04-20-2016 09:04 AM
I see lots of other constants in CiscoCallEv.java but none for 500:
public static final int CAUSE_INTERWORKINGUNSPECIFIED = 127;
public static final int CAUSE_CTIPRECEDENCEOUTOFBANDWIDTH = 129;
public static final int CAUSE_REDIRECTED = 200;
public static final int CAUSE_OUTBOUNDTRANSFER = 501;
public static final int CAUSE_OUTBOUNDCONFERENCE = 502;
public static final int CAUSE_INBOUNDTRANSFER = 503;
public static final int CAUSE_INBOUNDCONFERENCE = 504;
public static final int CAUSE_INBOUNDBLINDTRANSFER = 505;
public static final int CAUSE_CTIMANAGER_FAILURE = 507;
public static final int CAUSE_CALLMANAGER_FAILURE = 508;
It appears in the jtapi log like this:
1549: Apr 20 12:38:55.226 ADT %JTAPI-JTAPI-7-UNK:(P1-devuser2) 957495/1 CallCtlTermConnDroppedEv SEP000AB86A7B94 [#113] Cause:100 CallCtlCause:209 CiscoCause:500 FeatReason:16
1550: Apr 20 12:38:55.226 ADT %JTAPI-JTAPI-7-UNK:(P1-devuser2) 957495/1 ConnDisconnectedEv 6020::1 [#114] Cause:100 CallCtlCause:0 CiscoCause:500 FeatReason:16
1551: Apr 20 12:38:55.226 ADT %JTAPI-JTAPI-7-UNK:(P1-devuser2) 957495/1 CallCtlConnDisconnectedEv 6020::1 [#115] Cause:100 CallCtlCause:209 CiscoCause:500 FeatReason:16
What does it mean and where is it defined?
Derrick
04-20-2016 09:14 AM
Similar question for Cause=0.
Appears in jtapi log like this:
1081: Apr 20 13:05:37.410 ADT %JTAPI-JTAPI-7-UNK:(P1-devuser2) 957496/1 TermConnCreatedEv SEP001819231713 [#54] Cause:0 CallCtlCause:0 CiscoCause:100 FeatReason:12
Derrick
04-20-2016 09:56 AM
Derrick,
You may have an older version of the cause codes:
CAUSE_NOERROR 0X00 (0)
CAUSE_INTERNALCAUSE 0X1F4 (500)
David
04-20-2016 10:07 AM
Thanks David.
I have a fairly new version:
Specification-Title: JTAPI
Specification-Version: 1.2
Specification-Vendor: Sun Microsystems, Inc..
Implementation-Title: CiscoJtapiClient
Implementation-Version: 10.5(1.10000)-2 Release
Implementation-Vendor: Cisco Systems, Inc
What classes are CAUSE_NOERROR and CAUSE_INTERNALCAUSE defined in?
Derrick
04-20-2016 10:21 AM
I found CAUSE_NOERROR:
public interface CiscoCallEv extends CiscoEv, CallEv {
public static final int CAUSE_NOERROR = 0;
But still don't know where CAUSE_INTERNALCAUSE is defined.
Derrick
04-20-2016 10:40 AM
Should be in the latest JTAPI Interface Spec:
https://developer.cisco.com/fileMedia/download/546e5dc1-6eae-4c28-a0c8-81330f73832d
David
04-20-2016 10:47 AM
Derrick,
I couldn't find it in the Interface Spec either but I found it in the Developer Guide:
HTH.
David
04-20-2016 10:53 AM
Ok thanks David. Looks like it is not official defined in the jtapi source anywhere.
Maybe something that should be correct in a future version.
Thanks again.
