53
Apr 25 05:47:54.589: //CTI/SM:sm_find_scb_node_by_context context_id 363741
Apr 25 05:47:54.589: //CTI/SM:    to return 41975234
Apr 25 05:47:54.589: //CTI/PI:pi_send_cc_event event 53 context_id 363741
Apr 25 05:47:54.589: //CTI/PI:pi_build_event event 53
Apr 25 05:47:54.589: //CTI/XI:cti2csta:1076 cti_ev_type_t(53)
Apr 25 05:47:54.589: //CTI/XI:cti2csta_error: cti_error = 5
Apr 25 05:47:54.589: //CTI/XI:cti2csta:2169 csta_EventType_t(1)
Apr 25 05:47:54.589: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(177), message(177)
  <CSTAErrorCode xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <operation>invalidCallID</operation>
  </CSTAErrorCode>
DN         CallID GCID                                Calling    Called     State
73465
           363859   6A9128C2-EA4511E4-A52B3C08-F686F2D0            73465      DELVR
Currently UCXSI supports to monitor and control only SCCP device registered in Cisco Unified CME.
Raghavendra
Hi Raghavendra,
But I am able to answer calls originating from H323 trunk to the SCCP phone that's registered to CME.
can you explain the call flow which is not working, please attach full logs with below debug command.
debug cti all
Raghavendra
Hi Raghavendra,
The call flow that I'm having issues with is answering a call that originates from my mobile to a CME registered SCCP phone. The call comes to the CME via E1 trunk.
Apr 28 01:19:21.173: //CTI/CM:      target_node 4098E858
Apr 28 01:19:21.173: //CTI/CM:   - gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:21.177: //CTI/CM:  to return callID 370675
Apr 28 01:19:21.177: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 73460 callID 370675
Apr 28 01:19:21.177: //CTI/CM:find_lineinfo_node    finding number 73460
Apr 28 01:19:21.177: //CTI/CM:    target_node 40088218
Apr 28 01:19:21.177: //CTI/CM:   - dn 73460
Apr 28 01:19:21.177: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 3 mac 0C272454DE75
Apr 28 01:19:21.177: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_OFFERED
Apr 28 01:19:21.177: //CTI/CM:             CID = 370677, CallEntry_dst = 18587240, call_inst_dst = 1337907C
Apr 28 01:19:21.177: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 1337907C callID 370677 dn_tag -1 dn_chan -1
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:21.829: //CTI/CM:-- trigger 1, callID 370678, dn , reason 905969664, result 344017696
Apr 28 01:19:21.829: //CTI/CM:find_lineinfo_node    finding number
Apr 28 01:19:21.829: //CTI/CM:    target_node 0
Apr 28 01:19:21.829: //CTI/CM:Lineinfo node Search  FAILED
Apr 28 01:19:21.829: //CTI/CM:create_lineinfo_node
Apr 28 01:19:21.829: //CTI/CM:    target_node 18D912D8
Apr 28 01:19:21.829: //CTI/CM:   - dn
Apr 28 01:19:21.829: //CTI/CM:  CallEntry 41919BE0
Apr 28 01:19:21.829: //CTI/CM:  dstCallID -1
Apr 28 01:19:21.829: //CTI/CM:  line_info 18D912E4, dn
Apr 28 01:19:21.829: //CTI/CM:    * cmm_crs_proc_tr_call_orig
Apr 28 01:19:21.829: //CTI/CM:        callID = 370678, CG , GCID =
Apr 28 01:19:21.829: //CTI/CM:cmm_is_hairpin_leg  number  callID 370678
Apr 28 01:19:21.829: //CTI/CM: -- cid 370678 interface type 13
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_is_ephone_leg cid 370678 interface type 13 return FALSE
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_has_2nd_ephone_leg_in_gcid  compared number  cid 370678
Apr 28 01:19:21.829: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:21.829: //CTI/CM:      Gcidinfo node Search FAILED
Apr 28 01:19:21.829: //CTI/CM:  cti_cmm_has_2nd_ephone_leg_in_gcid callID -1 leg NOT FOUND
Apr 28 01:19:21.829: //CTI/CM:      target_node 4098EC08
Apr 28 01:19:21.829: //CTI/CM:   - gcid 06DFBD6E-EC7A11E4-8859AA78-418DAEF4
Apr 28 01:19:21.829: //CTI/CM:      target_node 4098E4A8
Apr 28 01:19:21.829: //CTI/CM:   - gcid 42C9FB15-EC7B11E4-88F7AA78-418DAEF4
Apr 28 01:19:21.829: //CTI/CM:      target_node 4098E858
Apr 28 01:19:21.829: //CTI/CM:   - gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:21.829: //CTI/CM:  cti_cmm_has_2nd_ephone_leg_in_gcid callID -1 leg NOT FOUND6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.829: //CTI/CM:increase_gcid_ref_count 370678 0
Apr 28 01:19:21.829: //CTI/CM:create_gcidinfo_node 370678
Apr 28 01:19:21.829: //CTI/CM:      target_node 4098EA30
Apr 28 01:19:21.829: //CTI/CM:   - gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.829: //CTI/CM:      count = 1
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 13377AB0 callID 370678 dn_tag -1 dn_chan -1
Apr 28 01:19:21.829: //CTI/CM:        orig --> callID 370678, line_info 18D912E4, call_inst 13377AB0, gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num  callID 370678
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag -1 mac no mac
Apr 28 01:19:21.829: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_ORIGINATED
Apr 28 01:19:21.833: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:21.833: //CTI/CM:-- trigger 14, callID 370679, dn 73566, reason 0, result 0
Apr 28 01:19:21.833: //CTI/CM:find_lineinfo_node    finding number 73566
Apr 28 01:19:21.833: //CTI/CM:    target_node 419665B4
Apr 28 01:19:21.833: //CTI/CM:   - dn 73566
Apr 28 01:19:21.833: //CTI/CM:  CallEntry 18584C60
Apr 28 01:19:21.833: //CTI/CM:  dstCallID 370678
Apr 28 01:19:21.833: //CTI/CM:  line_info 419665C0, dn 73566
Apr 28 01:19:21.833: //CTI/CM:    * cti_cmm_crs_proc_tr_call_active
Apr 28 01:19:21.833: //CTI/CM:    callID = 370679,src_callid  = 370678, CG , CD = 73566, GCID =6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.833: //CTI/CM:increase_gcid_ref_count 370679 0
Apr 28 01:19:21.833: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:21.833: //CTI/CM:      target_node 4098EA30
Apr 28 01:19:21.833: //CTI/CM:   - gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.833: //CTI/CM:      count = 2
Apr 28 01:19:21.833: //CTI/CM:    set originalCalled = 73566
Apr 28 01:19:21.833: //CTI/CM:-- trigger 2, callID 370679, dn 73566, reason 1, result 292880384
Apr 28 01:19:21.837: //CTI/CM:    target_node 419665B4
Apr 28 01:19:21.837: //CTI/CM:   - dn 73566
Apr 28 01:19:21.837: //CTI/CM:  CallEntry 18584C60
Apr 28 01:19:21.837: //CTI/CM:  dstCallID 370678
Apr 28 01:19:21.837: //CTI/CM:  line_info 419665C0, dn 73566
Apr 28 01:19:21.837: //CTI/CM:    * cmm_crs_proc_tr_call_offr
Apr 28 01:19:21.837: //CTI/CM:        offr --> line_info 419665C0
Apr 28 01:19:21.837: //CTI/CM:        CallEntry_src 41919BE0, id = 370678
Apr 28 01:19:21.837: //CTI/CM:             call_inst_src 13377AB0 gcid_parent 00000000-00000000-00000000-00000000
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num  gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.837: //CTI/CM:cmm_find_callid_from_gcid  dn
Apr 28 01:19:21.837: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:21.837: //CTI/CM:      target_node 4098EA30
Apr 28 01:19:21.837: //CTI/CM:   - gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.837: //CTI/CM:  to return callID 370678
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num  callID 370678
Apr 28 01:19:21.837: //CTI/CM:find_lineinfo_node    finding number
Apr 28 01:19:21.837: //CTI/CM:    target_node 18D912D8
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag -1 mac no mac
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_OFFERED
Apr 28 01:19:21.837:         <== CMM show CTI event ==>
Apr 28 01:19:21.837:                  - Calling
Apr 28 01:19:21.837:                  - Calling attr 0
Apr 28 01:19:21.837:                  - Calling tag -1
Apr 28 01:19:21.837:                  - Calling MAC
Apr 28 01:19:21.837:                  - Called 73566
Apr 28 01:19:21.837:                  - Called attr 1
Apr 28 01:19:21.837:                  - Called tag 0
Apr 28 01:19:21.837:                  - Called MAC
Apr 28 01:19:21.837:                  - ConnAddr 73566
Apr 28 01:19:21.837:                  - ConnAddr attr 1
Apr 28 01:19:21.837:                  - ConnAddr tag -1
Apr 28 01:19:21.837:                  - ConnAddr MAC
Apr 28 01:19:21.837:                  - type 69
Apr 28 01:19:21.837:                  - Cause 1 normal
Apr 28 01:19:21.837:                  - Gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.837:                  - EV_OFFERED
Apr 28 01:19:21.837:                  - LastRedirectAddr
Apr 28 01:19:21.837:                  - LastRedirectAddr attr 0
Apr 28 01:19:21.837:                  - type 0
Apr 28 01:19:21.837:                  - direction 0
Apr 28 01:19:21.837:                  - originalCalled
Apr 28 01:19:21.837:                  - originalCalled attr 0
Apr 28 01:19:21.837:                  - parentGcid00000000-00000000-00000000-00000000
Apr 28 01:19:21.837:                  - localConnectionState  Alerting
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo subscription id 370631 dn_tag 0
Apr 28 01:19:21.837:  send EV_OFFERED on number 73566 to ccm. sub id 370631
Apr 28 01:19:21.837: //CTI/CM:             CID = 370679, CallEntry_dst = 18584C60, call_inst_dst = 1336E21C
Apr 28 01:19:21.837: //CTI/CM:cti_cmm_call_inst_set_DN_phone  call_inst 1336E21C callID 370679 dn_tag -1 dn_chan -1
Apr 28 01:19:21.837: //CTI/CC:ccm_handle_call_event type 69 ConnAddr 73566
Apr 28 01:19:21.837: //CTI/CM:find_lineinfo_node    finding number 73566
Apr 28 01:19:21.837: //CTI/CC:ccm_find_ccb_by_gcid parent 0
Apr 28 01:19:21.837: //CTI/CC:ccm_append_ccb ccb 44415D40
Apr 28 01:19:21.837: //CTI/CC:    final ccb count 1
Apr 28 01:19:21.837: //CTI/CC:ccm_drive_fsm state_curr 1 event 69
Apr 28 01:19:21.837: //CTI/CC:        Eventual selection 12
Apr 28 01:19:21.837: //CTI/CC:Fsm_AnyState_AnyEvent state_curr 1 event 69
Apr 28 01:19:21.837: //CTI/CC:ccm_delete_ccb
Apr 28 01:19:21.837: //CTI/CC:    ccb 44415D40 released
Apr 28 01:19:21.837: //CTI/CC:    final ccb count 0
Apr 28 01:19:21.841: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:21.841: //CTI/CM:-- trigger 3, callID 370679, dn 73566, reason 0, result 0
Apr 28 01:19:21.841: //CTI/CM:find_lineinfo_node    finding number 73566
Apr 28 01:19:21.841: //CTI/CM:    target_node 419665B4
Apr 28 01:19:21.841: //CTI/CM:   - dn 73566
Apr 28 01:19:21.841: //CTI/CM:  CallEntry 18584C60
Apr 28 01:19:21.841: //CTI/CM:  dstCallID 370678
Apr 28 01:19:21.841: //CTI/CM:  line_info 419665C0, dn 73566
Apr 28 01:19:21.841: //CTI/CM:    * cmm_crs_proc_tr_call_ring
Apr 28 01:19:21.841: //CTI/CM:             call_inst_src 13377AB0 gcid_parent 00000000-00000000-00000000-00000000
Apr 28 01:19:21.841: //CTI/CM:cti_cmm_call_inst_set_DN_tag  call_inst 1336E21C dn_tag 130 dn_chan 1
Apr 28 01:19:21.841: //CTI/CM:        ring --> callID 370679, line_info 419665C0, call_inst 1336E21C, gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.841: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 28 01:19:21.841: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 28 01:19:21.841:         <== CMM show CTI event ==>
Apr 28 01:19:21.841:                  - Calling
Apr 28 01:19:21.841:                  - Calling attr 0
Apr 28 01:19:21.841:                  - Calling tag -1
Apr 28 01:19:21.841:                  - Calling MAC
Apr 28 01:19:21.841:                  - Called 73566
Apr 28 01:19:21.841:                  - Called attr 1
Apr 28 01:19:21.841:                  - Called tag 130
Apr 28 01:19:21.841:                  - Called MAC 405539ACDA93
Apr 28 01:19:21.841:                  - ConnAddr 73566
Apr 28 01:19:21.841:                  - ConnAddr attr 1
Apr 28 01:19:21.841:                  - ConnAddr tag 130
Apr 28 01:19:21.841:                  - ConnAddr MAC 405539ACDA93
Apr 28 01:19:21.841:                  - type 70
Apr 28 01:19:21.841:                  - Cause 1 normal
Apr 28 01:19:21.841:                  - Gcid 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.845:                  - EV_DELIVERED
Apr 28 01:19:21.845:                  - type 0
Apr 28 01:19:21.845:                  - LastRedirectAddr
Apr 28 01:19:21.845:                  - LastRedirectAddr attr 0
Apr 28 01:19:21.845:                  - direction 0
Apr 28 01:19:21.845:                  - originalCalled
Apr 28 01:19:21.845:                  - originalCalled attr 0
Apr 28 01:19:21.845:                  - parentGcid00000000-00000000-00000000-00000000
Apr 28 01:19:21.845:                  - localConnectionState  Alerting
Apr 28 01:19:21.845: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo subscription id 370631 dn_tag 0
Apr 28 01:19:21.845: //CTI/CM:cmm_is_hairpin_leg  number 73566 callID 370679
Apr 28 01:19:21.845:  send EV_DELIVERED on number 73566 to ccm. sub id 370631
Apr 28 01:19:21.845: //CTI/CM:find_lineinfo_node    finding number
Apr 28 01:19:21.845: //CTI/CM:    target_node 18D912D8
Apr 28 01:19:21.845: //CTI/CM:   - dn
Apr 28 01:19:21.845: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 28 01:19:21.845: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 28 01:19:21.845: //CTI/CC:ccm_handle_call_event type 70 ConnAddr 73566
Apr 28 01:19:21.845: //CTI/CM:find_lineinfo_node    finding number 73566
Apr 28 01:19:21.845: //CTI/CM:    target_node 419665B4
Apr 28 01:19:21.845: //CTI/CM:   - dn 73566
Apr 28 01:19:21.845: //CTI/CC:ccm_find_ccb_by_gcid parent 0
Apr 28 01:19:21.845: //CTI/CC:ccm_append_ccb ccb 44415D40
Apr 28 01:19:21.845: //CTI/CC:    final ccb count 1
Apr 28 01:19:21.845: //CTI/CC:ccm_drive_fsm state_curr 1 event 70
Apr 28 01:19:21.845: //CTI/CC:        Eventual selection 1
Apr 28 01:19:21.845: //CTI/CC:Fsm_AnyState_AnyCallEvent state_curr 1 event 70
Apr 28 01:19:21.845: //CTI/CC:ccm_delete_ccb
Apr 28 01:19:21.845: //CTI/CC:    ccb 44415D40 released
Apr 28 01:19:21.845: //CTI/CC:    final ccb count 0
Apr 28 01:19:21.849: //CTI/SM:sm_process_ccm_event event 70
Apr 28 01:19:21.849: //CTI/SM:sm_find_scb_node_by_context context_id 370631
Apr 28 01:19:21.849: //CTI/SM:    to return 40979B14
Apr 28 01:19:21.849: //CTI/PI:pi_send_cc_event event 70 context_id 370631
Apr 28 01:19:21.849: //CTI/PI:pi_build_event event 70
Apr 28 01:19:21.849: //CTI/XI:cti2csta:1076 cti_ev_type_t(70)
Apr 28 01:19:21.849: //CTI/XI:cti2csta_cause: cti_cause = 1
Apr 28 01:19:21.849: //CTI/XI:cti2csta_xrefID: xrefID (1D0)
Apr 28 01:19:21.849: //CTI/XI:cti2csta_CallID: CallID = 6F2C1F32-EC7B11E4-A6A33C08-F686F2D0
Apr 28 01:19:21.849: //CTI/XI:cti2csta_DeviceID: attr(1,tel:) number(73566) phone-context=(0,) device=(405539ACDA93)
Apr 28 01:19:21.849: //CTI/XI:cti2csta:2169 csta_EventType_t(29)
Apr 28 01:19:21.849: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(699), message(699)
  <DeliveredEvent xmlns="http://www.ecma-international.org/standards/ecma-323/csta/ed3">
    <monitorCrossRefID>000001D0</monitorCrossRefID>
    <connection>
      <callID>6F2C1F32-EC7B11E4-A6A33C08-F686F2D0</callID>
      <deviceID>tel:73566;device=405539ACDA93</deviceID>
    </connection>
    <alertingDevice>
      <deviceIdentifier>tel:73566;device=405539ACDA93</deviceIdentifier>
    </alertingDevice>
    <callingDevice>
      <notKnown/>
    </callingDevice>
    <calledDevice>
    </calledDevice>
    <lastRedirectionDevice>
      <notRequired/>
    </lastRedirectionDevice>
    <localConnectionInfo>alerting</localConnectionInfo>
    <cause>normal</cause>
  </DeliveredEvent>
Apr 28 01:19:21.873: //CTI/PI:cti_frontend_proc [5A7C7]: received CC Event [20]: CC_EV_CALL_INFO_ACK
Apr 28 01:19:21.873: //CTI/PI:pi_process_service_event event 20
Apr 28 01:19:21.873: //CTI/PI:    got CC_EV_CALL_INFO_ACK callID 370631
Apr 28 01:19:21.873: //CTI/SM:sm_handle_cc_service event 85
Apr 28 01:19:21.873: //CTI/SM:sm_find_scb_node_by_context context_id 370631
Apr 28 01:19:21.873: //CTI/SM:    to return 40979B14
Apr 28 01:19:21.873: //CTI/SM:    got CTI_EV_ACK, callID 370631
Apr 28 01:19:21.925: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:21.929: //CTI/CM:        ring --> callID 370677, line_info 213DA08, call_inst 1337907C, gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:21.929: //CTI/CM:cti_cmm_ringing_notify_ccm trigger EV_DELIVERED
Apr 28 01:19:21.929: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_DELIVERED
Apr 28 01:19:21.929: //CTI/CM:find_lineinfo_node    finding number 73460
Apr 28 01:19:21.929: //CTI/CM:    target_node 40088218
Apr 28 01:19:21.929: //CTI/CM:   - dn 73460
Apr 28 01:19:21.973: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:21.973: //CTI/MD:-- trigger 22, callID 370675, dn 73460, reason 0, result 401651488
Apr 28 01:19:21.973: //CTI/CM:find_lineinfo_node    finding number 73460
Apr 28 01:19:21.973: //CTI/CM:    target_node 40088218
Apr 28 01:19:21.973: //CTI/CM:   - dn 73460
Apr 28 01:19:21.973: //CTI/CM:  CallEntry 4191C1C0
Apr 28 01:19:21.973: //CTI/CM:  dstCallID 370677
Apr 28 01:19:21.973: //CTI/MD:  line_info 40088224, dn 73460
Apr 28 01:19:21.977: //CTI/MD:    * cti_cmm_crs_proc_tr_call_mediaattached
Apr 28 01:19:21.977: //CTI/MD:        parm --> callID 370675, line_info 40088224, call_inst 13374F18
Apr 28 01:19:21.977: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 73460 gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:21.977: //CTI/CM:cmm_find_callid_from_gcid  dn 73460
Apr 28 01:19:21.977: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:21.977: //CTI/CM:      target_node 4098E858
Apr 28 01:19:21.977: //CTI/CM:   - gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:21.977: //CTI/CM:  to return callID 370675
Apr 28 01:19:21.977: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 73460 callID 370675
Apr 28 01:19:21.977: //CTI/CM:find_lineinfo_node    finding number 73460
Apr 28 01:19:21.977: //CTI/CM:    target_node 40088218
Apr 28 01:19:21.977: //CTI/CM:   - dn 73460
Apr 28 01:19:21.977: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 3 mac 0C272454DE75
Apr 28 01:19:21.977: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_MEDIAATTACHED
Apr 28 01:19:22.009: //CTI/CM:cti_cmm_notify_trigger
Apr 28 01:19:22.009: //CTI/MD:-- trigger 22, callID 370675, dn 73460, reason 926102583, result 905969664
Apr 28 01:19:22.009: //CTI/CM:find_lineinfo_node    finding number 73460
Apr 28 01:19:22.009: //CTI/CM:    target_node 40088218
Apr 28 01:19:22.009: //CTI/CM:   - dn 73460
Apr 28 01:19:22.009: //CTI/CM:  CallEntry 4191C1C0
Apr 28 01:19:22.009: //CTI/CM:  dstCallID 370677
Apr 28 01:19:22.009: //CTI/MD:  line_info 40088224, dn 73460
Apr 28 01:19:22.009: //CTI/MD:    * cti_cmm_crs_proc_tr_call_mediaattached
Apr 28 01:19:22.009: //CTI/MD:        parm --> callID 370675, line_info 40088224, call_inst 13374F18
Apr 28 01:19:22.009: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_GCID  num 73460 gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:22.009: //CTI/CM:cmm_find_callid_from_gcid  dn 73460
Apr 28 01:19:22.009: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:22.009: //CTI/CM:      target_node 4098E858
Apr 28 01:19:22.009: //CTI/CM:   - gcid 6AA6E9F7-EC7B11E4-891AAA78-418DAEF4
Apr 28 01:19:22.009: //CTI/CM:  to return callID 370675
Apr 28 01:19:22.009: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  num 73460 callID 370675
Apr 28 01:19:22.009: //CTI/CM:cti_cmm_set_dev_id_DN_Phone_by_callID  getting dn_tag 3 mac 0C272454DE75
Apr 28 01:19:22.009: //CTI/CM:cti_cmm_notify_ccm_from_lineinfo trigger EV_MEDIAATTACHED
Apr 28 01:19:25.709: //CTI/PI:cti_frontend_proc [5A7C7]: received CC Event [19]: CC_EV_CALL_INFO
Apr 28 01:19:25.709: //CTI/PI:pi_process_service_event event 19
Apr 28 01:19:25.709: //CTI/PI:    got CC_EV_CALL_INFO callID 370631
Apr 28 01:19:25.709: //CTI/PI:pi_parse_service event 0
Apr 28 01:19:25.709: CTI_PARSER:Processing XML message
    <callToBeAnswered>
        <deviceID>73566</deviceID>
    </callToBeAnswered>
</AnswerCall>
Apr 28 01:19:25.709: //CTI/XI:csta_AnswerCall_cb: Function Called
Apr 28 01:19:25.709: //CTI/XI:csta_callToBeAnswered_cb: Function Called
Apr 28 01:19:25.709: //CTI/XI:csta_deviceID_cb: Function Called
Apr 28 01:19:25.709: //CTI/XI:csta2cti:811 csta_service_type_t(1)
Apr 28 01:19:25.709: //CTI/XI:csta2cti_DeviceID: csta(73566) attr(0,) number(73566) phone-context=(0,) device=()
Apr 28 01:19:25.709: //CTI/XI:csta2cti:1062 cti_ev_type_t(39)
Apr 28 01:19:25.709: //CTI/SM:sm_find_scb_node_by_context context_id 370631
Apr 28 01:19:25.709: //CTI/SM:    to return 40979B14
Apr 28 01:19:25.709: //CTI/PI:pi_process_service_event Feature Server Type = 2, Monitor_only = 0
Apr 28 01:19:25.709: //CTI/SM:sm_handle_cc_service event 39
Apr 28 01:19:25.709: //CTI/CC:ccm_process_sm_event event 39
Apr 28 01:19:25.709: //CTI/CM:find_lineinfo_node    finding number 73566
Apr 28 01:19:25.709: //CTI/CM:    target_node 419665B4
Apr 28 01:19:25.709: //CTI/CM:   - dn 73566
Apr 28 01:19:25.709: //CTI/CC:ccm_find_ccb_by_gcid parent 0
Apr 28 01:19:25.709: //CTI/CC:ccm_append_ccb ccb 44415D40
Apr 28 01:19:25.709: //CTI/CC:    final ccb count 1
Apr 28 01:19:25.709: //CTI/CC:ccm_drive_fsm state_curr 1 event 39
Apr 28 01:19:25.709: //CTI/CC:        Eventual selection 15
Apr 28 01:19:25.709: //CTI/CC:Fsm_Idle_AnswerCall answering 73566
Apr 28 01:19:25.709: //CTI/CM:cmm_find_callid_from_gcid  dn 73566
Apr 28 01:19:25.709: //CTI/CM:find_gcidinfo_node
Apr 28 01:19:25.709: //CTI/CM:      target_node 0
Apr 28 01:19:25.709: //CTI/CM:      Gcidinfo node Search FAILED
Apr 28 01:19:25.709: //CTI/CM:  to return callID -1
Apr 28 01:19:25.709: //CTI/CC:ccm_delete_ccb
Apr 28 01:19:25.709: //CTI/CC:    ccb 44415D40 released
Apr 28 01:19:25.709: //CTI/CC:    final ccb count 0
Apr 28 01:19:25.709: //CTI/SM:sm_process_ccm_event event 53
Apr 28 01:19:25.709: //CTI/PI:pi_send_cc_event event 53 context_id 370631
Apr 28 01:19:25.709: //CTI/PI:pi_build_event event 53
Apr 28 01:19:25.709: //CTI/XI:cti2csta:1076 cti_ev_type_t(53)
Apr 28 01:19:25.709: //CTI/XI:cti2csta_error: cti_error = 5
Apr 28 01:19:25.709: //CTI/XI:cti2csta:2169 csta_EventType_t(1)
Apr 28 01:19:25.709: //CTI/XML:csta_xml_builder: XML message evt->protocol(1) buffer size(5000), return length(177), message(177)
  </CSTAErrorCode>
I don't see callID in AnswerCall, could you please share your code how you are answering the call. Which call did you pass to answer method.
    <callToBeAnswered>
    </callToBeAnswered>
</AnswerCall>
Raghavendra
Hi Raghavendra,
Below are the code to answer a call.
CMECall myCall1 = provider.createCall(CMECall.Type.DIRECT);
tc = ephone1.getTerminalConnection(dn1);
tc.answer(myCall, cmeResponse );
Looks like you are passing empty call, please try to get CMECall from CMECallConnectionRingingEvent  and pass to answer method.
Raghavendra
yup that's it.
I wonder why it works on internal call ? Thanks
